IKEA FÖRNUFTIG in Home-Assistant
SIBA 1A SMD fuse 6.1x2.6mm
Wemos-d1-mini
ROT-1A/B or KY-040 (it’s quite cheap and popular, sold with different names)
DSN-1504-3A buck converter
JST-XH 2 and 4 pin connectors (standard 2.5mm)
Thx, any recommendations on where to get them?
I got the PCB’s and built my version.
(Many thanks for building and sharing the layout !!!)
I had trouble with the GPIO picking up a reliable signal (don’t have the pins decoupled due to lack of caps).
Also, the state of the fan was not always clear/obvious to me. So I made a variation using the rotary encoder component instead.
here is my yaml
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Fornuftig-AP"
    password: ""
captive_portal:
globals:
  - id: fan_speed
    type: int
    restore_value: yes
    initial_value: "0"
  - id: speed_0
    type: int
    restore_value: yes
    initial_value: "0"
  - id: speed_1
    type: int
    restore_value: yes
    initial_value: "33"
  - id: speed_2
    type: int
    restore_value: yes
    initial_value: "66"
  - id: speed_3
    type: int
    restore_value: yes
    initial_value: "100"
switch:
  - platform: restart
    name: "$friendly_name - Power consumption"
    device_class: power
    state_class: measurement
    unit_of_measurement: "W"
    accuracy_decimals: 1
    update_interval: 30s
  - platform: integration
    name: "$friendly_name - Consumed Energy"
    sensor: fonuftig_power_consumption
    time_unit: "h"
    device_class: energy
    state_class: total_increasing
    unit_of_measurement: "Wh"
    restore: false
    integration_method: left
  - platform: pulse_counter
    pin:
      # Fan - FG
      number: D2
      mode: INPUT_PULLUP
    unit_of_measurement: "RPM"
    accuracy_decimals: 0
    filters:
      - multiply: 0.1
    filters:
      - multiply: 3
      - lambda: |-
          if (id(fornuftig_fan).state){
            if(x > 300) { // limit max frequency
              return 300;
            } else if(x < 36 && x > 3) { // limit low frequency
              return 36;
            } else if(x <= 3) {
              return 0;
            } else {
              return x;
          } else {
            return 0;
    on_value:
      then:
        - output.esp8266_pwm.set_frequency:
            frequency: !lambda "return int(x);"
        - logger.log: "on_value called"
        - lambda: |-
            // send current status to homeassistant
            if(x) {
              auto call = id(fornuftig_fan).turn_on();
              call.set_speed(int(x)/3);
              call.perform();
            } else {
              auto call = id(fornuftig_fan).turn_off();
              call.perform();
        - sensor.template.publish:
            state: !lambda "return int(15*(id(my_rotary_encoder).state)/100);"
  - platform: rotary_encoder
    min_value: 0
    max_value: 100
    publish_initial_value: true
    restore_mode: ALWAYS_ZERO
    pin_a: # clk
      number: D5
      inverted: true
      mode:
        input: true
        pullup: true
    pin_b: # DT
      number: D6
      inverted: true
      mode:
        input: true
        pullup: true
    on_clockwise:
      then:
        - light.turn_on:
        - logger.log:
            format: "rotary sensor state was: %.1f"
            args: ["id(my_rotary_encoder).state"]
        - lambda: |-
            if (id(my_rotary_encoder).state < id(speed_1)) {
              // set rotary to speed1, turn on fan
              id(my_rotary_encoder).set_value(id(speed_1));
              id(status_led).turn_on();
            } else if (id(my_rotary_encoder).state < id(speed_2) && id(my_rotary_encoder).state > id(speed_0) && id(my_rotary_encoder).state < id(speed_3)) {
              // set rotary to speed2
              id(my_rotary_encoder).set_value(id(speed_2));
            } else if (id(my_rotary_encoder).state < id(speed_3) && id(my_rotary_encoder).state > id(speed_1) && id(my_rotary_encoder).state > id(speed_0)) {
              id(my_rotary_encoder).set_value(id(speed_3));
            } else {
              // do nothing;
        # trigger set fan speed
        - fan.turn_on:
            speed: !lambda "return int(id(my_rotary_encoder).state);"
        - logger.log:
            format: "rotary sensor state set to: %.1f"
    on_anticlockwise:
      then:
        - logger.log:
        - lambda: |-
            if (id(my_rotary_encoder).state > id(speed_2)) {
            } else if (id(my_rotary_encoder).state > id(speed_1) && id(my_rotary_encoder).state < id(speed_3) && id(my_rotary_encoder).state > id(speed_0)) {
            } else if (id(my_rotary_encoder).state > id(speed_0)  && id(my_rotary_encoder).state < id(speed_1)) {
              // set rotary to speed0; turn fan & led off
            } else {
              // do nothing;
        - fan.turn_on:
        - logger.log:
binary_sensor:
  - platform: gpio
    # SW
    pin:
      number: D7
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on_off: 100ms
    on_press:
      then:
        if:
          condition:
            and:
              - fan.is_off: fornuftig_fan
              - light.is_off: status_led
          then:
            - fan.turn_on:
                speed: !lambda "return id(speed_1);"
            - light.turn_on:
            - sensor.rotary_encoder.set_value:
                value: !lambda 'return id(speed_1);'
          else:
            - fan.turn_off:
            - light.turn_off:
            - logger.log: "SW - pin_c - Turned Off"
                value: !lambda "return id(speed_0);"
                state: !lambda "return int(0);"
light:
  - platform: binary
    output: light_output
output:
  - id: light_output
    platform: gpio
    pin: D3
  - platform: esp8266_pwm
    # Fan CLK
    pin: D1
    frequency: 150 Hz
    min_power: 0.5
    max_power: 0.5
    zero_means_zero: true
fan:
  - platform: speed
    output: pwm_output
    name: "Fornuftig Air Purifier"
    restore_mode: RESTORE_DEFAULT_OFF
    on_speed_set:
      - lambda: |-
          if(id(fornuftig_fan).speed != id(fan_speed) && id(fornuftig_fan).state){
           id(fan_speed) = id(fornuftig_fan).speed;
           id(set_fan_freq).publish_state(id(fornuftig_fan).speed);
    on_turn_on:
      - lambda: |-
          id(my_rotary_encoder).publish_state(id(fornuftig_fan).speed);
      - light.turn_on:
    on_turn_off:
          frequency: !lambda "return int(0);"
      - lambda: |-
          id(my_rotary_encoder).publish_state(id(speed_0));
      - light.turn_off:
      - logger.log: "Fan Turned Off!"
I modified the version from [0xDE4DBEEF], combined the very early version for the power calculations.
I also salvaged the LED from the original board and used it as a status light to show that the fan is actually turned on.
The functionality is as follows:
push the knob:
  • switch fan on, speed lvl (1)
  • switch fan off
set speed:
  • Turn knob clockwise: increase speed lvl (1-2-3)
  • Turn knob counter clockwise: decrease speed lvl (3-2-1)
It’s likely that the script can use some improvements :wink: - still an early adopter of HA.
Let me know if you have any suggestions or improvements.
buck converter:
rotary:
fuse (not sure if these are the right ones):
FYI, atm, its missing the sync of the LED and rotary state, if you control the device through HA
that should be taken care of, for now… updated the fan block in the code above.
IKEA has a new air purifier called Uppatvind. I created a project for it. You can check the details if you are interested in.
IKEA Uppatvind Air Purifier - Share your Projects! - Home Assistant Community (home-assistant.io)
Thank you for sharing PCB and template, it works really great !
@horvathgergo has released a new v2 board that now comes with a rotary switch. Great work :clap: :clap: :clap: !
The project currently uses micropython to integrate w/ HA. I’m still learning esphome and don’t know much about micropython. Would the esphome yaml file by @mcruiser work with this latest board? It’s unclear in my mind if the v2 board is using the approach that mcruiser used to add the rotary switch.
@horvathgergo Great stuff! Used your Gerber file to order and assemble the board. Can’t wait!
The position of that voltage regulator is a bit weird but i’m pretty sure that the manufacturer will fix it in the review phase.
Very sharp of you! Didn’t even notice before, even after triple checking. And yes, JLCPB corrected it perfectly.
Hi! Did you already check whether you could get this to work with esphome?
Got it to work more easily then I thought. I just changed the GPIO PIN’s from one of the previously shared esphome configuration… @horvathgergo I can turn on and turn off the purifier and select the fan speed from 0 to 100%. Als the knob is working correctly. Could you please check if the below will not negatively affect the used parts of your v2 board?
output:
    pin: 5
    frequency: 150 Hz
    min_power: 0.5
    max_power: 0.5
fan:
  - platform: speed
    output: pwm_output
    on_speed_set:
      lambda: |-
    on_turn_on:
      lambda: |-
    on_turn_off:
          frequency: !lambda 'return int(0);'
    pin:
      number: 4
      mode: INPUT_PULLUP
    unit_of_measurement: 'RPM'
    filters:
      - multiply: 0.1
    filters:
      - multiply: 3
      - lambda: |-
              return 300;
              return 36;
            } else if(x <= 3) {
              return 0;
            } else {
              return x;
          } else {
            return 0;
    on_value:
      then:
            frequency: !lambda 'return int(x);'
        - lambda: |-
            if(x) {
              call.perform();
            } else {
              call.perform();
binary_sensor:
    filters:
      - delayed_on_off: 300ms
    lambda: |-
      if (!id(knob_1).state && !id(knob_2).state && !id(knob_3).state) {
        return true;
      } else {
        return false;
    on_press:
      lambda: |-
        if(!id(speed_0)){
          call.perform();
        }else{
          call.set_speed(id(speed_0));
          call.perform();
  - platform: gpio
    pin:
      number: 13
      mode: INPUT_PULLUP
      inverted: true
    filters:
    on_press:
      then:
        - fan.turn_on:
            speed: !lambda 'return id(speed_1);'
  - platform: gpio
    pin:
      number: 12
      mode: INPUT_PULLUP
      inverted: true
    filters:
    on_press:
      then:
        - fan.turn_on:
            speed: !lambda 'return id(speed_2);'
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: true
    filters:
    on_press:
      then:
        - fan.turn_on:
            speed: !lambda 'return id(speed_3);'
globals:
  - id: fan_speed
    type: int
    restore_value: yes
    initial_value: '0'
  - id: speed_0
    type: int
    restore_value: yes
    initial_value: '0'
  - id: speed_1
    type: int
    restore_value: yes
    initial_value: '33'
  - id: speed_2
    type: int
    restore_value: yes
    initial_value: '66'
  - id: speed_3
    type: int
    restore_value: yes
    initial_value: '100'
How could I get the v2-board ready to use? Is there any manufacuturer worldwide who can I sent the files to and get an assembled and soldered board from?
Yes. There are many of them. I used this one as it was the easiest (and relatively cheap): https://jlcpcb.com/
คุณช่วยแชร์วิธีสั่งได้ไหมครับ ขอบคุคณครับ
Can you please translate that to English, thank you.
Looking to order this from JLC too. Is there a way I can only get one board printer and assembled?
Ordered two from JLC and they work great, thanks @horvathgergo
Anyone know if it’s possible to source a replacement board? I managed to brick mine while trying to power a wifi relay from the 5v on the board, probably shorted something (noob)
Edit: to specify – I meant the original Förnuftig board :slight_smile:
