Is this the perfect standalone tablet for HA?
There are loads of hits when searching - the Android System WebView said it wasn’t available for my device which is why I wrote about the apk option in the guide. If you can remember how you installed yours though from the store, I’d be happy to add that to the guide. Thanks :slight_smile:
Thanks for your contribution @pgale!
Let’s get a couple more reports of successful installs and I’ll link your lineage Guide prominently in OP!
Have had quite a few now - lots of discussion on Facebook and Discord. @ADHDSquir has installed a batch from new and your existing install. Looking good :slight_smile:
Special thanks to <@383199597507510272> for the great docs which helped me get Lineage OS on my latest TS. The process has a bit more steps but Paul’s instructions made it mostly easy short of me skipping the software step because I thought I was good. QFIL needs to be updated to do the partion part. Excited to have a TS that does not crash on boot!
I got mine working as well. Thanks for the work here!. Any way to wake it by touching the screen instead of camera switch (or volume)? My current workaround is using the proximity sensors with automagic, but would be nice by just a screen touch.
Thanks for the guide <@383199597507510272> - up and running my 2nd panel on Lineage now!
Nice work, just did mine and works like a dream thanks to your great guide!
Upgraded 4 devices in a hour.
Just a few I’ve pulled - from different users. I’m really confident in this install and OS :slight_smile:
Only report of an issue was some apps not sticking in landscape mode - I’ve not tested them yet.
It showed up in the google play store. Not the beta one or the canary one. Just the regular webview produced by google. Ill get the link when i have a chance tomorrow.
@pgale if you install Chrome browser from Play Store, a new WebView selection will be available in System > Developer Options > WebView Implementation
Had no problems migrating over to Lineage 15.1 with your guide coming from XDA Chewie610’s guide.
Finally the display turns off along with the backlight. :slight_smile:
I’m hoping we can figure out a way to wake the screen by tapping. I have the ThinkSmart under my monitor where it blocks all the buttons and my camera slider switch isn’t the easiest to move.
Apologies, you’re right, I mixed it up with the other thread, which I have yet to try: Lenovo ThinkSmart View ROM/OS Development - #363 by FelixKa
If you find out anything about Lineage 15.1 and its USB OTG capabilities though let me know :slight_smile:
Unfortunately deadman did say tap to wake doesn’t work so I doubt there’s anything we can do. You can set the volume buttons to wake the screen but if you can’t get to them…
If you are running Fully Kiosk, you could setup a button or external sensor to wake it.
Thanks. I’ll add that later :slight_smile:
This is the only outstanding Lineage issue for me.
Wallpanel and Spotify are running fine but I can’t get a minimal launcher or the Roon app to run in landscape.
Doesn’t show on my play store on the device if I search for “android system webview”
Thank you! I will try that and report back. That would certainly explain why it works on the FireHD8 and not the Lenovo. Cheers
Super weird. Shows for the 3 devices i have lineage on.
Keep getting a 422 error from discourse when trying to edit OP. Any mods can help?
A 422 status code indicates that the server was unable to process the request because it contains invalid data. To fix a 422 status code, you need to identify the specific data that caused the issue and correct it.
My guess, clear your cache, restart your browser @mattmon
I’m having what is likely just a user error. I had installed this a few months ago, and it had been working good enough, so I’ve just been sitting back waiting for the kinks to be worked out. Looks like this latest version is just what I need. I initially followed these instructions and was successfull.
Now following your instructions here - GitHub - pgale/lineage_15.1_Installation_TSV: Lenovo ThinkSmart View Lineage 15.1 installation guide
When I get to QFIL select port, there is nothing showing up. I hear windows load the device, I’m using the same cable I used before. Since I already have flashed this before, I suspect I need to reset something?
Also I noticed that there was a line " After installation, Windows should also be in Test Mode which can be seen in the lower left of the desktop."
I’m running windows 11 and I dont see that anywhere on my desktop. Maybe I’m missing something?
Any help is appreciated. Thank you
Did you click on the comm port button (whatever it’s labelled)? If the port number has changed, it won’t necessarily show directly in the QFIL app screen and you have to click to see it listed.
Windows Test Mode is used to bypass Microsoft driver signing. The com driver that’s installed isn’t signed I don’t think.
You can try the steps here:
Test mode
