I like to control my Philips Hue Lights from my KNX Operators and I need an idea how to implement this with HA.
Thanks for your help
Have you checked the KNX component documentation? As soon as you setup the components (Hue and KNX) you can build automations and combine the two of them.
Sure. I did.
I have no clue which component my KNX operator are. Sensor?
I think a working config example would help me a lot.
I created a KNX cookbook that answers this question.
I now use this
binary_sensor:
#https://www.home-assistant.io/components/binary_sensor.knx/
- platform: knx
address: '1/1/31'
automation:
- counter: 1
hook: 'on'
- data:
entity_id: light.eingang
service: light.turn_on
- counter: 1
hook: 'off'
- data:
service: light.turn_off
@kmplng seem the indentions are wrong in your Example, at least I struggle with it
If you have knx wall switches and deconz try this:
