You have those temperature sensors set to ‘none’ in your config but I don’t have checks to hide them based on this value. The quick fix is to just delete them entirely from you config if not used. I’ll release an update to include that logic as well as how to handle when use_timer_248: is set to none.
v1.6.9
Updates
Autarky and Ratio can now be displayed using real time power values or daily energy values. This can be set using the autarky attribute under the inverter card configuration. Valid values are energy
(default), power
or set to no
to hide
Fixes
Better logic to hide sensors when set to none
and not in use
Please try the new release v1.6.9
EDIT: Inverter status can be hidden if inverter_status_59: is set to none in v1.7.0
@elRadix added to v1.6.9
I think there is something wrong with calculation… can’t be negative and compared to the the other card the percentage is not the same
I’ll have a look. So you exclude Grid export from your calculations?
production = 1,34kw
consumption = 0.192kw
Ratio = ((consumption) * 100) / production)
Also v1.7.0 fixes the battery floating text
Seems so indd, the card does the calculations so it doest use the exported energy
using v.1.7 now no negative values but autarky is not right
v1.7.1
Updates
- Display up to two additional essential loads. See the
additional_loads:
attribute in the Load card section. Set the sensor to display using theessential_load2:
attribute under entities - Improvement to Autarky formula
Ok I think i figured it out. 1.7.5 matches what I am seeing in the power distribution card.
v1.7.6
Updates
- Introduces a new optional nonessential_icon: attribute under the grid card configuration to change the non-essential image. Options are default, oven, boiler, charger, pump If you need other icons please open a request on GitHub
- Code refactoring
any news on a 3 phase version??
Hi @tabackd. This card will work for a 3 phase inverter. You may need to create some template sensors to total the individual phases, but it depends on your integration method…
What would you need to be displayed that is different?
W values per phase
Please log a feature request on the GItHub repo.
v1.7.7
Updates
Add support for customising non-essential icons when there are two non-essential loads. See optional load1_icon:
and load2_icon:
attributes under the grid card configuration. Options are default
, oven
, boiler
, charger
, pump
If you need other icons please open a request on GitHub.
v1.7.8 Updates
- New non-essential icon (aircon)
- New AUX icons. Select one of the following ( gen, inverter, default, oven, pump, aircon, boiler, charger)
v1.7.9 Updates
- Improve logic checks
- Change default autarky mode. Values are calculated based on real time power usage instead of daily energy. Set preferred mode in the card config
v1.8.0 Updates
- Add support for customising essential icons when there are two additional essential loads. See the optional load1_icon: and load2_icon: attributes under the load card configuration. Options are boiler, aircon, pump If you need other icons please open a request on GitHub.
- Logic fixes
v1.8.1
Updates
- Add new oven icon for essential loads
- Essential icons can be displayed on the lite card
v1.8.2
Updates
- You can now use any mdi icon to customise card images. Use either the built in presets i.e.
oven
,aircon
etc. or specify the icon you want to use i.e.load1_icon: mdi:pool
- Adds
<ha-card>
element for card mod - Removes charger icon preset. Use
mdi:ev-station
instead
v1.8.3
Updates
Apply fixed positions for mdi icons.
NOTE: There is a known issue with the positioning and scaling of mdi icons in Safari. Please use the built in presets instead
v1.8.4
Updates
New card attribute card_height:
that lets you set the height of the card when panel_mode is set to no. Can be used to fine tune dashboard layouts. Specify height in pixels i.e 450px. The default card height is 396px
Fixes
Remove additional card objects when show_solar is set to no
