Hi all,
I have tried to build my first presence detector but I found my Esp32 S2 mini off line this morning although the device seems to work correctly.
I explained the issue here:
Thanks for your support
Hi all,
Fail to open device. This is the message when I try to open my LD2410
As i know no.
In my experience not all esp32 boards works great with ld2410b.
Esp32-c3 works the best for me.
If it was working, have you tried restarting it? Unplug and plug
Which ESP32 have you got?
This one?
This is what I’m using for my S2s and they have been super reliable.
Your mileage may vary though lol
esp32:
board: lolin_s2_mini
variant: ESP32S2
framework:
type: arduino
version: 2.0.6
platform_version: 5.3.0
I have tried to restart it several times but without success.
I have also Esp Reboot with the integration but it cointinues to appear offline in Esphome.
I’m using the ESP32 S2 mini wemos (maybe a clone) like in your picture.
esp32:
framework:
type: arduino
version: 2.0.9
platform_version: 6.3.2
The yaml seems similar to your one but without
variant: ESP32S2
What I should do now? restart the installation process via USB?
If I were you, I would make sure that you have the same esp32, do some digging and make sure and then here is my complete config file.
Upload Instructions
Tool
https://adafruit.github.io/Adafruit_WebSerial_ESPTool/
esphome:
friendly_name: put_your_own
platformio_options:
board_build.extra_flags:
- "-DARDUINO_USB_CDC_ON_BOOT=0"
esp32:
variant: ESP32S2
framework:
type: arduino
version: 2.0.6
# Enable logging
logger:
create a new device and copy the keys and wifi settings here and delete this line
captive_portal:
uart:
tx_pin: GPIO39
rx_pin: GPIO40
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
number:
- platform: ld2410
timeout:
light_threshold:
name: light threshold
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
- platform: ld2410
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0:
move_energy:
name: g0 move energy
still_energy:
name: g0 still energy
g1:
move_energy:
name: g1 move energy
still_energy:
name: g1 still energy
g2:
move_energy:
name: g2 move energy
still_energy:
name: g2 still energy
g3:
move_energy:
name: g3 move energy
still_energy:
name: g3 still energy
g4:
move_energy:
name: g4 move energy
still_energy:
name: g4 still energy
g5:
move_energy:
name: g5 move energy
still_energy:
name: g5 still energy
g6:
move_energy:
name: g6 move energy
still_energy:
name: g6 still energy
g7:
move_energy:
name: g7 move energy
still_energy:
name: g7 still energy
g8:
move_energy:
name: g8 move energy
still_energy:
name: g8 still energy
switch:
- platform: ld2410
engineering_mode:
bluetooth:
name: "control bluetooth"
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
Also a question to everyone else. The config that I pasted, are there any cool things I could be doing differently? Im not sure what lol, but im always open to make it better or what the latest things are.
Well you can use setting for device internal temperature uptime and wifi signal like
- platform: internal_temperature
name: "Internal Temperature"
- platform: uptime
entity_category: "diagnostic"
update_interval: 300s
- platform: wifi_signal
accuracy_decimals: 1
update_interval: 5s
Then it will be nice to have some light sensor for it like bh1750fvl
i2c:
sda: GPIO18
scl: GPIO19
scan: True
- platform: bh1750
address: 0x23
update_interval: 1s
accuracy_decimals: 2
And some restart and reset buttons
button:
- platform: ld2410
factory_reset:
restart:
These may be possible with LD2420, which has somehow a lighter component, on ESP32,with ld2410 it will crash with insufficient ram.
How are you using the internal temp sensor? This thing runs pretty hot
Thanks for all that
Ive seen this referenced, but cant find out any info?
I ever have some kind of reference in the config for it
light_threshold:
Right so it looks like the light sensor only works in engineering mode?
from the ESPHome doco
light (Optional, int): When in engineering mode, indicates the light sensitivity, otherwise unknown. Value between 0 and 255 inclusive. Though it seems that the value 85 is the lowest value at complete darkness. All options from Sensor.
yes, to use the builtin light sensor aka ldr you have to use engineering mode.
the internal temperature sensor is on the esp board, not the sensor itself.
can’t find bar-card in hacs.
Yeah, depends on the board. Esp32 wroom is running very hot, above 70 degrees even more than 80. I switched to esp32-c3 that is running much cooler, around 35 degrees.
I use temperature sensor for alerting on the device. If temperature start to go too high send notification before fire start.
I’m new here, signed up for an account to ask a question. I hope this is a suitable thread to ask in?
I have two home made d1 mini / LD2410c sensors which I’ve had running reliably in Home Assistant for quite a while. When I made them the current version of esphome at the time was 2023.3.2. Recently I made two more sensors and got them working with esphome 2023.10.6 (which required a different yaml configuration). It is actually much better as it allows the LD2410 to be configured from HA, so I updated my two older sensors to the same esphome version.
Everything works fine, but I have one annoying issue I can’t seem to work out. With the older version of esphome the icons for the has_target
binary sensor showed up correctly using the given device_class
of “occupancy” (the icons for this are mdi:home
when occupied and mdi:home_outline
when vacant). This worked well for the badges I have on my main HA dashboard and I could tell if a room was occupied at a glance. With the newer version of esphome the has_target
binary sensor appears with icon mdi:account
and seems to ignore the device_class
entirely. If I use a lovelace glance card the colour of the icon changes when a room is occupied as expected, but my badges are now useless because they show the same icon whether a room is occupied or not.
Could anybody give me a clue on how I can fix it? I don’t really care much about what icon is displayed, but reinstating the solid / outline state change is what I am hoping for.
Thanks in advance.
Hm… just wandering… why additional light sensor? LD has one already built-in… for better sensitivity?
Also - it’s not exactly good for wifi range to have wires across wifi antenna… you might want to move them to th bottom side of wemos.
otherwise: excellent job!
- engineering_mode (Optional): enable/disable engineering mode. Defaults to
false
. Notice this requires more resources and is not recommended to be enabled when not necessary.
without engineering_mode NO light sensor
