Improved Shopping List Card
v1.2.0-BETA-8 has been released
:sparkles: Implemented EAN Code Reader
This feature currently supports EAN-13 barcodes, limited to food products only.
The reason is simple — there is no free global EAN database available, except for the Open Food Facts project:
:link: https://world.openfoodfacts.org
In the future, I might add support for a local EAN list (similar to the local categories or local chips feature).
How to use
The feature is automatically triggered when:
  • an EAN-13 barcode is scanned using the camera, or
  • an EAN-13 number is entered manually into the input field.
You can test it by entering this example code: 4337256383165
:spiral_calendar: Added ToDo Mode
The new ToDo Mode transforms the Home Assistant ToDo list into a kind of task manager with recurring due date functionality.
Key features include:
  • Set recurring due dates and due times for each item.
  • Automatic calculation and display of remaining time until due, with intuitive formatting (e.g., days & hours, months & days).
  • Flexible options when marking tasks complete, such as removing the due date or scheduling the next due date based on custom intervals.
  • Visual indicators for upcoming or overdue tasks with configurable warning thresholds (currently only via YAML, see below).
  • Streamlined UI without quantity input or export buttons, optimized specifically for task management.
List View:
Edit Mode:
Acknowledge an item:
Configuration of Warning Thresholds for ToDo Due Dates
In ToDo Mode, you can configure when upcoming tasks are visually marked as “due soon” based on configurable warning thresholds. These thresholds are defined in minutes and differ depending on the type of interval or due date format:
Configuration Parameter Description Default Value (Minutes)
todo_yellow_m Warning threshold for intervals in months 1440 (24 hours)
todo_yellow_d Warning threshold for intervals in days 120 (2 hours)
todo_yellow_h Warning threshold for intervals in hours 10 (10 minutes)
todo_yellow_s Warning threshold for due dates without time 120 (2 hours)
If the remaining time until the due date is within the configured threshold, the task will be highlighted in orange to remind you in time.
Example Configuration
todo_yellow_m: 2880  # 2 days (in minutes) for monthly intervals
todo_yellow_d: 240   # 4 hours for daily intervals
todo_yellow_h: 15    # 15 minutes for hourly intervals
todo_yellow_s: 60    # 1 hour for dates without time
v2.0.0 has been released - Final Version
Changes since last BETA
  • Added a general category for all items without a category. Now you can also collapse these items.
  • In ToDo mode, the number of items shown for each category is now inverted. The number before the ‘/’ only counts entries that are not yet due. (Example: 3/5 means that out of 5 entries, 3 are still pending.) This way, when you see (5/5), you know there are currently no tasks left to do.
For all other changes from v1.0.0 to 2.0.0, please refer to the release notes:
It’s too much to post here. :wink:
v2.1.0 has been released
  • Added collapsible configuration sections in the Config Editor
  • Added option to set a title for the card
  • Added font size option for the title
  • Added icon option for the title
  • Clicking on the title now collapses/expands the entire card
    grafik
  • Added option to show/hide the exclamation mark (Todo Mode)
  • Exclamation mark for due items is now also shown in the title (Todo Mode)
  • Warning thresholds for ToDo due dates are now available in the GUI editor
  • Implemented local EAN file support (formats: EAN-8, UPC (12), EAN-13, and GS1-14)
You might also need to add the www folder (or your specific folder) to the allowlist_external_dirs in your configuration.yaml and restart Home Assistant afterwards:
# Loads default set of integrations. Do not remove.
default_config:
# add your path to the file here
homeassistant:
  allowlist_external_dirs:
    - "/config/www/"
  • Added Copy / Paste buttons
If you press the copy button, the current date, time, and interval will be saved to local storage (browser). You can then use the paste button to quickly apply these settings to a new entry or update an existing one.
v2.2.0-BETA-1 has been released
Implemented Dynamic Categories
Dynamic categories make it possible to assign items to categories that are not predefined, even from outside the card (e.g., through automations in the format: @Category@ Item). Additionally, new categories can be created when adding items through the card. These categories remain available until the last item in the category has been removed.
Due to the implementation of dynamic categories, the category merge mode has been reworked. There are many new options available to choose how local, global, and dynamic categories should be merged. 'local_only' shows only the locally defined categories, 'global_only' shows only the global categories, and 'dynamic_only' shows only the dynamic categories. All other options combine two or all three types in different ways.
The priority in which categories are merged follows the order in which they appear, from left to right. At first, it may look overloaded and some options might seem duplicated, but in the background this only happens if you don’t have overlapping categories.
For example, if you have the category “Vegetables” both in the local and global categories, the merge order matters. If “Vegetables” is red in the local category and green in the global category, then in the mode Local → Global the color will be red, while in Global → Local it will be green.
Additionally, there are different options to sort the merged categories. You can sort each block (global/local/dynamic) by name, or you can sort all categories together. And of course, there is also an option without sorting, meaning that the categories will be displayed as defined in the config editor, the text file for the global categories, and as detected in the items for dynamic categories.
Dont forget to enable dynamic categories AND change the merge mode for categories to use this feature.
Add an item to a dynamic category
Here you can see the dynamic category
If you add another item, you have to option to chose the earlier created dynamic category
New Options for ToDo Mode
  • Option to show/hide the title info about the next due item
    Displays the next due date of all items from all categories under the title when in ToDo mode, provided a title is set.
    Expired items are not shown here; they are indicated by an exclamation mark to the right of the name.
  • Option to show/hide the title info icon
    Displays a calendar icon before the due date as a visual highlight.
  • Option to show the next due date inside a category
    If this option is enabled, the next due date will be displayed under the category name in ToDo mode.
    This allows you to see at a glance when the next item in that category is due.
  • Option to show/hide the title exclamation mark (ToDo only)
New Options for Chips
  • option to hide the chips
  • option to show chips in the color of the category (the item must be part of a defined local or global category)
    If a chip is assigned as an ‘item’ to a category and that category has a defined color, the chip will be displayed in that color.
    The color priority order is: Highlight → Category → Global → Standard → Browser.
General Options
  • option to show the input mask at top / bottom
  • clear all button now also works in ToDo mode
General Category Options
  • option to show the category icon larger (approx. 2x)
    If the next due date is displayed, this option allows enlarging the icon so that it fits visually better.
New Options Overview
Parameter Type Description Default
show_title_info Boolean Option to show the next due date info under the title in ToDo mode true
show_title_info_icon Boolean Displays a calendar icon before the due date as a visual highlight true
show_title_exclamation_mark Boolean Shows an exclamation mark next to the title for due items (ToDo mode only) true
input_row_position String Position of the input mask (top or bottom) "top"
chips_with_cat_color Boolean Shows chips in the color of the assigned category true
show_cat_next_due Boolean Shows the next due date below the category name in ToDo mode true
cat_double_sized_icon Boolean Enlarges the icon when the next due date is displayed to better fit visually true
show_cat_exclamation_mark Boolean Shows an exclamation mark on the category for due items true
allow_dynamic_categories Boolean Allows the use of dynamic categories false
category_merge_mode String Defines how local, global, and dynamic categories are merged "local_only"
category_merge_mode Options
Mode Description
local_only Show only locally defined categories
standard_only (old) Only standard categories
global_only Show only global categories
dynamic_only Show only dynamic categories
local_only_sorted Local categories, sorted alphabetically
global_only_sorted Global categories, sorted alphabetically
dynamic_only_sorted Dynamic categories, sorted alphabetically
local_global Combine local + global categories (order matters)
local_first (old) Local first, then global
local_dynamic Combine local + dynamic categories
global_dynamic Combine global + dynamic categories
global_local Combine global + local categories (order matters)
global_first (old) Global first, then local
dynamic_local Combine dynamic + local categories
dynamic_global Combine dynamic + global categories
local_global_sorted Local + global categories, sorted alphabetically
local_dynamic_sorted Local + dynamic categories, sorted alphabetically
global_dynamic_sorted Global + dynamic categories, sorted alphabetically
global_local_sorted Global + local categories, sorted alphabetically
dynamic_local_sorted Dynamic + local categories, sorted alphabetically
dynamic_global_sorted Dynamic + global categories, sorted alphabetically
local_global_sorted_total Local + global categories, alphabetically sorted and merged
global_combined (old) Global categories merged
local_dynamic_sorted_total Local + dynamic categories, alphabetically sorted and merged
global_dynamic_sorted_total Global + dynamic categories, alphabetically sorted and merged
global_local_sorted_total Global + local categories, alphabetically sorted and merged
dynamic_local_sorted_total Dynamic + local categories, alphabetically sorted and merged
dynamic_global_sorted_total Dynamic + global categories, alphabetically sorted and merged
local_global_dynamic Combine local + global + dynamic categories
local_dynamic_global Combine local + dynamic + global categories
global_local_dynamic Combine global + local + dynamic categories
global_dynamic_local Combine global + dynamic + local categories
dynamic_local_global Combine dynamic + local + global categories
dynamic_global_local Combine dynamic + global + local categories
local_global_dynamic_sorted Combine local + global + dynamic categories, sorted alphabetically
local_dynamic_global_sorted Combine local + dynamic + global categories, sorted alphabetically
global_local_dynamic_sorted Combine global + local + dynamic categories, sorted alphabetically
global_dynamic_local_sorted Combine global + dynamic + local categories, sorted alphabetically
dynamic_local_global_sorted Combine dynamic + local + global categories, sorted alphabetically
dynamic_global_local_sorted Combine dynamic + global + local categories, sorted alphabetically
local_global_dynamic_sorted_total Combine local + global + dynamic categories, sorted and merged
local_dynamic_global_sorted_total Combine local + dynamic + global categories, sorted and merged
global_local_dynamic_sorted_total Combine global + local + dynamic categories, sorted and merged
global_dynamic_local_sorted_total Combine global + dynamic + local categories, sorted and merged
dynamic_local_global_sorted_total Combine dynamic + local + global categories, sorted and merged
dynamic_global_local_sorted_total Combine dynamic + global + local categories, sorted and merged
v2.2.0-BETA-2 has been released
Implemented Admin Options
With this new option, you can easily copy changes from your list to the configuration section.
Simply click the Copy button to transfer the content of the text area to your clipboard.
Inside the configuration editor, use your device’s paste function to insert the content into the configuration field.
Position of the Admin Button
Option in the Config Editor
Admin Options
Dynamic Categories – Include Items
If you check this checkbox, the assigned items of the dynamic category will also be included in the generated text area.
Use this function to copy the new categories—including their items—to your clipboard, then paste them into the defined local categories within the configuration editor.
Manual Assigned Items – Include Already Configured Items
If you check this checkbox, all items already assigned to a category (not only the changes) will be included in the generated text area.
Use this function to copy the complete updated configuration to your clipboard and replace the content of the categories section inside the configuration editor.
This seems very nice, but since being a noob, how do I implement this Improved shopping list? I have installed it, but where do I go now?
Never mind, forgot to restart HA. Now it shows up :grin: Thanks!
Is it possible to have my default chips or global chips with categories, so I won’t have to enter the category each time I push a chip?
Add the items in a category and it will get sorted by itself
Do you mean in the yaml code of the card or in a txt file with global chips?
Like this:
So I guess yaml code of the card.
Thanks a lot!
A great addition! I wish the author success.
If the project is still being supported, the following ideas may be useful:
  1. Add “auto-completion” of words (for example, filtering chips when entering the first letters).
  2. Color the chips by color according to the categories.
  3. Sometimes need to add grams instead of a quantity, a drop-down menu and a counter are not convenient in this case.
Regarding 3) we usually add them as item (500).
Not convenient but it works OK.
If you add these items as dishes or chips then it is easier. So you could have item (500) and item (1000) as two chips.
But we are using dishes for a lot of items. It has really made things easier.
Regarding 1 and 2. Sure. I agree with you.
And I recently noticed the card makes difference between tomatoes and Tomatoes and one of them goes in the uncategorized bin.
Perhaps add a |capitalize first word function-thingy?
I didn’t notice it right away, but the “Color the chips according to the categories” feature is implemented in v2.2.0-BETA-1
v2.2.0-BETA-6 has been released
there were some more BETA versions released not mentioned here, you can see the changelog here:
Bugfixes
  • In shopping list mode, check after 5 seconds if items are available; if not, trigger a refresh.
  • Fixed a bug with local chips where new chips were created if a chip already existed with different casing (e.g., “Tomatos” vs. “tomatos”).
@GrizzlY
2. and 3. were already answered by @Hellis81
Regarding 1.
Nice idea, let me think about this. Maybe this function will not be optimal on a mobile phone.
v2.2.0-BETA-8 released
Notification Functions implemented
This feature allows sending the shopping list or updates via notifications using configured notify entities in Home Assistant. Currently tested: Telegram, Email (via SMTP)
  • The message button lets users send the current list via the configured notify entity.
  • The notify entity must support HTML formatting for better readability.
  • SMTP notifications are handled separately via the SMTP notify platform name (notify_entity_smtp), not as a notify entity.
  • Notifications can be triggered automatically whenever items are added, edited, or removed.
  • You can choose to send either just the changed item or the entire list with each notification.
  • A delay timer can be configured to avoid notification flooding.
Button in the card:
grafik
General settings:
grafik
Notifications:
Parameter
Option Type Description
show_message_button Boolean Displays a message button in Shopping List mode to send the list via email, Telegram or similar.
notify_entity String The notify entity used when the message button is pressed. Must support HTML formatting. SMTP is not included here.
notify_on_change Boolean Enables automatic notification sending when an item is added, edited, or removed from the list.
notify_on_change_all Boolean Sends the entire list with each notification instead of just the changed item.
notify_on_change_time Integer (sec) Delays sending the notification by the specified number of seconds to avoid flooding notifications during rapid changes. Use 0 to disable the delay.
notify_entity_smtp String Name of the SMTP notify platform (from configuration.yaml) used for sending HTML email notifications (e.g., email_notification). Only the platform name, not the full entity like notify.email_notification.
I encountered the following problem and honestly spent the whole evening trying to solve it. Every time I refresh the page, all tasks with categories disappear.
Including in different browsers and on a mobile application
I tried:
  • different releases from 2.1.0 - 2.2.0 Beta 8
  • change category_merge_mode
  • сlearing the cache
  • turned on developer mode and read the debug log.
  • and, of course, restarting Home Assistant
in configuration.yaml
homeassistant:
    - "/config/www/"
in lovelace
title: shops
icon: mdi:store
path: shops
panel: true
cards:
  - type: horizontal-stack
    cards:
      - type: vertical-stack
        cards:
          - type: custom:ha-shopping-list-improved
            entity: todo.shopping_list
            category_file: /local/categories.txt
            category_merge_mode: global_combined
            # chips_position: bottom
            # quantity: end
            # acknowledged: end
            # mode: shopping
            # chip_click: single
            # chip_merge: global_combined
            # title: Список покупок
            # title_icon: mdi:store
            # show_plus_minus: true
            # #show_quantity_one: true
            # chips_width: 300
            # chip_file: /local/chips.txt
            # chips_with_cat_color: true
            # show_admin_button: true
            # list_reload_time: 30
        cards:
          - type: todo-list
in .\www\categories.txt
[Фрукты]
icon = mdi:apple
bgcolor = #28A745
items = Бананы, Яблоки, Груши, Апельсины, Мандарины
[Овощи]
icon = mdi:carrot
bgcolor = #20C997
items = Картошка, Кабачок, Морковь, Помидоры, Огурцы, Лук, Чеснок, Капуста, Свекла, Грибы, Шампиньоны
[Напитки]
icon = mdi:bottle-soda-outline
bgcolor = #FFC107
items = Сок, Соки, Кола
[Хозяйственные товары]
icon = mdi:cleaning
bgcolor = #6C757D
items = Салфетки, Полотенце бумажные, Средства для посуды, Моющие средства
[Мясо]
icon = mdi:food-steak
bgcolor = #DC3545
items = Свинина, Курица, Фарш, Ветчина, Колбаса, Сосиски
[Молочные продукты]
icon = mdi:milk
bgcolor = #17A2B8
items = Молоко, Молоко для йогурта, Йогурт, Сметана, Масло сливочное, Яйца куриные, Сыр, Творог
[Консервы и соусы]
icon = mdi:food-variant
bgcolor = #FD7E14
items = Кетчуп, Майонез, Горошек консервированный, Кукуруза консервированная, Солёные огурцы, Томатная паста
[Кот]
icon = mdi:cat
bgcolor = #495057
items = Корм коту, Наполнитель
[Бакалея]
icon = mdi:rice
bgcolor = #D4A017
items = Хлеб, Масло растительное, Сахар, Гречка, Рис, Макароны, Мука, Соль, Чай, Кофе, NAN 3
[Сладости и снеки]
icon = mdi:candy-outline
bgcolor = #E83E8C
items = Печенье детское, Вафли, Шоколад
Every сard refresh causes elements to disappear. If no elements are visible, switching to the native shopping list and back also helps.
GIF
ha-shopping-list-improved-compressed
Please help me with some advice on where to look.
@GrizzlY
Is there some output in the browser debug console (not in the Home Assistant log) below the version number ? And is the version v2.2.0-BETA-8 ?
grafik
For me it looks like that you are loosing your websocket connection for some reasons. I assume addblocker and all other blocking browser addons are disabled.
Normally, if you are forcing a reload of the page, it takes some seconds to load the list. If the list is not available on the first try, the card will check again in 10 seconds. During this time you should see a message instead of the items that the card is trying to load the list. (since BETA 7 or 8)
Lets try to localize the problem
Does it also happen if:
  • you only use local categories instead of the global categories (remove the path to the categories.txt and switch to local category only merge mode
  • you use the shoppinglist card without the horizontal and vertical stack card ?
Your animated gif is a bit hard to watch, at least for me :smiley:
Can you upload a video ? (With your mobile phone, no need for a complete screen capture) or at least a “slower” gif if video is not possible.
:tada: v2.2.0 Release
The year is coming to an end, and this is the perfect time to release v2.2.0 :fireworks:
There have been a lot of changes between v2.1.0 and v2.2.0 — too many to list them all in these release notes.
For full details, please read through the v2.2.0 BETA release notes:
:new_button: Additional Features (not mentioned in the BETA notes)
:label: Added Category Chips
Automatically generates chips based on items assigned to a category.
Each category is displayed as a collapsible chip, as long as the category contains at least one item.
Settings → Chips
Category Chips Settings
:magnifying_glass_tilted_left: Added Filter and Capitalize-First-Letter Option
Allows filtering of list items directly via the input field.
If enabled, the first letter entered in the input field is automatically capitalized.
Thanks to @creoludifico for these great ideas :raising_hands:
