I think, that there is a big KNX-community, which would also like to use the HomeAssistant. Particularly, because the KNX-Standard has been standardized ISO/IEC 14543-3, EN ISO 22510 and even n China GB/T 20965.
Many KNX-users are using the Gira Homeserver and comparable hardware - whose Software is sometimes dated and so there are many users, who are searching for a newer, much comfortabler software for visualization, automation which is even cross platform.
But those users are kind of spoiled by the cooperation of the ETS (software to configure the hardware of the smart-home-devices) with the e.g. Gira Homeserver Experte (Software to program the home server).
How does it work?
In the ETS you export your project. Then, in Gira Expert, you just import it. After that, every Group Address (Group Address = the Address, where e.g. the “light on” command has to be executed / kind of entity) will be imported and so the Gira Homeserver knows them all.
If this would be same at the Homeassistant, I think, many KNX-Users would like to switch to homeassistant.
So a “import Group address and convert to entity” service, which is also updateable (like “does this entity sell exist?” Yes? → no import) would be a very nice thing!
Now, the ETS-Data-Import just translate / decrypt the group address.
It knows what GA’s you used. You will still need to assign them manually and because Gira still doesnt know how to handle status groups you will need to tie the status group to the main group. Which on its turns causes all kind of “fun” interactions.
Also there is no “cooperation”, just a standard way that the export is made so anyone (including HA, which has an import feature now. Tho only for monitoring) can read it and use it in their server or visu.
Of the KNX users that maintain their own system i think they already do. The amount of knowledge you require to do that would that would imply they are comfertable with HA coding also.
HA already made a big leap integrating KNX:
There was some work on an import program:
But its a complicated thing to automate, unlike Expert you do not fill out a communication object list which you can then pick and choose for logic or QC.
If you want to create a light in HA you will need to assign the switch, dim value, feedback and or other things like color and such.
You would end up with an Entity for a switch, Entity for value and a not usable relative dim entity
Maybe we will get a GUI for that in the future, but for now its very simple to do it by hand.
Without any prior knowledge in KNX I manged to connect the KNX bus in my partner’s house to the Pi4 and added all KNX devices to the configuration.yaml file of the HA installation.
After uploading the ETS project file we can now control and dim all lights, covers and underfloor heating.
While doing this I learned a lot about the KNX topology. People who maintain their own KNX system should have no issue at integrating it with HA.
