I have a Pi3B+.
Wrote appropriate hassio image 32bit to USB flash drive (tried 3 different drives/brands) via Etcher.
Inserted drive to Pi, ethernet cable, etc… When I try to boot the Pi I just get boot errors. It looks like it is trying to do something. But no cigar.
If I leave the sd card inside it just boots to it instead. I thought the 3B+ was supposed to support USB booting.
Is there some trick to putting the hassio image on the USB directly using Etcher or Win32DiskImager? What am I missing? Any ideas?
Or, is there a particular reason we have to install to a SD card first and then burn an image of the SD to USB? That seems very antiquated, wasteful, and superfluous these days.
Try this on your USB flast drive or SSD i am working with SSD no other options worked but this work Click the Link to see the Instructions : https://github.com/dale3h/hassio-installer
Coool - but then it is not hassOS - I might need to go that way as HassOS does not support USB boot (so SD-card crashes will be quite common for HassOS users)
I have just Read that hassOS is more application stable and easy to maintain than hassIO
Hi, Did you ever figure this issue out?
I have done everything that you mentioned and tried to look at the other suggestions on here but everything was far to technical for me… I am a Noob…
I have a brand new RPi3B+ I managed to load the Noobs software and it work fine.
When I try to load the Hassio image I get the exact same as your screen shot above!
Regards Adrian
