Homematic(IP) Local - Reduce room temperature when a window or door is opened
This is a modified blueprint (original: Homematic - Reduce room temperature when a window or door is opened) which works for the new and upcoming Homematic(IP) Local integration by @danielperna84.
With this you can use any sensor (not just HmIP) to control the window state of the thermostats.
blueprint:
  name: Window Open, Notify HomeMatic CCU
  description: >
    An automation blueprint that reduces the set temperature of your climate
    device or group if a window sensor is open for more than the preset wait time.
    It uses the Homematic window sensor channel to set the temperature to the "Open-window
    temperature" set in the device configuration. You should set the "Mode for temperature
    fall detection" to Inactive to avoid conflicts. It waits until the window is closed
    again in order to restore the climate entity temperature. It has an optional blocking
    entity to prevent the automation running unnecessarily, for example during the
    Summer season.
  domain: automation
  input:
    window_entity:
      description: The window sensor that will control the climate entity.
      selector:
        entity:
          domain: binary_sensor
          device_class: window
          multiple: true
    open_delay:
      name: Windows Open Wait Time
      description: Time to delay after window opens before notifying HomeMatic.
      default: 30
      selector:
        number:
          min: 0.0
          max: 600.0
          unit_of_measurement: seconds
          mode: slider
          step: 1.0
    blocking_entity:
      name: (OPTIONAL) Blocking Entity
      description: >
        If this entity's state is on, it will prevent the automation from
        running. E.g. summer mode or away mode.
      default:
      selector:
        entity:
          domain: input_boolean
    climate_entity:
      description: The climate entity that is controlled by the window sensor.
      selector:
        device:
          integration: homematicip_local
  source_url: https://community.home-assistant.io/t/homematic-ip-local-reduce-room-temperature-when-a-window-or-door-is-opened/373305
variables:
  blocking_entity: !input "blocking_entity"
  climate_target: !input "climate_entity"
  climate_id: !input "climate_entity"
  open_delay: !input "open_delay"
  windows: !input "window_entity"
  - platform: state
    entity_id: !input "window_entity"
    to: "on"
    for: !input "open_delay"
condition:
  - condition: template
    value_template: "{{ (blocking_entity == none) or (states[blocking_entity].state == 'off') }}"
  - service: homematicip_local.set_device_value
      device_id: "{{ climate_id }}"
      channel: 1
      parameter: WINDOW_STATE
      value: 1
  - wait_template: >
          {% set closed = namespace(bool=true) %}
          {% for state in states.binary_sensor%}
              {% if state.entity_id in windows %}
                  {% if state.state == "on" %}
                   {% set closed.bool = false %}
                  {% endif %}
             {% endif %}
          {% endfor %}
          {{closed.bool}}
    continue_on_timeout: false
      channel: 1
      value: 0
mode: restart
max_exceeded: silent
Beware that aquara sensors are usually listed as door sensors, not as window sensors, so they won’t be listed in the selection area. You can either enter the entity manually (binary_sensor....) anyway or change the type of the sensor in Home Assistant by going to the entity settings.
Updates:
  • 08/05/22 - Updated syntax to newer version of homematicip_local (hahm → homelaticic_local) and added support for multiple window sensors.
This only makes sense with radiators because the underfloor heating is too sluggish for that.
Why not just do this via the CCU software or whatever else you use for Homematic software.
I use radiators and aqara door sensors (zigbee) which are connected via zigbee2mqtt to home assistant. Can you elaborate what you mean with why I don’t use the ccu?
Hi, I actually assumed that you are using a CCU and Homematic so it is at least in the title and in the blueprint, and not that it is Zigbee.
I am using raspberrymatic addon and homematic TVRs, but I don’t own homematic window sensors since I find them too bulky.
The blueprint/automation helps to get the same functionality as the homematic sensors with what ever sensor you like to use.
Why is there also concealed installation. Which are they using?
I use both a Raspberrymatic for Homematic and a separate Raspberry for Homeassistant.
Both are separated but the automation with Zigbee / Zwave / Homematic only via HA.
I use a single raspberry pi for everything.
The aquars sensors are a lot cheaper (7 euros each) that’s also a reason why I prefer them.
That would also have been an alternative.
That would also have been an alternative. FUNK-REED-SCHALTER JA-182M JABLOTRON - Funk-Reedschalter - Delta
Thank you for that great Blueprint. I‘ve imported the template und tried to configure one Automation with a Aquara Door and Windows Sensor and a Homematic climate. But unfortunately the Aquara sensor is not listed in the enteties so i am not able to select the device!
But i have no clue why?
The devices listed are window sensors, the aquars sensors are usually adopted as door sensors. In home assistant, select the aquar sensor and edit it (where you can edit friendly name etc) and there you can also select whether it should be used as a door or window sensor. This should fix it.
Alternatively you can enter the name manually “binary_sensor…” and then it also should show all binary sensors.
Thank you. That’s it. Now i can select the Aquara Sensor. I configured now one automation but the climate does not react.
Is there something to do in addition?
For debugging and error search i have the following questions
How does the climate get the new config?
Is it somewhere visible that the peering was successful besides the window open icon directly on the climate?
I come from FHEM and in the FHEM device it was visisble if the peer was successful or not.
Since it’s not a real paring between the window sensor and the device, no, you won’t be able to see it somewhere in a config. So the climate does not really get a new config, HomeAssistant simply changes the window_open state of the device depending on the aquara sensor.
But as you mentioned, you know when it’s working because of the window-open symbol on the device/the temperature change on the device (depending on your settings in HomeMatic).
Is it still not working? I created this automation with the addon on version 0.12 and it has changed a lot since then, so this might need to be updated, I haven’t checked since I am still on 0.12
Unfortunately it does not work on my side. The climate does not go in window open mode when i open the sensor.
What can i do to get it running or how to trouble shoot this issue?
Can you check if you can set the device state via a regular service call? 0 is closed, 1 is open
You could also try to check the box “value type” and enter int and see if this makes it work. If not, I believe you have the integration not setup correctly, e.g. did not enter the ports in the configuration.yaml and forwarded the ports in HomeMatic firewall.
I tried it manually as described but unfortunately no change in status.
Firewall in Raspberrymatic is open and i can control the devices integrated in HA with the new Homematic Integration but i did not setup something in configuration.yaml
Did you try with checked “Value type” → integer?
You need to make sure that the ports that you enter during the setup of the integration match the ports that you have entered in Home Matic. The JSON RPC port is usually 80 or 443, but when you run Home Matic on the same machine as Home Assistant, you would need to change that port in the Addon/integration since Home Assistant already uses that port on the same IP adresse.
Yes, i also tried with Value type” → integer but state doesn’t change.
So it looks like the communication does not work.
My Raspberrymatic Instance runs on a separate RPI.
To be honest im am now uncertain if it is necessary to configure something in the configuration.yaml?
Thats a part of the configuration from the Homematic(IP) Local integration.
"data": {
    "config": {
      "entry_id": "b45b345a11a87f6b250c97b0fb45a62f",
      "version": 1,
      "domain": "hahm",
      "title": "RaspberryMatic",
      "data": {
        "instance_name": "RaspberryMatic",
        "host": "192.168.178.15",
        "username": "**REDACTED**",
        "password": "**REDACTED**",
        "callback_host": "0.0.0.0",
        "callback_port": 0,
        "json_port": null,
        "tls": false,
        "verify_tls": false,
        "interface": {
          "BidCos-RF": {
            "port": 2001
          "VirtualDevices": {
            "port": 9292,
            "path": "/groups"
So the json_port must be 80?
