I’m looking to start working with MQTT so I installed the Mosquitto broker add-on. After clicking start the screen flashes (it tries to show the graphs for resource usage and the “start on boot” option turns off). I have not been able to get this stared even after multiple restarts and re installs. If I check the configuration tab it shows “This add-on does not expose configuration for you to mess with…” and if I check Log I have the following:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[19:22:09] INFO: Certificates found: SSL is available
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:22:09] INFO: Starting NGINX for authentication handling...
[19:22:10] INFO: Starting mosquitto MQTT broker...
1657844530: Warning: Mosquitto should not be run as root/administrator.
[19:22:11] INFO: Successfully send discovery information to Home Assistant.
[19:22:11] INFO: Successfully send service information to the Supervisor.
Current Setup:
Home Assistant 2022.7.4
Supervisor 2022.07.0
Operating System 8.2
Frontend 20220706.0
