I have HA and supervisor installed in docker on openWRT system. All is good except supervisor auto update, every time when new version detected, supervisor will pull the new image, shutdown supervisor, but never start supervisor automatically. I don’t know what’s the issue and how to fix it. And I think I can accept the workaround of stop the supervisor’s auto update, and update supervisor and start it by hand. Any idea how I can fix this problem or how can I stop supervisor’s auto update
20-02-18 01:42:44 INFO (MainThread) [hassio.addons] Found 2 installed add-ons,
20-02-18 01:42:44 INFO (SyncWorker_5) [hassio.docker.interface] Attach to homeassistant/amd64-addon-duckdns with version 1.10,
20-02-18 01:42:44 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/amd64-addon-nginx_proxy with version 2.6,
20-02-18 01:42:44 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 01:42:45 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files,
20-02-18 01:42:45 INFO (MainThread) [hassio.discovery] Load 0 messages,
20-02-18 01:42:45 INFO (MainThread) [hassio.ingress] Load 0 ingress session,
20-02-18 01:42:45 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 1,
20-02-18 01:42:45 INFO (MainThread) [__main__] Run Hass.io,
20-02-18 01:42:45 INFO (MainThread) [hassio.api] Start API on 172.30.32.2,
20-02-18 01:42:45 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons,
20-02-18 01:42:45 INFO (MainThread) [hassio.core] Hass.io reboot detected,
20-02-18 01:42:45 INFO (MainThread) [hassio.tasks] All core tasks are scheduled,
20-02-18 01:42:45 INFO (MainThread) [hassio.core] Hass.io is up and running,
20-02-18 03:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 04:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-02-18 04:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-02-18 04:42:48 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-02-18 05:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 07:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 07:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-02-18 07:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-02-18 07:42:48 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-02-18 09:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 10:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-02-18 10:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-02-18 10:42:47 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-02-18 11:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 13:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 13:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-02-18 13:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-02-18 13:42:48 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-02-18 15:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 16:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-02-18 16:42:45 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-02-18 16:42:48 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-02-18 17:42:45 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-02-18 17:52:45 INFO (MainThread) [hassio.tasks] Found new Hass.io version,
20-02-18 17:52:45 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 201,
20-02-18 17:52:45 INFO (SyncWorker_5) [hassio.docker.interface] Update image homeassistant/amd64-hassio-supervisor:200 to homeassistant/amd64-hassio-supervisor:201,
20-02-18 17:52:45 INFO (SyncWorker_5) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor tag 201.,
20-02-18 17:52:56 INFO (SyncWorker_5) [hassio.docker.interface] Tag image homeassistant/amd64-hassio-supervisor with version 201 as latest,
20-02-18 17:52:56 INFO (SyncWorker_5) [hassio.docker.interface] Stop hassio_supervisor application,
20-02-18 17:52:57 INFO (MainThread) [__main__] Stopping Hass.io,
20-02-18 17:52:57 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2,
20-02-18 17:52:57 INFO (MainThread) [hassio.misc.forwarder] Stop DNS forwarding,
20-02-18 17:52:57 INFO (MainThread) [hassio.core] Hass.io is down,
20-02-18 17:52:57 INFO (MainThread) [__main__] Close Hass.io,
