If you have hassbian installed there is hassbian_config show command which shows the list of installable components. Here is also appdaemon. You can install it simply by run this command:
sudo hassbian_config install appdaemon
Now I investigate how to set and run HADASHBOARD. Seems like there is no easy manual nowhere. Shame.
I got some problems, I canât see the dashboard in my browser.
Installed on a AIO with pip3.
Have maked the directories css and javascript in compiled directory.
I got rw-râr-- as homeassistant on all files under conf/
This is my error:
2017-11-28 19:52:38.239633 INFO AppDaemon Version 2.1.12 starting
2017-11-28 19:52:38.240614 INFO Configuration read from: /home/homeassistant/.homeassistant/conf/appdaemon.yaml
2017-11-28 19:52:38.479894 INFO Starting Apps
2017-11-28 19:52:38.673285 INFO Got initial state
2017-11-28 19:52:38.675155 INFO App initialization complete
2017-11-28 19:52:38.676529 INFO Starting dashboard
2017-11-28 19:52:38.692793 WARNING ------------------------------------------------------------
2017-11-28 19:52:38.693531 WARNING Unexpected error in dashboard thread
2017-11-28 19:52:38.694230 WARNING ------------------------------------------------------------
2017-11-28 19:52:38.700055 WARNING Traceback (most recent call last):
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py", line 401, in __init__
raise ValueError('Not a directory')
ValueError: Not a directory
File "/usr/local/lib/python3.6/site-packages/appdaemon/rundash.py", line 319, in run_dash
setup_routes(conf.dashboard_obj)
File "/usr/local/lib/python3.6/site-packages/appdaemon/rundash.py", line 289, in setup_routes
app.router.add_static('/compiled_javascript', dashboard.compiled_javascript_dir)
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py", line 845, in add_static
follow_symlinks=follow_symlinks)
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py", line 404, in __init__
"No directory exists at '{}'".format(directory)) from error
ValueError: No directory exists at '/home/homeassistant/.homeassistant/conf/compiled/javascript'
2017-11-28 19:52:38.700934 WARNING ------------------------------------------------------------
2017-11-28 19:52:38.701645 INFO API is disabled
2017-11-28 19:52:38.799291 INFO Connected to Home Assistant 0.58.1
Thanks @keithh666 I thought I had missed a step to install something but it turns out what I missed was manually creating those directories. I too created âcompiledâ in the dashboards directory; once I moved it up one level I was in business.
easy enough they are random bunched together nothing is complete from start to finish of a particular install of appdeamon and HADashboard looked like it was hastily thrown out there from the feedback I been getting is install docker because it is easier following those instructions I doubt I hurt anybodyâs feeling as very little care went into those instructions so whoever made it does not care what I have to say about it
well then instead whining and crying about how your feelings got hurt and instead provide a link to the "Official install instructions that is for Venv install that works if it is different then what I came across on their site and actually works I will post a apology on here
one example is where is this file located
You just need to add a directive to the appdaemon.yaml file - dash_url
here is another example from my count I see at least 5 different methods of installing on different platforms all ran together on one page donât know where one leaves off and another starts but according to the page title it suggests that all it applies to Venv install which I am not convinced on https://appdaemon.readthedocs.io/en/stable/INSTALL.html#install-using-pip3
