and yes, running todays dev nightly with these PR’s does change significantly. At first I thought it would also influence the config check, but that remains about 20 secs on my instance (the Yaml check that is, not the ha core check, which takes much longer).
It does however change the startup time of the integrations significantly. I still see a top4 listing of heavy integrations, but most of the others have decreased enormously reducing more than 50% for some, or even more. Compare my previous boolean (39.07) from above with:
back atop of the list is MQTT, changing enormously per startup.
(comp with 156 str 2022.6: Gaining new insights! - #356 by Mariusthvdb)
and this morning with the new pr’s a blazing:
MQTT is really unreliable in this listing…
update
grr, next startup:
all in all this listing isnt very reliable…
how can this be so different upon each restart
