I’ve been playing around with these …
after seeing MQTT enabled led sign
So mine is based on 3 modules connected together, currently without a box but hopefully I will get round to building one
The controller is a Wemos D1 Mini, which is small enough to fit in the back of the box and I can add some sensors if I want. I may add a temperature/humidity sensor, a smoke sensor and a lux sensor to set the brightness automatically. However for now it will output the following mostly via HA publishing to MQTT :-
[0] = Date/Time (Grabbed from NTP)
[1] = Good Morning/Good Afternoon/Good Evening (Done internally based on time)
[2] = My Bitcoin Value (Published by HA)
[3] = Livingroom Temperature (Published by HA)
[4] = Livingroom Humidity (Published by HA)
[5] = Todays Weather (yweather current) (Published by HA)
[6] = Tomorrows Weather (yweatyher day1 condition) (Published by HA)
[7] = Any plant needs attention (Published by HA)
[8] = Alarm set for xx:xx (not done atm)
[9] = Message from the web I/F or if connected from serial I/F
On HA I’ve added a group card to control the speed of scrolling, the brightness, the text effects and whether it’s displayed or not.
I’m using the MD_Parola software (Parola for Arduino: Main Page) to animate the sign.
I’m very pleased with it and am already thinking of other uses for it (messages and perhaps alarms for smoke/fire or windows/doors left open)
I would like to thank Kmanoz Profile - KmanOz - Home Assistant Community for his work on OTA updates, which I’ve shamelessly copied
and Koen01 Profile - koen01 - Home Assistant Community for his idea ![]()
When I finally put it in a box I’ll post an image here.
Added Sky News RSS feed gathered by the Wemos - seems to work pretty well
Added Evacuate/Panic sign for smoke/fire etc - not completely working yet
Added option to turn off/on individual lines
Maybe if you put it in a sleek polished aluminium container it might help :D, or paint it pink
Sketch is over 32000 chars
i see the standard texts. do i have to change “mqttsignstatus” in "textEffect_t to false? it is to “true” atm
