It’s not really possible for HA to become out of date with any zwave-js-server changes without you knowing. The zwave_js integration requires a minimum API schema version to be supported by the remote server. If the API schema version HA requires is newer than what the server version supports you’ll get an error and the integration will not load.
The zwave-js-server is also backwards compatible with previous versions of the API schema. Even if you install a newer version of zwave-js-server, HA will still be compatible, as long as the API schema versioning requirements are met.
The official addon also pins specific versions of zwave-js-server and zwave-js, and these are always compatible with the latest version of HA. Usually the addon versions are bumped prior to an HA release when HA requires a new minimum API schema version.
Zwavejs2mqtt hosts the same zwave-js-server code that the official addon does. They may not have the same versions at the same time, yet you can switch between both (assuming the same version requirements are met). If you are using HA to talk to the server hosted by zwavejs2mqtt, it’s really no different than using the official addon. However, there is a difference when using the z2m control panel since it talks to the driver via its API directly.
Regarding inclusion, there was the bug (referenced earlier) in 2021.9.0 to 2021.9.3, and fixed in 2021.9.4, that broke inclusion in some ways, but it was not because of changes to the server. The fix did not require any server changes. HA always sets the inclusion strategy to S0 (when the secure toggle is on) or Insecure. It never enables the S2 inclusion strategies. While the server does support the functionality, HA needs to implement the DSK PIN prompt in the UI.
You don’t need the S2 keys defined to use S0. S2 bootstrapping should never be attempted when including with HA. Assuming you tried this on 2021.9.4 (and not 2021.9.0-3), and since HA cannot include with S2, if this node was somehow included with S2 then there is an unknown problem that would be worth investigating. Even if S2 inclusion was specified, without the S2 keys defined the bootstrapping would fail, and node-zwave-js should then downgrade to Insecure. However, since you’ve moved on to zwavejs2mqtt that may be moot at this point. Without driver debug logs of the inclusion process it isn’t possible to debug any further.
Regarding the official addon, S2 keys are not supported yet but a PR is in progress. Since HA itself doesn’t support S2 yet, the keys will not be useful unless you are switching back and forth between zwavejs2mqtt and the official addon.
