🔴️ Inovelli RED Led Status Change for Garage + Door Lock [ex: August/MyQ/ZwaveJS]
Tags: #<Tag:0x00007fc42198e5a8> #<Tag:0x00007fc42198e4b8> #<Tag:0x00007fc42198e3f0>
I’ve but together a blueprint that will set an Inovelli Red Dimmer with an effect and a color based on the status of a cover (garage door) and a lock. There are 4 states:
Garage open/closed and Lock unlocked/locked.
Garage Door Lock
Garage Open Door Unlocked
Garage Open Door Locked
Garage Closed Door Unlocked
Garage Closed Door Locked
Additionally it will fire off a notification to a mobile device.
Demo Video Here
This blueprint will depend on the ability to call two services which are scripts forked from brianhanifin
service: script.inovelli_led
service: script.inovelli_led_set_defaults
One will set an effect on the LED while the other will then update the colors post-effect.
The blueprint will make use of the two following scripts that were forked off of brianhanifin’s repo:
Hi Jeef,
Thanks for throwing this together.
Any way to add additional locks and/or garage doors easily?
Probably. What locks?
Happy to work with you to try it out. Right now there is a zwave flag on the lock but if I remove it it will probably grab any lock I think. Same for any cover.
Actually I think it will work with any lock as-is
Awesome! All my locks are Z.Wave.
I believe you are correct, when I changed your default lock (August) or Cover it provided a drop-down list that had my devices as the selection.
