Hi!
Would you share some more details on this?
- Was it hard to set up?
- How do you add devices?
- Is it push or pull?
- How does it work with remotes?
/R
Hi!
/R
It was easy, itâs an add on to RPi (2 and 3). One thing, it needs to have X windows.
I add devices to the system by accessing a webpage (internet, not a cloud system) and press open zigbee network. And then it shows in the Hass.
Unfortunately I donât know if it push or pull,
I can add a remote but you can only turn on/off the lights and dim. You canât use the arrow remote for letâs say change scen.
Ok, thanks! Did you also try going the Zigbee lights component way?
/R
Zigbee light component when adding the remote?
I did everyway that was possible
I meant as an alternative to using deconz at all.
Sorry, no I havenât tried that.
If you try it out please post your findings
Got this answer from Lightify customer service:
Dear Johan,
thank you for your reply and info, we will forward the info to the manager.
Kind regards,
NicoYour LIGHTIFY Support-Team
It seems like IKEA is going to have their own Gateway device for around 200-300 SEK, on their homepage they are stating that it will be released 2017-03-31, but when contacting the support they say it is going to be delayed.
I have been trying to find the app for controlling the gateway on the play store (its going to be named TrÄdfri) to se if we can reverse engineer it.
But i guess they wont publish it there before they release the gateway.
There are PDF manuals available on the Ikea site
I only skimmed the content, do they contain anything of use?
No not much info at all.
Here is the main one:
One letdown is För att anvÀnda gatewayen behöver du en internetuppkoppling.
and that means you will have to be connected to the internet for the gateway to work, so if we are unlucky its just a dum box that is controlled from some server on the internetâŠ
Or that it is dependant on the cloadservice being provided by IKEA?
@Kimpan that is what i meant, a cloud service still has to run one or multiple servers .
According the âunnamed deviceâ-problem, today Osram released a new version of its iPhone app, and then the Ikea bulb showed up. Although with a warning sign and I was unable to interact with it. But it shows up. One small step.
âDevice 01â in screen shot.
Hi
Can i manage IKEA Smart light with Philips Hue hub and HA?
IKEA launches its own low-cost smart lighting range
Sweet. Iâll be off to Wembley Ikea to have a look sometime soon.
Actually Iâll hold off for a while. Despite that Engadget article statinf uk launch none of the products are on ikea uk website yetâŠ
