@mshrem, it seems like you made --ha-card-background completely transparent.
So you must have changed ha-card-background: rgba(10, 10, 10, 0.4) to ha-card-background: rgba(?, ?, ?, 0).
@bachoo786, the color you quoted, corresponds to rgb(35, 35, 46) in RGB.
To make it transparent you edit (add) a fourth entry, like: rgba(35, 35, 46, 0.5), where the last entry is the transparency.
He Bas,
Is there a way to also use the background on the rest of the HA pages (config etc.). Love the dashboard, but in config and such it’s sometimes hard to read stuff.
@RvdHNL, unfortunately, that is not possible as far as I know.
What do you find hard to read? Could you perhaps post a screenshot? Maybe I can improve it
Oh, that is indeed quite terrible. I will see what I can do about it when I find some time!
Geen stress! Will also check if I can find something (not completely code agnostic
This looks like an excellent theme that I’d love in install, but need some help.
I already have:
frontend:
themes: !include themes.yaml
in my config file.
The instructions say to add:
themes: !include_dir_merge_named themes
So do I edit mine to be:
frontend:
themes: !inlcude themes.yaml
and then create a ‘themes’ directory?
Then, with regard to cloning git, which I’ve never done before, I just use terminal and enter
cd themes/
git clone https://github.com/basnijholt/lovelace-ios-dark-mode-theme.git
Have I got all of that correct?
I’ve installed using HACS.
It’s all there now, just working through getting the transparency to show now.
The ‘background-image:’ line 7 has a load of code after url('data:image/jpeg;base64, is this correct?
@ denver - yes that should be there
New to this system, i installed theme. Then I added yo lovelace yaml file:
background: var(--background-image)
cch-background: 'rgba(174, 179, 169, 0.8)'
primary-color: 'rgba(153, 159, 153, 1)'
I have green background but all other things like buttons, headers etc are orange. No idea what i am doing wrong. I have even restarted Home Assistant. Still no change.
@bindujohal, did you install the CCH Lovelace plugin?
nopes is it located in HACS?
Yes, look for “Compact Custom Header”
FYI, it is now called Custom Header. It was just recently re-written by the developer.
I installed custom header plugin but still shows Orange. Do i need to change something in my YAML file???
ch-background: 'rgba(174, 179, 169, 0.8)' not cch-background: 'rgba(174, 179, 169, 0.8)'
What was the final configuration?
I have installed this theme via HACS but am unable to activate it. I’ve added:
frontend:
themes:
!include_dir_merge_named themes/
Is the themes.yaml entry still required?
If you added it like that, Home Assistant should throw an error, that is not valid.
if should be:
frontend:
