Registered to say thanks and to note that I managed to get Google Assistant Webserver (Hass.io addon version) working too. Required (A) the addition of a cheap usb sound card (possibly could have spoofed a sound device but I don’t have the know-how for that) and (B) changing the default ports used so as not to conflict with the ports used by DSM.
Thanks, after upgrading to the lastest spk it seems to be working. At first it didn’t seem to work, but stopping and restarting the package from Synology Package Center apparantly did the trick. I can now find and add repositories.
Now I’ll play around with hassio to see if I can get the addons I had installed from HACS to work on Hassio (or install HACS inside Hassio)
Same error for me. Received mine today and tried starting the addon runs into following error in system log:
19-07-31 15:11:18 ERROR (SyncWorker_5) [hassio.docker] Can’t start addon_7ad98f9c_zigbee2mqtt: 404 Client Error: Not Found (“linux runtime spec devices: error gathering device information while adding custom device “/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193B13F2-if00”: lstat /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193B13F2-if00: no such file or directory”)
Hey @fredrike I’ve commented on your work in spksrc; I do have an avoton-6.1, I did a clean build of spk-hassio-avoton-6.1 and installed.
good news: using a specified USB device for ZWave Integration works – I’ve just used the /dev/ttyACM0 that my Gen5 USB hotplugs as, and it’s less work than doing a rules file to softlink it to a known device.
bad news: I hit the entrypoint.js issue with your PR in spksrc (d1b19970)
I’ll re-build and re-try tonight with your 7b9dbcc
So far that build has been working well for me – I recompiled the SPK for my HW due to habit, if I didn’t need to, cool/sorry. I believe it downloads the and images for actual run anyways.
I can check later if it’s critical.
I had to restart to get the add-on list to populate, but this time it worked. Had some hiccups in wave, need to repopulate aliases, and maybe a few issues related to running a 0.85.0 config on 0.96.5. I’m happy to test a new version if you prefer. Lemme direct-message you some contact info if you need a quick re-check of a build.
I’m having some trouble getting the plex media server addon working. I have the hass.io image installed via docker and home assistant itself is working flawlessly so far but I cant get the plex addon container started. Im faced with the following error message from the docker logs:
As described above I have tried installing the image directly to a share (volume1/hass.io) but that resulted in the same behaviour.
Have also tried manually start the container (this resulted in the error message). Previously trying to start the plex addon via HA would just result in a failed attempt with no log messages in either the addon or HA.
Have also tried adding the IP:port of HA to Plexs “Custom server access URLs” but that had no affect.
Plex is installed natively on my Synology DS1817+ (DSM 6.2.2-24922 Update 2)
Plex Version 1.16.3.1402
Thanks for the pointers. Excuse my ignorance, but if I stop plex running natively on the nas, plex wont be running at all… Does that mean that the plex addon for hass.io is a new server altogether?
Yes it is a new server (I guess). I’ve not dared to migrate from native Plex to hassio-addon Plex my self yes so please keep us updated on your experience.
The benifit will (probably) be that you are managing all services from within hassio…
Ok Awesome… Thanks so much for your help!! I have the addon working now, but would like to point out one minor detail that isnt explained in the documentation and that is that after the install, the plex addon docker container needs to be updated to include mounting paths for media locations… Minor detail but thought it worth a mention.
Ill keep you posted here. I have turned off my native install (I wont delete it though, at least for the short term) and am slowly building the libraries for hass.io
Did anybody experience problems after the last Synology update ( 6.2.2-24922-3)? My Synology updated overnight, and SSH and MQTT promptly stopped to connect to api.
Some more info:
Log file in addon_core_configurator:
/run.sh: line 17: HASSIO_TOKEN: unbound variable
Logfile in addon_xxx_ssh:
[11:36:51] ERROR: Unable to authenticate with the API, permission denied stderr
11:36:51 [cont-init.d] nginx.sh: exited 0. stdout
11:36:51 [cont-init.d] ssh.sh: executing… stdout
11:36:51 [cont-init.d] ssh.sh: exited 0. stdout
11:36:51 [cont-init.d] user.sh: executing… stdout
11:36:51 /var/run/s6/etc/cont-init.d/user.sh: line 30: HASSIO_TOKEN: unbound variable stderr
11:36:51 [cont-init.d] user.sh: exited 1.
No, on the synonogy there is a package “Virtual Machine Manager”
So you can run virtual machines straight on the Synology.
But I don’t know what would be the best way. I think docker is slightly better, with less overhead…
Only thing I don’t have find out if it’s possible with the add-on to have a dedicated network configuration (Separate IP from the NAS itself), only for the hassio docker. (So no trouble with already used ports and stuff…)
