all of a sudden yesterday, my HASS can not connect to my Roomba; Lots of errors and it completely breaks the HASS restart. I have had to disable the device in my config.
2019-08-04 12:18:03 ERROR (SyncWorker_9) [roomba.roomba.Roomba] Attempting new Connection# 1
2019-08-04 12:18:04 ERROR (SyncWorker_9) [roomba.roomba.Roomba] Error: [Errno 111] Connection refused
2019-08-04 12:18:04 ERROR (SyncWorker_9) [roomba.roomba.Roomba] Attempting new Connection# 2
2019-08-04 12:18:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform arlo is taking over 10 seconds.
2019-08-04 12:18:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform yr is taking over 10 seconds.
2019-08-04 12:18:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform transport_nsw is taking over 10 seconds.
2019-08-04 12:18:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform systemmonitor is taking over 10 seconds.
2019-08-04 12:18:05 ERROR (SyncWorker_9) [roomba.roomba.Roomba] Error: [Errno 111] Connection refused
2019-08-04 12:18:05 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform darksky is taking over 10 seconds.
2019-08-04 12:18:05 ERROR (SyncWorker_9) [roomba.roomba.Roomba] Attempting new Connection# 3
2019-08-04 12:18:05 ERROR (MainThread) [homeassistant.components.yr.sensor] Retrying in 17 minutes:
2019-08-04 12:18:05 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received
File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 526, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 207, in feed_ssldata
self._sslobj.unwrap()
File "/usr/local/lib/python3.7/ssl.py", line 767, in unwrap
return self._sslobj.shutdown()
ssl.SSLError: [SSL: KRB5_S_INIT] application data after close notify (_ssl.c:2609)
2019-08-04 12:18:06 ERROR (SyncWorker_9) [roomba.roomba.Roomba] Error: [Errno 111] Connection refused
2019-08-04 12:18:06 ERROR (SyncWorker_9) [roomba.roomba.Roomba] Unable to connect
2019-08-04 12:18:06 ERROR (MainThread) [homeassistant.setup] Error during setup of component light
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 153, in _async_setup_component
hass, processed_config)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/light/__init__.py", line 246, in async_setup
await component.async_setup(config)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_component.py", line 112, in async_setup
await asyncio.wait(tasks)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 363, in wait
return await _wait(fs, timeout, return_when, loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 456, in _wait
await waiter
concurrent.futures._base.CancelledError
2019-08-04 12:18:07 ERROR (MainThread) [homeassistant.setup] Error during setup of component cover
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/cover/__init__.py", line 100, in async_setup
await waiter
2019-08-04 12:18:07 ERROR (MainThread) [homeassistant.components.sensor] darksky: Error on device update!
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
await entity.async_device_update(warning=False)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 380, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 571, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 539, in run_forever
self._run_once()
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 1775, in _run_once
handle._run()
File "/usr/local/lib/python3.7/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/roomba/vacuum.py", line 84, in async_setup_platform
await hass.async_add_job(roomba.connect)
File "/srv/homeassistant/lib/python3.7/site-packages/roomba/roomba.py", line 283, in connect
sys.exit(1)
SystemExit: 1
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 366, in async_device_update
await self.parallel_updates.acquire()
File "/usr/local/lib/python3.7/asyncio/locks.py", line 474, in acquire
await fut
2019-08-04 12:18:08 ERROR (MainThread) [homeassistant.components.sensor] darksky: Error on device update!
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await fut
2019-08-04 12:18:08 ERROR (MainThread) [homeassistant.setup] Error during setup of component sensor
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/sensor/__init__.py", line 42, in async_setup
await waiter
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await fut
concurrent.futures._base.CancelledError```
