Legrand/Bticino MyHome
That’s the reason why! I have mh 202, myhomeserver1 and the touch 10", all of them possible gateway.
In this case i believe the best is to create a MH202 scenario using a cenplus to open the gate and than recall it from HA
Another question for you regarding error in HA. In the log i have those errors
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-74 already exists - ignoring light.luce_camera_padronale
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-73 already exists - ignoring light.luce_cabina_armadio
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-70 already exists - ignoring light.luce_balcone_padronale
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-77 already exists - ignoring light.luce_wc_padronale
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-0711 already exists - ignoring light.luce_specchio_bagno_padronale
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-82 already exists - ignoring light.luce_padronale_sinistra
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-75 already exists - ignoring light.luce_bagno_padronale
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-03 already exists - ignoring light.luce_padronale_destra
2021-09-23 16:29:11 ERROR (MainThread) [homeassistant.components.light] Platform myhome does not generate unique IDs. ID 1-0714 already exists - ignoring light.luce_camera_ospiti
do you believe this happen because i have more than one gateway configured?
Yes, at this time the integration does not work with multiple gateways at the same time.
It is indeed likely the easiest way to achieve what you need!
Hi All,
Salut Julien …
I’d also like to test the custom integration.
Github: chercheur57
need to say i’m quite new in Home assistant platform …
Thank you!
Hi, thanks for the suggestion.
The dimmer works perfectly fine!
I am actually driving a couple of LED ceiling lights through a dedicated power supply (QLT PBOX150DB).
Hi Julien,
after upgrade that you released, I started to have some problems with auxiliary sensors from the alarm system. The following message appears: ​entity not available.
What could be the reason?
thanks for everything you do :muscle:
Hi!
Good catch! The issue is fixed in this commit.
You can either try to run the current “master” version from HACS, or wait a few days for an actual release that will contain the fix.
Thanks!
Hi Julien,
I’m setting Up mi HA installation and I have home control with MyHomeServer1 and I’m tuning a little bit my climate control. I’ve setted up my KM4691 with heating/cooling and everything else. Then I find that with sizing 60 I can get also humidity but I don’t know how to set it in configuration.yaml.
Thanks in advance for help and for your integration.
Hi Julien,
no problem, let’s wait … just one thing I also encountered problems with the 4 zone control unit (thermoregulation) the set-point temperature and the current temperature are not displayed and then at each HA restart the energy_today and energy_current_month sensors are disabled.
As always, Thanks!
Bonjour Julien
Hello Julien,
For you information ,Who 6 and 8 works with the F454. I have this system at home.
Think you can work on who 6 and 8?
I have a screen bus 10 pouces Celiane. => 067219 Ecran tactile couleur MyHOME screen BUS 10pouces Céliane écran capacitif - blanc - Espace Pro | Legrand
In the screen , i see my interphone and my alarm => my interphone is composed to Bticino | BTI-351300 and Bticino | BTI-352000 and BTicino - 353200
[/quote]
Hi @stephane24 ,
Support means two different things
  • The messages you can see, here I’m not sure what the compatibility matrix is, I suppose some old gateways don’t know about newer messages
  • The messages you can send, and here is where the problem becomes more complex.
In your case, with your F454 you can see WHO 6 and WHO 8, but you can only send WHO 8 commands; and F453AV can only send WHO 6 commands.
So, given the very restrictive circumstances, I will not build these commands into the integration at this point.
Your best bet is to do what @Costa was trying to do: use the send_message service to send the message you want. If your gateway understands it, it will send it.
@Murazor, as far as I know, you have nothing more to configure. If your device sends DIMENSION 60 humidity values, they will be added to the climate entity. But to be honest, since I don’t have the heating system, I cannot tell you what it looks like in Home Assistant; it’s possible that the humidity value appears as an attribute.
@vix0971, I’ll have a look at the energy entities. For the 4 zones heating, do all zones have the same problem? (Even the “central unit” zone?)
Do you have some logs that could help me find what’s wrong?
Hi @anotherjulien ,
The problem Is found only with the ‘central unit’ zone, the other zones are ok.
I’ve experimented with the script examples/command_session.py from my github repo (https://github.com/karel1980/reopenwebnet) and these are the results I’m getting:
Slight change to the script:
    MESSAGE_INTERVAL=5
    while True:
        await light_off(client)
        await asyncio.sleep(MESSAGE_INTERVAL)
        await light_on(client)
My setup is as follows:
A router with a wired connection to an F545 and a Deco X60 mesh network
macbook connected to the Deco X60 network.
When the Deco network is in router mode (basically the macbook and the F545 are on a different network):
The connection is always lost after 30 seconds.
When the Deco network is in AP mode (i.e. macbook and F545 are on the same network):
The command_session.py script keeps working - as long as I keep MESSAGE_INTERVAL < 30.
HTH,
Karel
Oh, and event sessions keep working, even when the client and the F545 GW are on different networks. That’s why my current implementation of the reopenwebnet mqtt bridge uses a long living event session for the mqtt state topic, and opens a new command session for every message received on the mqtt command topic
Hi, would you mind if we moved this part of the discussion to a separate thread?
I have this issue only with zone1:
And in addition if i set the temperatuere the fancoils starts but on the app it will give me unactive even if is running, any help?
Is this the central unit in a 4 zones system? If so, then I’m already trying to figure out what’s going on :slight_smile:
I have same issue. No central unit - 1’st zone - it changes temperature by itself to 0, 0.2, 8.8, 3.3 etcobraz_2021-10-04_195654
I would appreciate debug logs and the relevant part of the configuration :slight_smile:
No, this is zone 1 with a central unit, i have in total six zone.
Thanks for your help
I have a old Bitcino system, still using telephone landline.
I believe the gateway is the F422. I don’t see any ethernet port on the equipment and the system in not connected to my LAN …
Some images:
https://imgur.com/6m24akJ
https://imgur.com/seKDIkp
https://imgur.com/DmA1gnr
Can you help connect it to Home Assistant?
Do you think it’s possible?
Thank you and great work!
