Hi Oliver84, I feel your pain. I tried setting up hassio with HA on docker over the weekend and I had to basically fix this by myself. There’s no answers on any related threads/questions.
I found out that each add-on and in fact hassio itself, is run as a separate container. I’m decently knowlegeable with docker and so started looked deeper and realized that network-manager is not so much of an ‘optional’ dependency as mentioned here, if you want to use hassio or any add-on.
I had previously uninstalled network-manager since it started faking my Pi’s Mac address during the WiFi scan, making the router assign a new IP every time. I was able to get around it by adding this config file.
Once I installed network-manager on the host machine hassio was able to set up the networking between hassio and add-on containers, and I didn’t get this error anymore.
In general, if there’s any networking issues (like invalid access token, add-on DNS issues, etc) in your hassio_supervisor container’s logs, the network-manager install/config on the host machine is the first thing I’d check.
Thank you, however I’m not sure if this is my issue. I’ve always had network-manager installed and this issue just started happening out of nowhere. I had everything working just fine and then all of a sudden I started getting this error.
I tried the config that you suggested but I’m not sure if I did it right because it didn’t seem to make a difference. I’ll keep looking into the network-manager and see what’s going on there. Thanks!
I think this is related, yes. Even if network-manager is installed, maybe hassio isn’t able to use it? I’m not an expert at network-manager or hassio so I doubt I can help more. I had the same issue and it was because network-manager was missing on the host machine.
The network-manager configuration I made was just to prevent the RPi from continuously changing it’s MAC address on every wifi scan. I needed network-manager for hassio to work, but without the MAC address mischief.
Did you manage to handle this? I am experiencing the same. I’m trying to migrate to HA docker container over OpenMediaVault NAS server. I used this project to create the images. On the host I have network manager installed, so the problem is other.
In the supervisor container I get:
e[31m19-08-16 03:45:32 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/infoe[0m
e[31m19-08-16 04:40:33 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/infoe[0m
e[31m19-08-16 05:35:34 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/infoe[0m
e[31m19-08-16 06:30:35 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/infoe[0m
e[31m19-08-16 07:09:32 ERROR (MainThread) [hassio.api.security] Invalid token for access /app/entrypoint.jse[0m
e[31m19-08-16 07:25:36 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/infoe[0m
e[31m19-08-16 08:20:37 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/info
And in HA web interface, when clicking on Hass.io menu I get
Unable to load the panel source: /api/hassio/app/entrypoint.js.
Sorry, I wish I could be of help. I gave up on this and am just running it straight from docker, no hassio. I tried everything short of a clean install and nothing worked. If I go back to Hassio, I will try starting from scratch and rebuilding everything and hope that works.
My bad, I were messed up the shared folders between containers. I deleted all docker images and containers and build them again and everything works fine.
