Install HAOS - Fujitsu Futro S740 - only 16GB ssd space
Hello, how can i install Home-Assistant 10.3 on a Fujitsu Futro S740?
I’m prefer the Home-Assistant OS method, my SSD only have 16 GB free space.
Greets
henrya
Here you go:
X86 install
It look’s nice, but i havn’t a M.2 to USB Adapter.
Use option 2 and put an OS on a USB drive and boot to that.
You should install HAOS on a system with at least 64GB storage space. Anything less than that you are looking for long term issues. DO NOT forget you need space for backups, add-ons, integrations, HACS, database, etc. The all eat up disk space.
Did you have read this?
@reotto
Did you mean this?
What did you mean?
Yes I meant that.
It eliminates the need of pulling your drive and installing the OS directly.
Boot to the USB and then install the image to your main drive, pull the USB and reboot and you will be rolling.
I have an Intel NUC and this how I did my install.
Is that a s470 or a s740. I can’t find reference to a s470 on the net, but the s740 has options for different (bigger) drives.
S740
I havel edit the S470 to S740
