Though I do see that you use an iPad 3? That is iOS 9.3.5? iOS 9.3.5 does not support ES6 which means that most cards will not work on the iPad 3 (I have one too, but never use it).
The iPhone 6 has iOS 12? That should work (though the iPhone 6 nowadays is considered a bit slow).
What you can try is this, uninstall card-mod, config-template-card, text-input-row, fold-row and restart BEFORE you re-install them. This to make sure that nothing is keeping the cards in cache (because cache is a real pain in the behind and this is even worse on iOS). Next start home assistant and see if anything loads (it should NOT, if it does show the header then it is 100% cache). Once you have verified that it is really not working anymore re-install them. Also make absolutely sure you have the latest version of everything and also make sure that the resources are added (you might have to do this manually).
Also on iOS you might want to re-install the app after you have re-installed the cards from HACS since iOS is really hard on cache (even the clear cache button often does not work for me).
Lastly you can try removing line 8 and 9 in /packages/homekit-infused/configuration.yaml. This loads the js variant of card-mod for better performance. HKI5 will work fully without it! But it might be possible older variants of iOS canât handle it right so you might get some success there. Though note since it wonât be loaded beforehand it might be possible that the interface loads slightly slower.
Since I donât have an iPhone 6 to test it (and an iPad 3 does not have custom card support anyways so I wonât even try it on that). The error you are getting is related to the resource not getting loaded, so removing these lines might be your solution (youâll just have to do it again after each HKI update).
Let me know what your results are.
@lpt2007 I think I have been able to replicate the problem and I might have found a fix for it. I will update the repo soon with a new release, once you update please let me know if the problem still persists.
The public release is almost ready to be published. People that are currently on HKI 5 betaâs will no longer receive new betaâs and can update straight to the public version.
The expected release date is upcoming Friday, however there might be an early surprise!
I updatet to latest version. An the error screen is gone:)
Now I have different problem on two devices both have ios 12.5.5. On both I only see menu on top and line where greeting is. Entity icon for lights have incorrect position.
This has to do with the viewport on iOS not understanding the default pixel width, Someone recently showed me what to do with that. So I might be able to fix it soon. I do however would like your input. Would you maybe care to join the discord channel (link in the first post)? That way I can just send you fixes directly and youâll be able to help me fix this issue for iOS users.
Not a requirement for me to help you ofcourse, but if you would do that it would be greatly appreciated.
Hi. So i have been following the Videos and before I move to the addons video I thought I would create a room or two. I have put the below in to my views.yaml , restarted and even rebooted HA but the living room never shows up.
I am not 100% sure what I am doing wrong. I even followed along with the kitchen example in your video and same thing.
Do you have the documentation on how to get the people and their pictures o the main page? I am starting so small trying to learn this. I am starting with the people and setting up my CCTV views.
