How do I use the Dim up+down continuously and released on the IKEA STYRBAR
So I currently want to setup the dimmer controls for the light in my hallway with the STYRBAR remote but the light just ends up flashing. I have tried to restart the HASSIO server to terminate any scripts that might be stuck in a loop, the server also has the Zigbee chip but that didn’t help.
The two scripts that I have is a copy of each other except that they have the different button’s and the light value inverted:
alias: Dim Up
description: ""
  - device_id: 3ba2b5095fb8931ec6eb08fa0b2e2e63
    domain: zha
    platform: device
    type: remote_button_long_press
    subtype: dim_up
    domain: zha
    platform: device
    type: remote_button_long_release
    subtype: dim_up
condition: []
  - if:
      - condition: trigger
        id:
          - Pressed
    then:
      - repeat:
          until:
              id:
                - Released
          sequence:
            - service: light.turn_on
                transition: 1
                brightness_step_pct: 10
                device_id:
                  - a5640c71518f33094c89744d6b73eb35
                  - 2515c06df61643f9d3664bbd51f7749b
                  - 974afc0f514f884ebc83df9f53c62d9f
            - delay:
                hours: 0
                minutes: 0
                seconds: 1
                milliseconds: 0
    else:
      - stop: ""
mode: single
The delay was just added to make sure that the loop isn’t stacking up in the background.
Suggest test these existing Blueprint threads and ask in those threads if you have related questions:
I couldn’t get that to work either, so what I did was use a value_template in the until condition:
repeat:
  until:
    - condition: template
      value_template: "{{ wait.trigger is not none }}"
