Hi to everybody,
is there a way to open homeassistant.tar.gz ? It’s around 1Gb and i was using a password.
I’m trying with 7z but it gives me an error: impossible to open it as an archive.
Is there a way to solve this?
I’m no more able to rebuild this snapshot, even with a fresh home assistant installation.
I’ve a lot of work lost inside there
Hi Tom. Yes maybe are corrupted. I think so…even if i have 3 snapshot and all these are giving me same error. Will try with winrar now and yes…i’m using windows
Yes i’m sure to have the correct password, cause i’m using it in other home assistant instances and just copy and paste snapshot automations and dropbox addon config
Actually is not true that the snapshot is not rebuilding because something happen. Home assistant start back again giving me different errors.
The proof that something is back is about the old privateKey i need to use for ssh connection.
Anyway, and seem so strange, no configuration files are back. Inside the config/ folder i’ve only default files of the fresh hassio installation
Ok so i’ve tryed it. Installed last hassio image and then trought console installed:
hassio homeassistant update --version=0.91.2
91.2 (the home assistant version of the snapshot)
But the webserver reply with a 404 error
404: Not Found
And in the log i can see this
2019-07-26 17:11:09 WARNING (MainThread) [homeassistant.config] Incomplete core configuration. Auto detected latitude: 45.408, longitude: 11.8859, name: Padova, time_zone: Europe/Rome, elevation: 0
2019-07-26 17:11:11 ERROR (MainThread) [homeassistant.setup] Error during setup of component onboarding
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 151, in _async_setup_component
hass, processed_config)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/onboarding/__init__.py", line 24, in async_setup
data = await store.async_load()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/storage.py", line 81, in async_load
return await self._load_task
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/storage.py", line 104, in _async_load
data['version'], data['data'])
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/storage.py", line 197, in _async_migrate_func
raise NotImplementedError
NotImplementedError
2019-07-26 17:11:11 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2019-07-26 17:11:11 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2019-07-26 17:11:12 ERROR (MainThread) [homeassistant.loader] Unable to find platform google_translate.
2019-07-26 17:11:12 ERROR (MainThread) [homeassistant.setup] Error during setup of component met
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 154, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
AttributeError: module 'homeassistant.components.met' has no attribute 'setup'
2019-07-26 17:11:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2019-07-26 17:11:13 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2019-07-26 17:11:14 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2019-07-26 17:11:14 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, logbook
2019-07-26 17:11:14 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2019-07-26 17:11:17 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1885959248] Received invalid command: get_panels
2019-07-26 17:11:17 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1885959248] Received invalid command: frontend/get_themes
2019-07-26 17:11:17 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1885959248] Received invalid command: frontend/get_translations
deleted .storage folder and now 91.2 is working
i’ve tryed wipe and restore snapshot and i’ve got addons back but files in the config folder are still the ones from the fresh hassio installation.
so what’s the problem? nothing is showed in the log
it’s so frustrating.
i’ve tryed with all 3 snapshot i ve without luck
I was surprised about this too. Password protected (encrypted) snapshots can not be opened. The type of encryption seems to be proprietary, which gives me a very bad feeling because not being able to access snapshot contents from outside HA is a no go for me. People don´t want and really should not end like
