Journal issues with supervised install after updating to 2022.11
BAH, I reinstalled my supervisor using the link from above and now I’ve lost my add-on options and many of my previously installed things!
How do I get them back?
I thought I’d restore the backup but I don’t even have backup listed in the settings/system menus!!
I’m seeing this in my ha su logs:
22-11-03 20:16:29 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
22-11-03 20:16:30 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
I was originally using the -d option (for an alternate directory) with the original supervisor install.sh script which was apparently deprecated for the deb file which forces everything into /usr/share/hassio, from what I can tell. This is causing my installation to be borked now. I’m attempting to remove all my customizations so I can perform a fresh install to the /usr/share/hassio location and then restore a backup…
The full restore from backup sorta worked, the system is “up” but several sub-systems are semi-broken. The Add-ons are all greyed out like Home Assistant doesn’t know that they’re running even though I can see them in the docker container ls results. Also they appear to be up when I query them directly (bw, unifi), however ESPHome/Studio Code Server thinks they’re down and the ingress is unreachable because of that “Add-on is not running. Please start it first”. The Z-wave JS integration is broken, all devices offline and won’t load properly even though I can see in ha su logs it is complaining that core_zwave_js is already running!
How can I get my system back up and running at full strength?
