HOWTO: Leviton Vizia rf+ Zone Controllers
The following is a guide on how to use the Leviton Vizia rf+ zone controllers with Home Assistant, specifically:
VRCZ4-M0Z 4-Button Zone Controller (type=“0702” id="0261”)
VRCZ4-MRZ 4-Button Zone Controller with Switch (type=“1202” id="0243”)
The following applies to these two specific versions of the Leviton zone controllers. Although purchased separately, I only have three of them, and there may be different revisions where things are different. I’m also not claiming to be an expert in Z-Wave or Home Assistant. Any feedback or corrections are welcome, and perhaps we can get it into shape for inclusion in the official documentation.
Software Installation
When configuring Home Assistant, it is possible to specify a path to the device database. This allows using the latest database from OpenZWave. Putting it into .homeassistant/config allows it to be be shared with the OpenZWave control panel (which would then installed in into the .homeassistant directory):
zwave: config_path: /usr/local/homeassistant/.homeassistant/config
The OpenZWave control panel and Home Assistant will also access the same network configuration file (zwcfg_…xml).
Coming from Vera and Z-Way, I personally am still using the Z-Way software as the primary Z-Wave controller (even though Z-Way has many many other shortcomings). A second UZB1 USB stick is used for Home Assistant. The UZB1 has the advantage that it can be backed up and restored using the Z-Way software, even if the full feature set of the software is not licensed. The backup is a standard .tar.gz file, and before restoring, it is possible to manipulate its contents, including values that would otherwise be impossible to change (such as the Home ID or Node ID of the controller, or promoting a secondary to a primary controller). Note that it is necessary to perform a factory reset before the restore.
Network Design
Reportedly, some legacy devices cannot report state changes to a controller that is not at Node ID 1. Other devices have problems with Node IDs greater than 32. While I have not encountered this, it’s still a good idea to ensure that the USB stick connected to OpenZWave for Home Assistant is Node ID 1. A verified fact is that some battery operated devices will only ever report their status to one controller, so it may be necessary to pick the primary or secondary controller for the reporting target.
Including the Zone Controller
The VRZC4-M0Z is included by pressing and holding the left side of the first and third buttons (counting from the top) for about five seconds until the LED turns amber. Letting go of the buttons, the LED will blink and the zone controller can be included.
Including the Zone Controller with Switch
The VRZC4-MRZ is “two devices in one”. It will show up on the Z-Wave network with two Node IDs, but both of them will have an identical manufacturer, type and ID.
First, include the zone controller part (buttons 1 and 3) as described above.
Second, include the local switch (load control). The manufacturer’s instructions are confusing or wrong. I succeeded by pressing and holding the left side of buttons 2 and 4.
Buttons and Z-Wave Scenes
Associations
The zone controller can talk to OpenZWave, and “directly” to (some) devices. To talk directly to devices (which makes things faster), the target device’s Node ID must be “associated”. Supposing OpenZWave is Node ID 1, and the light bulbs to be controlled with buttons 1, 2, 3, and 4 are Node IDs 13, 14, 15, 16, then the Z-Wave “Association Groupings” for the zone controller would be:
Controller Button Association Group (Target) Node IDs
1 1 1, 13
2 2 1, 14
3 3 1, 15
4 4 1, 16
Set the associations first. Using the Home Assistant Z-Wave Configuration panel, select the Node ID of the zone controller, and change “Node group associations” (or use Z-Way).
It is possible to add multiple Node IDs for each association group. The key is that Group 1 is Button 1, Group 2 is Button 2, etc.
Note that not all devices support “direct” association. I have found it only works when the device supports the Z-Wave SCENE_ACTIVATION command class.
Scenes
Z-Wave scenes can be programmed to set a light to a certain dimming level, and to turn lights and switches on and off. Like many things in Z-Wave, scenes aren’t that useful when using a powerful controller such as Home Assistant, but they still have some advantages. Direct association is faster (otherwise, there can be an annoying noticeable delay), and works even when the controller is down.
Pressing a button on the zone controller sends out a Z-Wave SCENE_ACTIVATION command. The Scene ID numbers have nothing to do with Node IDs, and different buttons and different devices can send out the same scene number.
To reuse Scene ID numbers across buttons and devices is inviting trouble. Instead, create a scene number plan and define which device and button creates which scene. OpenZWave may have built-in scene management, but I have been unable to get it to work. It would be easier if software managed this.
For example:
Device Scene IDs
scene_controller_4 11, 12, 13, …
scene_controller_5 21, 22, 23, ...
scene_controller_6 31, 32, 33, …
As shipped, the Leviton zone controllers emit SCENE_ACTIVATION commands for the left sides of the buttons only, and use Scene IDs 1 through 4. The right (“off”) side of the buttons can turn directly associated devices off, but the only notification OpenZWave will see is a “node event” that does not specify which of the buttons was pressed, and so it is not terribly useful. It also does not allow triggering a button specific automation or script in Home Assistant.
Therefore, the next step is to change the Scene ID numbers that the buttons produce. This is done using the Z-Wave SCENE_CONTROLLER_CONF command class. Currently, this is not possible in Home Assistant’s Z-Wave Configuration panel. It might be possible in OpenZWave’s Control Panel, but I took the shortcut of using Z-Way.
Zone controller’s SCENE_CONTROLLER_CONF factory programming:
Group
Scene ID
Description
1
1
Button 1 Left (On)
2
2
Button 2 Left (On)
3
3
Button 3 Left (On)
4
4
Button 4 Left (On)
5
None
6
None
7
None
8
None
Zone controller’s SCENE_CONTROLLER_CONF modified programming:
Group
Scene ID
Description
1
21
Button 1 Left (On)
2
22
Button 2 Left (On)
3
23
Button 3 Left (On)
4
24
Button 4 Left (On)
5
25
Button 1 Right (Off)
6
26
Button 2 Right (Off)
7
27
Button 3 Right (Off)
8
28
Button 4 Right (Off)
9
None
Magically, the zone controller will now send out Scene IDs for the right side of the buttons. The “all off” is no longer emitted. The “off” side of the buttons can now be used for automation triggers in Home Assistant, for example:
    - action: []
      alias: Controller Button 4 Off
      condition: []
      - event_data:
          entity_id: zwave.scene_controller_5
          scene_id: 28
        event_type: zwave.scene_activated
        platform: event
The next step is to go into the configuration for each “directly” associated device and change the Z-Wave SCENE_ACTUATOR_CONF to do the right thing.
For example, to turn on the light with Node ID 15 when the left side of button 3 is pressed on controller 5:
For device node ID 15, change SCENE_ACTUATOR_CONF and set Scene ID 28, Level 255, Duration 0, Level used 128.
Note that not all devices support SCENE_ACTUATOR_CONF, and in those cases a Home Assistant action can be created such as the following:
- action:
  - data:
      entity_id: light.node004_level
    service: light.turn_on
  alias: Controller Button 3 On
  condition: []
  - event_data:
      scene_id: 23
    platform: event
Using actions vs. directly controlled devices has the downside of potentially incurring a delay. The delay is small but may be noticeable enough to be irritating.
Troubleshooting
In an ideal world, all Z-Wave devices would interoperate. In the real world, devices are buggy, support different parts and revisions of the specification, and sometimes just don’t work well. For those who can afford it, using Z-Wave Plus devices exclusively helps. Z-Wave Plus is by no means perfect, but better. For those who have legacy devices (which may at some point have cost quite a bit), the following may help.
Symptom
Cause
Solution
Device does nothing when zone controller button pressed
Wrong Scene ID sent, or Scene ID not configured in device, or scene does not tell the device a light level
Program Scene IDs properly, and ensure the device knows what to do with the scene
Device does not support scenes
Use light.turn_on/off or switch.turn_on/off in automation action
Home Assistant state does not change when light or switch turns on/off
Device does not report changed state
For Aeon Labs dimmers and switches, enable the Z-Wave HAIL using COMMAND_CLASS_CONFIGURATION, parameter 80, value 1
Force a refresh in Home Assistant either by repeating the action from Home Assistant (issue service switch/light.turn_on/off) or by a call to service zwave.node_refresh
Zone controller LEDs do not indicate controlled device state
Lights must be set and cleared using manufacturer proprietary commands, currently not supported by Home Assistant
None - Contribute to or wait for software upgrade
Bonus: When toggling button on controlled outlet, Home Assistant state does not change
Device sends out a NIF (Node Information Frame), but OpenZWave/Home Assistant ignores it
None - Contribute to or wait for software upgrade (Z-Way has the user contributed NIFFLER)
Hi Robert,
I have two VRCZ4-M0Zs installed, and almost exclusively Zigbee (Philips Hue) bulbs in my network. I’ve already developed code to respond to “Manufacturer Proprietary” commands from my first VRCZ4, and it’s all working beautifully. On installing my second VRCZ4, though, I find that it’s behaving just like the first one except that it’s not generating of those Manufacturer Proprietary (command 9100, or 0x91) commands that include the button-press number.
Any chance you’ve come across how to enable/activate these messages? (I’m thinking perhaps I did it somehow inadvertently while discovering the first unit…)
Hi All,
I just started with Home Assistant and Z-Wave recently and have my network setup with 34 devices and working decently. I wanted to add the 4 VRCZ4-M0Z I have to my network (they are currently connected to my Vera) and was expecting them to send zwave.scene_activated events just like my MiniMotes, but they don’t even just for the left side buttons. I’ve reset a controller multiple times and still get the same thing; none of the ZWave events generated help me. I don’t have access to ZWay so can’t reprogram the controller that way. I’m not versed in OpenZWave Control Panel or Zensys-tools, but anyone know if I could use either of those tools to send raw commands to the controller to get it to send scene activated events? Interestingly enough, my Vera works flawlessly with the controllers so I suspect they have some magic sauce.
Thanks!
I hate to reply to myself, but I spent the last several days trying to figure this out. I did figure out how to reprogram the VRCZ4-M0Z using the Z-Wave PC Controller that is part of the Z-Wave SDK. I didn’t use the SCENE_ACTUATOR_CONF commands, just the SCENE_CONTROLLER_CONF commands and re-used the scene IDs across controller as I can distinguish between controllers in HA. For buttons that I want to control lights directly, I don’t set the SCENE_CONTROLLER_CONF, just set an ASSOCIATION to the device.
Full instructions can be found on my blog.
When configuring direct control of zwave devices, my experience is that you have to remove the zwave controller (device 1) from the setup in the scene controller and only keep the switches you want to control. When I leave the zwave controller, and I use the dimmer controls, it causes the remote-controlled switch to hang, and I need to pull the air-gap to restart it.
@sgruby Thank you for such a detailed blog post. I learned a lot.
When this scene controller is properly configured. How does it show up in Home Assistant? Should I see the device by name in the Z Wave panel? Will I see the individual scenes in the entities panel?
Thanks.
Not much will show up in Home Assistant. The controller will show up as a Node in Home Assistant, but you won’t see scenes. I use Node-RED for everything so I watch for zwave.scene_activated events and then the scene ID is embedded in the event.
Hopefully that helps.
Screen Shot 2020-03-25 at 3.35.18 PM
Thank you for the quick reply. It is definitely helpful.
Forgot to ask. Are you able to use last row of up/down buttons on the controller? I didn’t see you mention reprogramming them in the blog.
I think the bottom buttons are to control dimming on a light. Since none of the switches I’m controlling with the controller are dimmable, I just ignore them.
@sgruby Thanks to your posts/blog, I now have my scene controller in Home Assistant. I am having a few issues with assigning groups etc.
In your blog, you note that each button’s on/off corresponds to a unique group 1-8 that can then be assigned using the Windows Z-wave Controller software to independent scene_ids. I have tried multiple times but it appears I can only assign scenes to 4 assignable groups (and only 4 groups show up in HA unless I manually modify the zwcfg*.xml file)
When I click each button (either side) I get alternating events (multiple duplicate entries) in OZW_Log.txt
Node003, Received Scene Activation set from node 3: scene id=5 now. Sending event notification.
(Note: scene_id five was the proper scene I assigned to the group) followed by (on the next press)
Node003, Received Basic set from node 3: level=0. Sending event notification.
I have seen other posts noting this behavior. Basically this completely limits the functionality of the controller as the Basic set node_event does not include any way to identify which physical button it came from.
How many groups do you see in Home Assistant?
Is it possible I am missing something? Are you certain you were able to assign 8 groups to 8 separate scenes?
Thank you in advance for your help.
I think you’re confusing groups (or maybe I was). The groups in HA are only for other ZWave devices that have associations. If you aren’t using associations, ignore the groups in the Z Wave configuration of HA. For associations, each group corresponds to a button.
I suspect the reason you’re getting the same scene id for both sides of the switch is that in the Z-Wave Controller software, you didn’t properly set the scene id. On step 29 of my post, did you verify that you’re getting the right scene ID? You should do that before dealing with HA. By doing this before HA, you’ll be able to troubleshoot better.
In any case, this is what I see in my OZW_Log.txt file. You can see the scene Ids are different for the left and right press of the second button on my controller.
Let me know what you see in the log on the Z-Wave Controller software when you push the buttons.
2020-04-01 12:46:33.471 Info, Node074, Received Scene Activation set from node 74: scene id=3 now. Sending event notification.
2020-04-01 12:46:40.930 Info, Node074, Received Scene Activation set from node 74: scene id=4 now. Sending event notification.
Yeah, at least with this method, I seem to only be able to assign scenes to groups 1-4. The rest seem to go through but do not give me Received Scene Activation set fromRx SCENE_ACTIVATION_SET(2B 01) + 07 00 and only give me Rx BASIC_SET (2B 01) + 00
I am using what I though was a rebadged version of this switch. Monster ML IWC600 https://www.ebay.com/c/1200008019 (it even says leviton in the metal frame). So perhaps, they have different programming.
If it’s possible for you to check. What do you see for total groups when you click the Associations icon (directly under Command Classes) in Windows Zwave?
Is it possible to use any other software to reprogram these to fire different events etc?
Thanks again for all of your help.
Thanks for the link to the device you have. While it may be a rebadged Leviton, it is a Scene controller and not a Zone controller. My devices are zone controllers which apparently behave differently than the device you have. When I did the research on what to purchase years ago, I believe that the Zone controllers (Leviton makes Scene controllers as well) sent distinct on/off messages, i.e. separate scenes for the left and right presses whereas the Scene controllers didn’t.
You’re stuck with what the controller can do and other programming software isn’t going to help. You might consider recording the “state” of the switch and have a toggle in HA and trigger off that.
Thanks again you all of your help. Wow, I can’t believe I overlooked the difference between Zone and Scene controllers.
As of right now, it looks like I’m out of luck with the scene controller option. I’m able to detect the “off” via the Basic Set using Zwave.node_event however it does not provide any info of the ID of the physical button that pressed it. Looking at the OZW code it references a Value_ID that should be sent but I don’t see it in HA or log. I checked by following the event in the Developer Options and even doing a diff of the OZW_log.txt with both button presses .I was hoping I could grep the difference to determine the button.
If anyone else has a breakthrough using scene controllers, please update this thread. For now, I ordered a Zone Controller and hopeful I can get the functionality I am looking for.
The only reason you would need to remove the hub from the list, is if the Leviton controller doesn’t receive the proper scene report that allows it to check the next device.
The Leviton controller is a really simple device. It iterates through devices associated in the order that they are stored in the device. Off the top of my head, I believe the order is Activate and then get actuator ( which needs to be followed up with a report). The activation is multicast ( so devices near to it will see it twice ( broadcast/multicast… I can’t remember at the moment which one they call it )).
If any devices doesn’t respond with the correct report it hangs.
You can keep your hub associated with other devices in a single group on the Leviton controller, as long you make sure the hub responds to the scene get message.
Hi Michael
Did you have any success with “Manufacturer Proprietary” commands for the VRCZs?
I’m looking for help regarding LED control and button press
thanks
I did – or rather, I found an alternate command pattern to obviate the need for them. Check my latest code versions at the SmartThings community site
I’ve figured out direct associations and have that all working fine, but is there any way to change the LEDs from within HA for a VRCS4? My automation kills the lights at night but the scene stays activated so the LEDs stay on, and you had to double press the button to turn them back on the next day (one to deactivate and one to activate).
I wanted to add my 2c. I spent some time this weekend trying to get an old Leviton VRCS4-M0 working. Instead of jumping through a lot of hoops I decided to go via the Node-Red route. It seems you can listen to zwave_js_value_notification events from the events:all node. Then it’s a matter of using a switch to filter traffic for the device you care about on payload.event.node_id or payload.event.device then filter for each button press with another switch on payload.event.value to work out which button is pressed.
Edit: I re-read the post and overlooked the complexity that went into making the 4 buttons back into 8. I’ll leave my comment in case it helps someone.
