Sorry for replying to this old post but now it took almost 60 days instead of the usual 30 days before HA crashed.
Only the red LED was on and network LEDs, not the yellow one.
I got something from the log anyway.
Welcome to Home Assistant OS 10.5!
[ 32.130157] systemd[1]: Hostname set to <homeassistant>.
[ 32.136032] systemd[1]: Installed transient /etc/machine-id file.
[ 32.499299] systemd[1]: Queued start job for default target Multi-User System .
[ 32.583348] systemd[1]: Created slice Slice /system/ha-cli.
[ OK ] Created slice Slice /system/ha-cli.
[ 32.607302] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 32.631109] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 32.675371] systemd[1]: Created slice Slice /system/systemd-fsck.
[ OK ] Created slice Slice /system/systemd-fsck.
[ 32.700099] systemd[1]: Created slice Slice /system/systemd-growfs.
[ OK ] Created slice Slice /system/systemd-growfs.
[ 32.723508] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 32.745383] systemd[1]: Started Dispatch Password Requests to Console Directo ry Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 32.768903] systemd[1]: Started Forward Password Requests to Wall Directory W atch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 32.792868] systemd[1]: Reached target Local Encrypted Volumes.
[ OK ] Reached target Local Encrypted Volumes.
[ 32.812672] systemd[1]: Reached target HassOS zram targets.
[ OK ] Reached target HassOS zram targets.
[ 32.832754] systemd[1]: Reached target Local Integrity Protected Volumes.
[ OK ] Reached target Local Integrity Protected Volumes.
[ 32.856862] systemd[1]: Reached target NFS client services.
[ OK ] Reached target NFS client services.
[ 32.876696] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 32.896694] systemd[1]: Reached target Preparation for Remote File Systems.
[ OK ] Reached target Preparation for Remote File Systems.
[ 32.920670] systemd[1]: Reached target Remote Encrypted Volumes.
[ OK ] Reached target Remote Encrypted Volumes.
[ 32.940690] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 32.960616] systemd[1]: Reached target Remote Verity Protected Volumes.
[ OK ] Reached target Remote Verity Protected Volumes.
[ 32.984701] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 33.004711] systemd[1]: Reached target Local Verity Protected Volumes.
[ OK ] Reached target Local Verity Protected Volumes.
[ 33.025525] systemd[1]: Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 33.109174] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 33.132994] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 33.162320] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 33.185757] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 33.205381] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 33.229295] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 33.252551] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 33.273189] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 33.293267] systemd[1]: Huge Pages File System was skipped because of an unme t condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 33.349061] systemd[1]: Mounting POSIX Message Queue File System...
[ 33.373431] systemd[1]: Mounting Kernel Debug File System...
[ 33.398791] systemd[1]: Mounting Kernel Trace File System...
[ 33.430992] systemd[1]: Starting Create List of Static Device Nodes...
[ 33.459942] systemd[1]: Starting Load Kernel Module configfs...
[ 33.521506] systemd[1]: Starting Load Kernel Module drm...
[ 33.545401] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 33.613600] systemd[1]: Starting Load Kernel Module fuse...
[ 33.630954] fuse: init (API version 7.37)
[ 33.652182] systemd[1]: Starting Journal Service...
[ 33.673266] systemd[1]: Starting Generate network units from Kernel command l ine...
Starting Generate network …ts from Kernel command line...
[ 33.753166] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 33.776986] systemd[1]: Starting Coldplug All udev Devices...
[ 33.841219] systemd[1]: Starting Disk Manager...
[ 33.861062] systemd[1]: Starting HassOS ZRAM tmp...
[ 33.885412] systemd[1]: Starting HassOS ZRAM var...
[ 33.903478] zram1: detected capacity change from 0 to 65536
[ 33.904120] zram2: detected capacity change from 0 to 32768
[ 33.947571] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Trace File System.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module efi_pstore.
[ OK ] Finished Load Kernel Module fuse.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
[ OK ] Finished HassOS ZRAM tmp.
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished HassOS ZRAM var.
[ OK ] Reached target Preparation for Network.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting D-Bus System Message Bus...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
[ 34.462963] audit: type=1334 audit(1680605724.431:2): prog-id=6 op=LOAD
[ 34.470817] audit: type=1334 audit(1680605724.443:3): prog-id=7 op=LOAD
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Started Disk Manager.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Found device /dev/zram2.
[ OK ] Found device /dev/ttyAMA2.
[ OK ] Found device /dev/disk/by-label/hassos-overlay.
[ 35.018711] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ OK ] Found device /dev/disk/by-label/hassos-boot.
[ 35.095328] videodev: Linux video capture interface: v2.00
[ 35.104732] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned.
[ 35.126366] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned.
[ 35.127010] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned.
[ 35.130766] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned.
[ 35.140868] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 35.146983] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 35.167050] i2c-bcm2835 fe205c00.i2c: Could not read clock-frequency property
[ 35.173624] rpivid feb10000.codec: Device registered as /dev/video19
[ 35.175661] [vc_sm_connected_init]: start
[ 35.182644] [vc_sm_connected_init]: installed successfully
[ 35.190662] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 35.200496] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 35.202221] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 35.205283] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 35.234163] bcm2835_v4l2: module is from the staging directory, the quality i s unknown, you have been warned.
[ 35.239619] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 35.239629] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Starting File System Check…v/disk/by-label/ha[ 35.270118] dwc2 fe9800 00.usb: supply vusb_d not found, using dummy regulator
ssos-boot...
[ 35.285928] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 35.293629] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 35.309132] dwc2 fe980000.usb: supply vusb_a not found, using dummy regulator
[ 35.331237] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev /video13
[ 35.339495] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 35.346610] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 35.348394] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de v/video14
[ 35.361912] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de v/video15
[ 35.372496] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/ video16
[ 35.380429] bcm2835-isp bcm2835-isp: Register output node 0 with media contro ller
[ 35.388042] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr oller
[ 35.395677] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr oller
[ 35.403934] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr oller
[ 35.422844] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 35.429932] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 35.464772] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev /video20
Starting File System Check…isk/by-label/hassos-overlay...
[ 35.496797] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de v/video21
[ 35.509574] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de v/video22
[ 35.519600] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/ video23
[ 35.527502] bcm2835-isp bcm2835-isp: Register output node 0 with media contro ller
[ 35.535656] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr oller
[ OK ] Finished File System Check…dev/disk/by-label/hassos-boot.
[ 35.550587] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 35.566903] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 35.580623] dwc2 fe980000.usb: EPs: 8, dedicated fifos, 4080 entries in SPRAM
[ 35.588628] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr oller
[ 35.609985] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr oller
Mounting HassOS boot partition...
[ 35.627873] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 35.635040] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 35.642175] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 35.643118] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase
[ 35.657599] dwc2 fe980000.usb: DWC OTG Controller
[ 35.664564] dwc2 fe980000.usb: new USB bus registered, assigned bus number 1
[ 35.667220] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 35.671804] dwc2 fe980000.usb: irq 41, io mem 0xfe980000
[ OK ] Mounted Hass[ 35.691203] usb usb1: New USB device found, idVendor=1d6 b, idProduct=0002, bcdDevice= 6.01
OS boot partition.
[ 35.704610] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 35.711907] usb usb1: Product: DWC OTG Controller
Starting Home Assistant OS Agent...
[ OK ] Finished File System Check…/disk/by-label/hassos-overlay.
[ 35.808358] usb usb1: Manufacturer: Linux 6.1.21-v8 dwc2_hsotg
[ 35.814699] usb usb1: SerialNumber: fe980000.usb
[ OK ] Started Home Assistant OS Agent.
[ 35.983825] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6
[ 35.994123] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455 -sdio.raspberrypi,4-compute-module-ha-yellow.bin failed with error -2
[ 36.011003] hub 1-0:1.0: USB hub found
[ 36.015514] hub 1-0:1.0: 1 port detected
[ 36.084491] usbcore: registered new interface driver brcmfmac
Mounting HassOS overlay partition...
[ 36.207608] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Q uota mode: none.
[ OK ] Mounted HassOS overlay partition.
[ 36.232117] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
Mounting Dropbear persistent keys...
[ 36.432562] usb 1-1: new high-speed USB device number 2 using dwc2
Mounting Kernel persistent modprobe.d...
[ 36.473153] rtc-pcf85063 6-0051: registered as rtc0
Mounting Kernel persistent modules-load[ 36.482415] rtc-pcf85063 6-00 51: setting system clock to 2023-09-01T16:18:02 UTC (1693585082)
.d...
[ 36.498867] systemd-journald[140]: Oldest entry in /run/log/journal/9a0596709 c884517882c3dd5e1a9d75f/system.journal is older than the configured file retenti on duration (1month), suggesting rotation.
[ 36.516722] systemd-journald[140]: /run/log/journal/9a0596709c884517882c3dd5e 1a9d75f/system.journal: Journal header limits reached or header out-of-date, rot ating.
Mounting Udev persistent rules.d...
Mounting Docker persistent user...
Mounting Dropbear persistent user...
Starting HassOS overlay setup...
[ 36.653285] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcd Device= 1.00
[ 36.661539] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 36.661551] usb 1-1: Product: USB 2.0 Hub [MTT]
[ OK ] Mounted 36.673721] hub 1-1:1.0: USB hub found
;39mDropbear persistent [ 36.680098] hub 1-1:1.0: 4 ports detected
keys.
[ OK ] Mounted Kernel persistent modprobe.d.
[ OK ] Mounted Kernel persistent modules-load.d.
[ OK ] Mounted Udev persistent rules.d.
[ OK ] Mounted Docker persistent user.
[ OK ] Mounted Dropbear persistent user.
[ OK ] Finished HassOS overlay setup.
[ OK ] Reached target Sound Card.
[ OK ] Reached target Hardware activated USB gadget.
Mounting NetworkManager persistent system connections...
Mounting Hostname persistent configuration...
Mounting Hosts persistent configuration...
Mounting Timesyncd persistent configuration...
Starting Retrigger udev rules after user rules mounted...
Starting Apply Kernel Variables...
[ 37.096597] usb 1-1.1: new full-speed USB device number 3 using dwc2
[ OK ] Mounted NetworkManager persistent system connections.
[ OK ] Mounted Hostname persistent configuration.
[ OK ] Mounted Hosts persistent configuration.
[ OK ] Mounted Timesyncd persistent configuration.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Retrigger udev rules after user rules mounted.
[ TIME ] Timed out waiting for device ▒▒dev/disk/by-label/hassos-data.
[DEPEND] Dependency failed for File…dev/disk/by-label/hassos-data.
[DEPEND] Dependency failed for HAOS data disk detach.
[DEPEND] Dependency failed for HassOS data partition.
[DEPEND] Dependency failed for Grow File System on /mnt/data.
[DEPEND] Dependency failed for Docker persistent data.
[DEPEND] Dependency failed for Dock… Application Container Engine.
[DEPEND] Dependency failed for HassOS supervisor.
[DEPEND] Dependency failed for HassOS AppArmor.
[DEPEND] Dependency failed for HAOS swap file.
[DEPEND] Dependency failed for Systemd persistent logging.
[DEPEND] Dependency failed for Flus…Journal to Persistent Storage.
[DEPEND] Dependency failed for HAOS swap.
[DEPEND] Dependency failed for HassOS data resizing.
[DEPEND] Dependency failed for Home…t OS data partition migration.
[ OK ] Reached target Swaps.
Mounting Temporary Directory /tmp...
Mounting Buildroot /var tmpfs...
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Mounted Buildroot /var tmpfs.
Mounting NetworkManager persistent data...
Mounting Bluetooth persistent state...
Mounting Systemd persistent state...
[ OK ] Mounted NetworkManager persistent data.
[ OK ] Mounted Bluetooth persistent state.
[ OK ] Mounted Systemd persistent state.
[ OK ] Reached target HassOS overlay targets.
[ OK ] Reached target Local File Systems.
Starting Load/Save Random Seed...
Starting Create Volatile Files and Directories...
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Create Volatile Files and Directories.
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
Starting Docker Socket for the API...
[ OK ] Listening on Journal Gateway Service Socket.
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
Starting Network Manager...
Starting Configure multigenerational LRU...
Starting HassOS persists data on bootstate...
Starting Configure Bluetooth Modems connected by UART...
[ OK ] Started Input Event Daemon.
Starting RAUC Update Service...
Starting RPC Bind...
Starting User Login Management...
Starting WPA supplicant...
[ OK ] Started RPC Bind.
[ OK ] Finished Configure multigenerational LRU.
[ OK ] Finished HassOS persists data on bootstate.
[ OK ] Started RAUC Update Service.
[ OK ] Started Network Manager.
[ OK ] Started WPA supplicant.
[ OK ] Reached target Network.
Starting Network Manager Wait Online...
Starting containerd container runtime...
Starting HassOS Configuration Manager...
Starting Hostname Service...
Starting Permit User Sessions...
[ OK ] Finished Permit User Sessions.
[ OK ] Started User Login Management.
[ OK ] Started Home Assistant CLI.
[ OK ] Started Serial Getty on ttyAMA2.
[ OK ] Reached target Login Prompts.
[ OK ] Finished HassOS Configuration Manager.
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service...
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started containerd container runtime.
[ OK ] Started Configure Bluetooth Modems connected by UART.
[ OK ] Created slice Slice /system/bthelper.
[ OK ] Reached target HassOS hardware targets.
[ OK ] Reached target Multi-User System.
Starting Raspberry Pi bluetooth helper...
[ OK ] Finished Raspberry Pi bluetooth helper.
Starting Bluetooth service...
[ OK ] Started Bluetooth service.
[ OK ] Reached target Bluetooth Support.
[ OK ] Finished Network Manager Wait Online.
[ OK ] Reached target Network is Online.
Starting Notify NFS peers of a restart...
Starting Wait Until Kernel Time Synchronized...
Starting Network Time Synchronization...
[ OK ] Started Notify NFS peers of a restart.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Finished Wait Until Kernel Time Synchronized.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Reached target Timer Units.
pi@raspberrypi3:~ $
it’s unfortunate there are no timestamps, else the issue would be easier to locate.
I believe this part is impotant,
however, later on, the system is able to mount /tmp and /var, so not sure why it crashes.
I think, I need to replace my SSD
