Integrating Tado Bridge X fabric into HA using Matter/Thread
I am running a Tado Bridge X with two Tado X thermostats and one Tado X temperature sensor connected to this TBR.
While waiting for the official HA update of the Tado integration to also support the X devices, I was wondering whether I can control the X devices by integrating the Tado X fabric into HA using the native Matter/Thread integration.
In the Thread integration, I can see the Tado Thread network as preferred network but I see no Matter devices in the Matter integration. I — being a newbie to Matter/Thread — expected to see the devices connected to the Tado X bridge.
Am I mistaken and the integration of existing Matter/Thread fabrics doesn‘t work like this in general? Or is this an individual problem of the Tado X bridge? Am I doing something wrong?
In tado app go to “settings”, “rooms and devices”, select desired device, scroll down to “device linking” and from there you can share it to HA trough matter.
I am running the iOS Tado app version 8.10.0 and I don‘t have this „device linking“ option, neither on my iPhone nor on my iPad. :thinking:
I’m also very interested in understanding whether the Thread TBR are accessible for joining a different pre existing thread network, did you find a way to gather their network info and keys? Or, better, having them connect to another network?
No, I was neither able to integrate the Tado X Thread network into HA nor to share the Tado X TRVs with HA. But it is my understanding that others has success, see this thread.
On the other hand, there is an update for the existing Tado integration on the way which will probably be part of HA 2024.12, see here. But this is not what I was looking for since the HA Tado integration uses the Tado API and therefore requires a Tado account. I was looking for controlling the TRVs completely locally.
Although quite stylish, the Tado X TRVs come with some limitations I didn‘t like: open-window detection only with a paid Tado account; heat curve not stored locally (when you lose your internet connection, they stay in their current state); Tado-specific battery pack; no once-a-week cycle to keep valve moving; … I sent them back, got a refund and will try the Bosch TRVs some day.
This option is missing in my app as well. I tried on iOS and on Android but no luck.
I also found on tado’s website that I should be able to pair other devices with their bridge for X devices. While the pairing works and the other device (a smart plug) shows up in the Home app on iOS, the device is also not showing in Home Assistant.
I had the same problem. Interestingly, about a week before that happened, I installed a different Tado X head and the sharing worked ok. So, this time around I first installed the head in HA and then shared it from there with Tado App. Now both heads are visible in both controllers.
For some reason I had a similar issue: Most devices were able to be shared. On one Smart Radiator Thermostat the Device linking button was missing. And on one Smart Thermostat the Device Linking never worked and ended with a red alert warning. It help to disconnect, reset an reconnect the devices from the Tado app. Afterwards both devices worked fine. Here you can find information about the reset mechanism: How do I do a factory reset on my tado° X devices? | Help Center: tado° X
You can get the network key from the debug menu in the HA companion app.
Settings → Companion App → Debugging → Thread
There you can see the Border-Agent-ID, Networkkey, extended PAN-ID and active Dataset.
Matter does not work for me, also the info in the matter item are much less then the ones in the Tado integration.
Please can you enable TadoX ?
:tada: Good news for Tado X users!
@msavazzi I’ve built a custom HACS integration that works perfectly with Tado X devices: ha-tado-x
Why this integration?
:white_check_mark: No Matter hassles - uses Tado’s official API directly
:white_check_mark: All features working: climate control, presets (Schedule/Boost/Home/Away/Auto), sensors
:white_check_mark: API usage monitoring (critical for free tier: 100 requests/day)
:white_check_mark: Temperature offset calibration
:white_check_mark: Energy IQ meter reading upload
:white_check_mark: Child lock, open window detection, weather sensors, quick actions
Super simple installation:
  1. Add custom repository in HACS: https://github.com/exabird/ha-tado-x
  2. Search “Tado X” → Install
  3. Restart Home Assistant
  4. Add integration → Follow device authentication flow
  5. Done! All your Tado X devices appear automatically
Already 100+ users have it working smoothly. Latest version: v1.6.4
No more greyed-out Matter buttons, no device resets, just plug and play. :rocket:
Thanks for this, works great!
love this, connected easily. and can control the stat without drop outs, only issue is the Tado app, usually set to manual mode, ‘until you resume schedule’ , but now randomly reverts to the Tado schedule. I can’t seem to find what/how this happens.
I use scheduler card for setting climate temps, times etc.
would this integration be the cause of it reverting to schedule in Tado app?
Apologies for late answer but I've been swamped.
@exabird THANK YOU!!!! really a lot!!!!
