Hmm, I got one of these ledvance lights as a gift, frustrating that it will not integrate.
EDIT Jan 2023: i suggest you all to use: https://github.com/FlagX/ha-ledvance-tuya-resync-localkey
Finally i managed to get localKey for this trashdevices
pretty hacky procedure, but at least i got the key:
i used
- the 1.0.0 (probably also work with the latest) version of LDV smart wifi: https://m.allfreeapk.com/ledvance-smart-wifi,17068539/download.html
- a rooted android 10 device (an emulator and probably also others android versions are okay) with frida-server running: https://frida.re/docs/android/
- macos with frida installed (frida is multiplatform, so any OS should be okay)
login to the app on the android device, than on a terminal of the PC launch this command with the app in foreground frida-trace -U --decorate -j '*!*encodeString*/isu' -F
, refresh the list of device and you will get on the terminal a json-like blob, copy in a text editor and ctrl+f for localKey
(oviusly if you have more than one device you will get multiple keys, also if you configured any group in the app)
Actually i hope iāll find the right config for localtuya.
EDIT: all is fine with the one suggested for the sylvania bulb
https://community.home-assistant.io/t/sylvania-smart-wifi/223985/25
so, finally got this bulb in HA and working flawlessy!!
Hi, thank you very much for your investigation. I also had luck with my ledvance GU10 RGBW bulbs. I used the emulator in Android Studio (on windows with Pixel 2 XL API 28, Android 9 x86). It has to be a specific image because otherwise the adb root
command will not work (on images with Google Play).
iām just having a little issue with the colors, but probably the issue is somewhere else, all the light blue (i.e Azure, sky blue) colors turns my bulb in more near to violet colorā¦ probably a misconfiguration of localtyuya?
maybe you got something wrong in the configuration. colors look fine for me.
Hey, could you do a small writeup on this method? I was in the middle of sourcing a Pixel 2 for the
sole purpose of getting the localkey from a couple of bulbs, but this seems easier and more financially sane
I already got the Pixel 2 XL API 28 Android 9 image set up, but donāt know how to proceed from there.
EDIT: Seems I got it setup, and it works with the Chrome example, however when running the command from FrancYescO, it just says āStarted tracing 0 functions.ā and nothing happens when I refresh the list of devices by swiping down on the android emulator. I do this from remote, as Iām trying to help my brother, could that be the issue?
Step 1 Download & Install the latest version of Android Studio from here: https://developer.android.com/studio
(in my case 2020.3.1)
Step 2 On the first startup of Android Studio you have to complete the setup wizard:
Keep everything on default settings
Step 3 Open an empty folder (e.g. on your desktop)
Step 4 Open the AVD Manager and create a virtual device
Step 5 Select a device without Play Store (important!!) E.g. Pixel 2 XL
Step 6 Click on Download for the Pie system image (API Level 28, Android 9.0)
Step 7 Select the downloaded image and click next
Step 8 Now you can start the emulator (play button)
Step 9 Download python 3.9.x
From here https://www.python.org/downloads/release/python-396/
If you are using Windows 10 64bit I would recommend the installer:
https://www.python.org/ftp/python/3.9.6/python-3.9.6-amd64.exe
Step 10 Run the installer and make sure you select āAdd Python 3.9 to PATHā
Step 11. Open powershell and install frida tools via pip:
pip install frida-tools
Step 12. Download frida-server from https://github.com/frida/frida/releases
(I used frida-server-15.0.17-android-x86.xz)
Step 13. Extract to a directory via 7zip, WinRAR,ā¦ and rename the file to frida-server
Step 14 Setup adb (you can follow this guide https://medium.com/androiddevelopers/help-adb-is-not-found-93e9ed8a67ee)
On Windows I just added C:\Users\[your username]\AppData\Local\Android\Sdk\platform-tools
to my PATH variable.
Step 15 Run the adb commands from the directory, where you have extraced frida-server
to:
adb root
adb push frida-server /data/local/tmp/
adb shell "chmod 755 /data/local/tmp/frida-server"
adb shell "/data/local/tmp/frida-server &"
(press CTRL+C, this will not stop the server)
Step 16 Download the ldvwifi apk that FrancYescO mentioned: https://m.allfreeapk.com/ledvance-smart-wifi,17068539/download.html.
EDIT: Link is broken now. You may want to look at hints here: https://community.home-assistant.io/t/howto-ledvance-smart-plug-wifi-in-home-assistant-solution/350280?u=flag
Step 17 Run from the same directory where you have downloaded com-ldvsmartwifi-smart-1.apk
adb install com-ldvsmartwifi-smart-1.apk
Step 18 At this point you have an emulated rooted device with frida-server and the old LEDVANCE SMART+ WiFi Apk installed. Now you can do the last steps that are mentioned by FrancYescO (no macos is needed):
login to the app on the android device, than on macos launch this command with the app in foreground
, refresh the list of device and you will get on the terminal a json-like blob, copy in a text editor and ctrl+f forlocalKey
Hint for windows users: If the last command outputs Started tracing 0 functions. Press Ctrl+C to stop.
, you should try it in powershell or in cmd.exe without quotes (frida-trace -U --decorate -j *!*encodeString*/isu -F
). If it is sucessfull it should trace 2 functions.
Hey
Thanks for your guide, but I ended up like rgrabot and jacobtc, frida-trace said itās tracing 0 functions and no outputā¦ Iām trying to get this stupid localkey since Fridayā¦
I tried android 9 and 7 (emulated in Android Studio) and 5 different versions of frida-server, always with the same resultā¦ Python Version is the same as yours, Windows 10 x64 as well.
MITM Attacks wonāt work either, the communication with tuya-cloud looks AES-encrypted and I did not manage to get the AES key so farā¦
pretty frustrating
Do you get any warnings or errors when you start the frida-server on the emulated device?
If you get something like this:
Unable to load SELinux policy from the kernel: Failed to open file ?/sys/fs/selinux/policy?: Permission denied
you are running the command in user mode instead of root and it will not work.
If the server runs sucessfully there should be no output.
Nope, everything seems to check out, I just get āStarted tracing 0 functionsā and nothing happens when I refresh the app on the virtual device.
I just tried everything again and version of frida-server has to be very specific indeed. I even used the wrong one when writing my guide:
It has to be frida-server-15.0.17-android-x86.xz (not frida-server-15.0.17-android-arm.xz). They both start without any problems but only the x86 version (also not the 64bit version) works because it must match your ABI.
Also make sure if you are using e.g. frida-server version 15.0.17, it should also match your cli version:
āÆ frida-trace --version
15.0.17
Btw. you can also check if you are in root mode the following way:
If enter a shell command without root it will give you a $
character at the end
āÆ adb shell
generic_x86_arm:/ $
But if you are successfully in root mode you will get a #
āÆ adb root
āÆ adb shell
generic_x86_arm:/ #
I did install the x86 version. Everything seems to check out.
Again, frida does seem to work, as the Chrome example given in the frida documentation seems to work fine.
I think I found the issue: make sure you are not running this command in cmd.exe (the terminal in android studio is cmd.exe by default)
Try it in powershell in a directory where you write files.
With cmd.exe i got the same thing:
frida-trace -U --decorate -j ā*!encodeString/isuā -F
vs in powershell
āÆ frida-trace -U --decorate -j '*!*encodeString*/isu' -F
Instrumenting...
MMKV.encodeString: Auto-generated handler at "C:\\Users\\[...]\\__handlers__\\com.tuya.smart.mmkv.MMKV\\encodeString.js"
ByteString.encodeString: Auto-generated handler at "C:\\Users\\[...]\\__handlers__\\okio.ByteString\\encodeString.js"
Started tracing 2 functions. Press Ctrl+C to stop.
Iām going crazyā¦ I have absolutely no idea why, but using powershell seemed to solve the problem
Thank you!
Seems like cmd.exe handles string parameters differently. It would work without qotes:
Iām glad I could help!
Awesome! Powershell gave me an error, buyt running without quotes in cmd did the trick!
Iām guessing the device_id is easy to obtain?
Awesome, thanks! Should be easy to do then
EDIT: The device_id string can also be found named ādevIdā in the blob.
Iām guessing that there is no reason to sign up for an Tuya IOT dev account anymore, as we got the localkey this other way, correct?
