vpomax
(Vpomax)
January 20, 2018, 5:49pm
1
Hi, Xiaomi Gateway ringtones are very shorts.
I wish to play them in loop when a door/wndows sensor is opened… how can I do it?
- alias: Play ringtone when window is open
- platform: state
entity_id: binary_sensor.door_window_sensor_123456789
to: 'on'
- service: xiaomi_aqara.play_ringtone
gw_mac: !secret gw_mac
ringtone_id: 10
ringtone_vol: 100
Hefford27
(Graham Hefford)
January 20, 2018, 7:04pm
2
Hi
I have done something similar for an Alarm Siren based on the Xiaomi Gateway. I have done this by a Script being called by the automation.
There is the script, I’m still learning scripting, so there may be a better way, but will give you an idea.
## Alarm Siren Loop ##
# START XIAOMI SIREN
xiaomi_alarm_siren:
alias: Xiaomi Alarm Siren
sequence:
data_template:
ringtone_id: 0
ringtone_vol: 100
gw_mac: 34:CE:00:91:F2:BC
data_template:
ringtone_id: 0
ringtone_vol: 100
gw_mac: 34:CE:00:90:83:4F
- delay:
#### time for siren to play before restarting
seconds: 14
- service: script.turn_on
entity_id: script.xiaomi_alarm_siren_loop
# LOOP BACK TO START SIREN AGAIN
xiaomi_alarm_siren_loop:
alias: Xiaomi Alarm loop
sequence:
- delay:
#### time for siren to start
seconds: .1
# CANCEL Siren when Disarm - refer to Automation
xiaomi_alarm_siren_cancel:
alias: Cancel Siren Cancel
sequence:
- delay:
seconds: 1
- service: script.turn_off
vpomax
(Vpomax)
January 20, 2018, 7:37pm
3
HI @Hefford27 I’m a newbie… after I put your code in script section of configuration.yaml or in the script.yaml file… how do I call this script in my automation?
Hefford27
(Graham Hefford)
January 20, 2018, 10:12pm
4
hi try this (Again I am quite new, so might not be the best way )
When Alarm Triggers Automation
- alias: 'Alarm Triggered Siren'
initial_state: 'on'
platform: state
entity_id: alarm_control_panel.house
to: 'triggered'
- service: switch.turn_on
entity_id: switch.outside_alarm_siren
To Turn Off Siren When Alarm Disarmed Automation
- alias: 'Alarm Disarm Sound Turn off Siren and Stop Gateways Flashing'
initial_state: 'on'
platform: state
to: 'disarmed'
ringtone_id: 10002
ringtone_vol: 50
entity_id: script.alarmdisarmdashchange
entity_id: script.xiaomi_alarm_siren_cancel
- service: switch.turn_off
Just change the trigger to your sensor and state .
Please note I have a recorded tone that plays on Disarm and I have my Gateways Flash Red when the alarm triggers and this also turns them off, so need to remove those lines, I can if you want give you the Flash Gateway script if your interested.
vpomax
(Vpomax)
January 21, 2018, 12:01am
5
I’m using the System Alarm Add-On, it is a complete system and it already have flashing lights of gateway and it is easy to configure
I have migrated my alarm system to appdaemon. The previous solution based on 350+ lines of automation.yaml and was a pain to maintain.
This system work with any light system (should support color) and with any sensors who report on/off values. I have tested it with xiaomi hub, sensors, buttons.
You can configure these settings:
Key
Description
Default
language
language used for notifcations in text and audio
english
device_trackers
list of tracked devices (for auto arming / …
do you know this project?
Hefford27
(Graham Hefford)
January 21, 2018, 1:05am
6
I have seen it but I have been using the one from
My custom version of an alarm panel hoping to bring many new features at the request of fellow patrons.
Tested with HA Version 0.60.1
You can find the github here: https://github.com/gazoscalvertos/Hass-Custom-Alarm
Please contribute to this thread and submit your requests, suggestions, ideas and pitfalls!.
Features:
MQTT Integration
Google Assistant Integration
Clock display (Optional)
Weather Status (Optional) - NOTE: You must have dark sky weather component enabled specifically sensor.d…
i like the Alarm UI and the check and stuff it does
Hefford27:
you have an external siren, which type?
Hefford27:
yes please, thanks, which ringtone?
Hefford27
(Graham Hefford)
January 27, 2018, 7:45pm
10
this is the call for the Script to change the display on the Wall Tablet for then the Alarm is disarmed all the Wall Panels show a Disarm Message…
Also have TTS working so I get an audible message too.
Hefford27
(Graham Hefford)
January 27, 2018, 7:47pm
11
here you go
### ALARM TRIGGER START FLASHING LIGHT ###
# START FLASH
light_flash:
alias: Alarm Trigger flash on
sequence:
- service: homeassistant.turn_on
entity_id:
- scene.downstairs_night_light_red
- scene.upstairs_night_light_red
- scene.porch_led_light_red
- delay:
#### time for flash light on
seconds: .02
- service: homeassistant.turn_off
entity_id:
- light.gateway_light_34********
- light.gateway_light_34*********
entity_id: script.light_loop
# LOOP BACK TO START FLASH AGAIN
light_loop:
alias: Light flash loop
sequence:
- delay:
#### time for flash light off
seconds: .02
entity_id: script.light_flash
# CANCEL FLASHING
light_flash_cancel:
alias: Cancel Light Flash
sequence:
I recorded the alarm disarm tone and the 30 sec countdown tones from my old Alarm using the Xiaomi App, and play these when the alarm is activated / triggered (before the Siren after 30 secs) and a Disarm tone.
Thank you for the scripts!!! For some reason the alarm_siren_cancel works only half the time. Meaning I have to arm/disarm again when the first time the sound loop still keeps running. Do you have this issue? I wonder if my old laptop is too old to handle it correctly?
This is the automation i use.
alias: ‘Turn off alarm siren’
platform: state
entity_id: alarm_control_panel.ha_alarm
to: ‘disarmed’
Please disregard. I have found the example where the author uses stop_ringtone instead.
https://community.home-assistant.io/t/xiaomi-gateway-alarm/44230
Yoinkz
July 28, 2019, 9:13am
14
Anyone experienced that when the alarm goes off and the Xiaomi starts the loop, it only does it for 5 minutes, then stops and the ‘Yet another alarm component’ goes from Triggered to Armed Away again?
EDIT: I think this must be related to something else.
WRL
January 7, 2020, 6:24pm
15
Hi All,
I have started adventure with HA week ago. Maybe this will be helpful for somebody.
To make a loop for xiaomi gateway sound or light just use scripts that start another script.
To turn off stop scripts. In automation call first script of loop.
scripts.yaml
## Siren Loop ##
xiaomi_alarm1:
sequence:
ringtone_id: 2
ringtone_vol: 1
gw_mac: !secret xiaomi_mac
- delay:
seconds: 5
- service: script.xiaomi_alarm2
xiaomi_alarm2:
sequence:
ringtone_id: 2
ringtone_vol: 1
- delay:
seconds: 5
- service: script.xiaomi_alarm1
## Light Loop ##
flash_gateway1:
alias: Flash Gateway On Red
sequence:
- service: light.turn_on
entity_id: light.gateway_light_<xiaomi_gw_mac>
color_name: red
brightness: 255
- delay:
milliseconds: 600
- service: light.turn_off
- service: script.flash_gateway2
flash_gateway2:
alias: Flash Gateway On Blue
sequence:
color_name: blue
brightness: 255
- delay:
milliseconds: 600
- service: script.flash_gateway1
## Siren and Light Off ##
alarm_off:
alias: Alarm was disarmed
sequence:
entity_id:
- script.flash_gateway1
- script.flash_gateway2
- script.xiaomi_alarm1
- script.xiaomi_alarm2
## Disarm confirmation ##
color_name: green
brightness: 255
- delay:
seconds: 60
automation.yaml
## Alarm ##
- alias: Alarm!
hide_entity: true
- platform: state
entity_id: alarm_control_panel.alarm
to: 'triggered'
## Disarm ##
- alias: Disarm!
hide_entity: true
- platform: state
to: 'disarmed'
- service: script.alarm_off
elik745i
(El Nur)
February 3, 2021, 2:34pm
16
Does not work for some reason, plays second script and stops.
sebdoan
(Sebastian Doan)
March 7, 2021, 11:32pm
17
same thing happened to me, stops after 2nd script.
Further investigation highlighted that the first script was still running hence it would not run again.
Logger: homeassistant.components.script.security_countdown_1
Source: helpers/script.py:1156
Integration: Scripts (documentation, issues)
First occurred: 10:00:08 (3 occurrences)
Last logged: 10:16:38
security_countdown_1: Already running
To fix this i changed the scripts to include closing the other script. My code is as below:
script:
sequence:
entity_id: script.security_countdown_2
gw_mac: f0b429ccxxxx
ringtone_id: 29
ringtone_vol: 10
- delay: "00:00:15"
security_countdown_2:
sequence:
entity_id: script.security_countdown_1
ringtone_id: 29
ringtone_vol: 10
- delay: "00:00:15"
stop_security_sounds:
alias: Stop Security Sound Scripts on Gateway
sequence:
entity_id:
- script.security_countdown_1
- script.security_countdown_2
- service: xiaomi_aqara.stop_ringtone
sebdoan
(Sebastian Doan)
March 8, 2021, 6:18am
18
I’ve done an extensive write-up on how I use the Xiaomi Gateway as a siren for a Home Assistant Alarm System. If you’re interested read it here: Home Assistant Manual Security System with Xiaomi Gateway as Siren
