- Use a IKEA Tradfri on/off remote to turn on/off or dim a light
- Light dimming should be smoother compared to other blueprints
- Works with ZHA
So I tried the one from Awesome HA Blueprints but thought the dimming experience wasn’t that smooth. Then I tried ControllerX which did make things way more smooth, however I really like having all my config in one place and rely less on external tools.
So as a fun proof-of-concept I created this blueprint that uses the transition feature instead of multiple calls to increase/decrease the brightness. In short:
- When you start holding the button down a transition towards full/zero brightness starts
- When you release the button it cancels the transition by sending a guesstimate of what the current brightness should be, based on how long you held the button down and how fast you want the dimming to be
To my surprise it works fairly well and so far my dimming experience has been smooth
Enough talking, you can get the blueprint from GitHub Gists or down below:
blueprint:
name: IKEA E1743 Trådfri on/off switch (ZHA)
description: Dim or turn on/off a light using the IKEA Trådfri E1743 switch remote. Works with ZHA.
author: oscarb
source_url: https://gist.github.com/oscarb/1e295b636d27559aa6c4d45c9ccd24ae
domain: automation
input:
light:
description: Entiy ID of light to control
selector:
entity:
filter:
domain: light
multiple: false
remote:
name: Trådfri on/off switch
description: The IKEA Trådfri on/off switch remote to use
selector:
device:
filter:
integration: zha
manufacturer: IKEA of Sweden
model: TRADFRI on/off switch
multiple: false
fade_speed:
description: The speed used for dimming the light )brightness steps per second)
default: 80
selector:
number:
min: 1
max: 255
unit_of_measurement: brightness steps/second
default_brightness:
name: Default brightness
description: The brightness to set when turning on the light
default: 128
selector:
number:
min: 1
max: 255
mode: restart
max_exceeded: silent
variables:
input_light: !input light
fade_speed: !input fade_speed
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- choose:
- conditions: "{{ trigger.event.data.command == 'on' }}"
sequence:
- service: light.turn_on
entity_id: !input light
brightness: !input default_brightness
- conditions: "{{ trigger.event.data.command == 'off' }}"
sequence:
- service: light.turn_off
- conditions: "{{ trigger.event.data.command in ['move', 'move_with_on_off'] }}"
sequence:
- alias: Set up variables
variables:
brightness_from: "{{ state_attr(input_light, 'brightness') | int(0) }}"
brightness_target: "{{ 0 if trigger.event.data.command == 'move' else 255 }}"
brightness_delta: "{{ (brightness_target - brightness_from) | abs }}"
brightness_direction: "{{ -1 if trigger.event.data.command == 'move' else 1 }}"
transition_time: "{{ brightness_delta / fade_speed }}"
transition: "{{ transition_time }}"
brightness: "{{ brightness_target }}"
- wait_for_trigger:
- platform: event
event_data:
command: stop_with_on_off
timeout: "{{ transition_time }}"
continue_on_timeout: false
- alias: Estimate current brightness
variables:
brightness_current: >
{{ brightness_from +
brightness_direction * fade_speed * (wait.trigger.event.time_fired - trigger.event.time_fired).total_seconds()
brightness: "{{ brightness_current }}"
