I have rolled back to 3.4.3 and I can confirm the sensor works again
I am using the S2-WIFI-ST, when scanning for open ports, it also doesn’t show any, however, open port was 502, instead of the well known 8899 as the DLS-LAN.
Seeing as both S3 and S2 are both alpha numeric serials, I would expect them to behave the same.
Ohh really , then I have to go with your modbus ASAP…
Will try install it now.
Could you please open an issue on the repo, and I will investigate.
Thank you so much.
I reported it here:
Hi !
Thank you for all nice job !!!
Can i resize you card to full screen for any
my devices ? ipad mini, ipad 4 ?
how to change size ?
Yes you can. Have a look at the following card options:
panel_mode:
card_width:
card_height:
Please read the documentation how to use these in combination and make sure you have the correct dashboard layout selected.
https://slipx06.github.io/sunsynk-power-flow-card/configuration.html
v4.5.0
Exciting New Features
- feat: update default essential icon to
mdi:home-import-outline
- feat: add
dynamic_icon:
attribute to load. The essential icon will change when there is 100% contribution from a single power source (battery, grid, solar). This is enabled by default - feat: add
dynamic_colour:
attribute to grid. All grid objects will be set to theno_grid_colour
when there is no grid power. This is enabled by default. If disabled theno_grid_colour
will only be used to set the colour of the grid icon when grid is disconnected. - feat: grid icon will change when exporting energy
Full Changelog: Comparing v4.4.3...v4.5.0 · slipx06/sunsynk-power-flow-card · GitHub
Hello, please, how can you change the entire background of the card?
I tried ha-card and it doesn’t work.
Thanks for any idea.
card_mod:
style: |
ha-card {
background-color: transparent;
card_mod:
style: |
ha-card {
--ha-card-background: red;
Thank you very much. No frame like this
card_mod:
style: |
ha-card {
--ha-card-background: transparent;
box-shadow: none;
border: 0px;
you have a typo in box-shadow
card_mod:
style: |
ha-card {
box-shadow: none;
border: 0px;
I’m using this card and is great! Please, something that I have in my home is 2 inverters. Is there an option for that? thanks!!
No. You will either need two cards or you need to create template sensors
Can you add the support to SRNE inverters?
Please add a feature request on github
Please help me decide which icon to use for the essential load when supplied by PV
v4.8.0
- feat: new incremental battery icon to show SOC more accurately. Note that the battery
full_capacity
andempty_capacity
attributes are now obsolete and can be removed from your config. Closes #192
Full Changelog: Comparing v4.7.4...v4.8.0 · slipx06/sunsynk-power-flow-card · GitHub
