Not working
Care to elaborate?
This doesnāt help describe what issue you might be facing.
yeah that is true, I lost connection when I reset my modem assigning a static IP to my Raspberry pi. The Think is I follow the instructions and I am not getting hassio running on a docker container
I just get This site canāt be reached when I try to get https://<raspberry.ip>:8123
I would suggest this is your issue then. Format your SSD/SD and start over.
Easier to start over, it takes 30mins from start to finish.
I just ran everything to test on my test Pi, and have everything up and running, so you have caused the error.
I used your Guide with an Fresh Ubuntu 18 and snapshoted my old Hassio and everything works Perfect and i can install other Programs thats rly nice thx for that.
When HA gets an update i should be able to just do it with that instalation or will it make Problems?
Hi, ima noob hereā¦ managed to follow all the steps less the last oneā¦ any help or advise is greatly appreciated. Thanks!
First try again. A tls hhandshake timout can happen, can be just an intermittent internet problem.
I have the exact same problem. Did you ever find a solution?
I updated yesterday from a perfectly working 0.113.2 to 0.114 using the upgrade function in Supervisor.
After some waiting, I noticed HA was not coming back.
I uninstalled it all (I have automatic backups on Google Drive) using the info in Can't Remove Docker Containers
I then tried a fresh install using this Guide and script, without succes!
Script runs fine, but the HA docker image is not installed.
I looked into the hassio_supervisor logs in Docker, and I get this
0-08-14 04:36:02 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-08-14 04:36:02 WARNING (MainThread) [supervisor.updater] Can't process version data: 'null'
20-08-14 04:36:02 WARNING (MainThread) [supervisor.homeassistant] Found no information about Home Assistant. Retry in 30sec
Can someone help me out here? The script is called with
sudo bash supervised_installer.sh -m raspberrypi4-64
The installer script was updated and also contains an error.
if [ -z "${HOMEASSISTANT_DOCKER}" ]; then
error "Found no Home Assistant Docker images for this host!"
fi
Iāve changed my version and it should be working again now.
It works.
curl -SL "https://raw.githubusercontent.com/konnectedvn/hass-config/master/hassio_installer.sh/hassio_installer.sh" -o hass_installer.sh
As I already noted, the script has been updated and is now fixed. No need to provide alternatives.
Script seems to work now, HA-container is installed but HA crashes unfortunately.
Docker:
2e50d8b7ecd8 homeassistant/raspberrypi4-64-homeassistant:0.114.0 "/init" About a minute ago Exited (1) About a minute ago homeassistant
f822288003a9 homeassistant/armv7-hassio-multicast:2 "/init" About a minute ago Up About a minute hassio_multicast
485903ceeb95 homeassistant/armv7-hassio-cli:25 "/init /bin/bash -c ā¦" About a minute ago Up About a minute hassio_cli
1d0742aaa40d homeassistant/armv7-hassio-audio:17 "/init" About a minute ago Up About a minute hassio_audio
c846a7b23a94 homeassistant/armv7-hassio-dns:9 "/init coredns -confā¦" About a minute ago Up About a minute hassio_dns
23312a67a4a5 homeassistant/armv7-hassio-supervisor "/init" About a minute ago Up About a minute hassio_supervisor
Supervisor Log:
20-08-14 07:05:32 INFO (MainThread) [supervisor.homeassistant] Wait until Home Assistant is ready
20-08-14 07:05:37 ERROR (MainThread) [supervisor.homeassistant] Home Assistant has crashed!
raspberrypi4-64-homeassistant:0.114.0 Log
standard_init_linux.go:211: exec user process caused "exec format error"
Did you format your SSD/SD and start again, or try and re-install over the previous? I would start fresh if you didnāt.
I just tested on Ubuntu 18.04 and it works without an issue, no crashes.
On Raspbian, only raspberrypi4 works, raspberrypi4-64 does not. Donāt know why it changed to āraspberrypi4-64ā.
I noticed that the supervisor indeed installs raspberry4-64, does not matter if you pass raspberrypi4 or raspberry4-64 to the script
Google for the HA-error in Docker in fact points to architecture mismatches.
Iām confusedā¦and Iām about to do this same install on a Rpi 4 on Raspian. Is it now fixed or do I have to change something to get HA working correctly?
Magic just happened.
I removed all docker images with
sudo docker system prune -a
The Supervisor now downloaded the homeassistant/raspberrypi4-homeassistant image instead of the 64-bit version. HA is back up but will need to reinstall some stuff since my backup is on 0.113 and I donāt want to restore that one given the mess Iāve been confronted with
Edit: I took the plunge. Restored 0.113.2 and hit the upgrade button. Works perfect now.
I tried this just a few days ago and kept getting stuck on loading the docker image. I let it sit for over and hour and HA never seemed to start. Iāll give it another go this weekend.
