Legrand/Bticino MyHome
Hi Julien, this is the log
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Negotiating test session.
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:08:38 DEBUG (MainThread) [custom_components.myhome] Sending test session password.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Test session closed.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Creating listening worker.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Opening event session.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Creating sending worker 0
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Negotiating event session.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0## was successfully queued.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*1## was successfully queued.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*2## was successfully queued.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*3## was successfully queued.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*4## was successfully queued.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*5## was successfully queued.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*6## was successfully queued.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Sending event session password.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0## was successfully unqueued by worker 0.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Received: *4*203*#0##
2021-10-05 08:08:39 INFO (MainThread) [custom_components.myhome] Zone 0's mode is set to 'off'.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Received: *4*21*#0##
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0## received response *4*203*#0##.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*1## was successfully unqueued by worker 0.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*1## was successfully sent.
2021-10-05 08:08:39 DEBUG (MainThread) [custom_components.myhome] Message *#4*2## was successfully unqueued by worker 0.
2021-10-05 08:08:40 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*0*0259##
2021-10-05 08:08:40 INFO (MainThread) [custom_components.myhome] Zone 1's main sensor is reporting a temperature of 25.9°C.
2021-10-05 08:08:40 DEBUG (MainThread) [custom_components.myhome] Message *#4*2## received response *#4*1*0*0259##.
2021-10-05 08:08:40 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*12*0245*3##
2021-10-05 08:08:40 INFO (MainThread) [custom_components.myhome] Zone 1's local target temperature is set to 24.5°C.
2021-10-05 08:08:40 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*1##
2021-10-05 08:08:40 INFO (MainThread) [custom_components.myhome] Zone 1's mode is set to 'off'.
2021-10-05 08:08:40 DEBUG (MainThread) [custom_components.myhome] Message *#4*3## was successfully unqueued by worker 0.
2021-10-05 08:08:40 DEBUG (MainThread) [custom_components.myhome] Message *#4*3## received response *4*303*1##.
2021-10-05 08:08:41 INFO (MainThread) [custom_components.myhome] Found gateway: 192.168.1.191
2021-10-05 08:08:41 INFO (MainThread) [custom_components.myhome] Found gateway: 192.168.1.26
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*14*0245*3##
2021-10-05 08:08:41 INFO (MainThread) [custom_components.myhome] Zone 1's target temperature is set to 24.5°C.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*13*00##
2021-10-05 08:08:41 INFO (MainThread) [custom_components.myhome] Zone 1's local offset is set to 0°C.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*7*0*5##
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*8#6*0030##
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Message *#4*4## was successfully unqueued by worker 0.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Message *#4*4## received response *#4*1*13*00##.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Message *#4*4## was successfully sent.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Message *#4*5## was successfully unqueued by worker 0.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*8#8*0400##
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Negotiating test session.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:08:41 WARNING (MainThread) [custom_components.myhome] Connection requires a password but none was provided.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Test session closed.
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*8#5*0030##
2021-10-05 08:08:41 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*8#7*0400##
2021-10-05 08:08:42 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*0*0266##
2021-10-05 08:08:42 INFO (MainThread) [custom_components.myhome] Zone 2's main sensor is reporting a temperature of 26.6°C.
2021-10-05 08:08:42 DEBUG (MainThread) [custom_components.myhome] Message *#4*5## received response *#4*2*0*0266##.
2021-10-05 08:08:42 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*12*0245*3##
2021-10-05 08:08:42 INFO (MainThread) [custom_components.myhome] Zone 2's local target temperature is set to 24.5°C.
2021-10-05 08:08:42 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*2##
2021-10-05 08:08:42 INFO (MainThread) [custom_components.myhome] Zone 2's mode is set to 'off'.
2021-10-05 08:08:42 DEBUG (MainThread) [custom_components.myhome] Message *#4*6## was successfully unqueued by worker 0.
2021-10-05 08:08:42 DEBUG (MainThread) [custom_components.myhome] Message *#4*6## received response *4*303*2##.
2021-10-05 08:08:43 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*14*0245*3##
2021-10-05 08:08:43 INFO (MainThread) [custom_components.myhome] Zone 2's target temperature is set to 24.5°C.
2021-10-05 08:08:43 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*13*00##
2021-10-05 08:08:43 INFO (MainThread) [custom_components.myhome] Zone 2's local offset is set to 0°C.
2021-10-05 08:08:43 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*7*0*5##
2021-10-05 08:08:43 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*8#6*0030##
2021-10-05 08:08:43 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*8#8*0400##
2021-10-05 08:08:43 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*8#5*0030##
2021-10-05 08:08:43 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*8#7*0400##
2021-10-05 08:08:44 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*0*0251##
2021-10-05 08:08:44 INFO (MainThread) [custom_components.myhome] Zone 3's main sensor is reporting a temperature of 25.1°C.
2021-10-05 08:08:44 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*12*0245*3##
2021-10-05 08:08:44 INFO (MainThread) [custom_components.myhome] Zone 3's local target temperature is set to 24.5°C.
2021-10-05 08:08:44 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*3##
2021-10-05 08:08:44 INFO (MainThread) [custom_components.myhome] Zone 3's mode is set to 'off'.
2021-10-05 08:08:44 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*14*0245*3##
2021-10-05 08:08:44 INFO (MainThread) [custom_components.myhome] Zone 3's target temperature is set to 24.5°C.
2021-10-05 08:08:44 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*13*00##
2021-10-05 08:08:44 INFO (MainThread) [custom_components.myhome] Zone 3's local offset is set to 0°C.
2021-10-05 08:08:44 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*7*0*5##
2021-10-05 08:08:45 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*8#6*0030##
2021-10-05 08:08:45 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*8#8*0400##
2021-10-05 08:08:45 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*8#5*0030##
2021-10-05 08:08:45 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*8#7*0400##
2021-10-05 08:08:45 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*0*0261##
2021-10-05 08:08:45 INFO (MainThread) [custom_components.myhome] Zone 4's main sensor is reporting a temperature of 26.1°C.
2021-10-05 08:08:46 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*12*0245*3##
2021-10-05 08:08:46 INFO (MainThread) [custom_components.myhome] Zone 4's local target temperature is set to 24.5°C.
2021-10-05 08:08:46 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*4##
2021-10-05 08:08:46 INFO (MainThread) [custom_components.myhome] Zone 4's mode is set to 'off'.
2021-10-05 08:08:46 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*14*0245*3##
2021-10-05 08:08:46 INFO (MainThread) [custom_components.myhome] Zone 4's target temperature is set to 24.5°C.
2021-10-05 08:08:46 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*13*00##
2021-10-05 08:08:46 INFO (MainThread) [custom_components.myhome] Zone 4's local offset is set to 0°C.
2021-10-05 08:08:46 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*7*0*5##
2021-10-05 08:08:46 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*8#6*0030##
2021-10-05 08:08:46 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*8#8*0400##
2021-10-05 08:08:47 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*8#5*0030##
2021-10-05 08:08:47 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*8#7*0400##
2021-10-05 08:08:47 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*0*0208##
2021-10-05 08:08:47 INFO (MainThread) [custom_components.myhome] Zone 5's main sensor is reporting a temperature of 20.8°C.
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*12*0245*3##
2021-10-05 08:08:48 INFO (MainThread) [custom_components.myhome] Zone 5's local target temperature is set to 24.5°C.
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*5##
2021-10-05 08:08:48 INFO (MainThread) [custom_components.myhome] Zone 5's mode is set to 'off'.
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*14*0245*3##
2021-10-05 08:08:48 INFO (MainThread) [custom_components.myhome] Zone 5's target temperature is set to 24.5°C.
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*13*00##
2021-10-05 08:08:48 INFO (MainThread) [custom_components.myhome] Zone 5's local offset is set to 0°C.
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*7*0*5##
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*8#6*0030##
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*8#8*0400##
2021-10-05 08:08:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*8#5*0030##
2021-10-05 08:08:49 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*8#7*0400##
2021-10-05 08:08:49 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*0*0272##
2021-10-05 08:08:49 INFO (MainThread) [custom_components.myhome] Zone 6's main sensor is reporting a temperature of 27.2°C.
2021-10-05 08:08:49 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*12*0245*3##
2021-10-05 08:08:49 INFO (MainThread) [custom_components.myhome] Zone 6's local target temperature is set to 24.5°C.
2021-10-05 08:08:49 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*6##
2021-10-05 08:08:49 INFO (MainThread) [custom_components.myhome] Zone 6's mode is set to 'off'.
2021-10-05 08:08:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*14*0245*3##
2021-10-05 08:08:50 INFO (MainThread) [custom_components.myhome] Zone 6's target temperature is set to 24.5°C.
2021-10-05 08:08:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*13*00##
2021-10-05 08:08:50 INFO (MainThread) [custom_components.myhome] Zone 6's local offset is set to 0°C.
2021-10-05 08:08:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*7*0*5##
2021-10-05 08:08:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*8#6*0030##
2021-10-05 08:08:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*8#8*0400##
2021-10-05 08:08:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*8#5*0030##
2021-10-05 08:08:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*8#7*0400##
2021-10-05 08:09:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:09:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:09:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:09:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:09:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:09:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## received response *#4*2*13*00##.
2021-10-05 08:09:00 INFO (MainThread) [custom_components.myhome] Message *#1*04## was successfully sent.
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## received response *#4*3*0*0251##.
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] Received: *#13**#1*02*05*10*2021##
2021-10-05 08:10:00 INFO (MainThread) [custom_components.myhome] Gateway broadcasting internal date: 2021-10-05.
2021-10-05 08:10:00 DEBUG (MainThread) [custom_components.myhome] Received: None
2021-10-05 08:10:00 WARNING (MainThread) [custom_components.myhome] Data received is not a message: None
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:11:00 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:11:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:12:00 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:12:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:13:00 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:13:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:14:00 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:14:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:15:00 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*0*0259##
2021-10-05 08:15:00 INFO (MainThread) [custom_components.myhome] Zone 1's main sensor is reporting a temperature of 25.9°C.
2021-10-05 08:15:01 DEBUG (MainThread) [custom_components.myhome] Received: *#4*2*0*0266##
2021-10-05 08:15:01 INFO (MainThread) [custom_components.myhome] Zone 2's main sensor is reporting a temperature of 26.6°C.
2021-10-05 08:15:01 DEBUG (MainThread) [custom_components.myhome] Received: *#4*3*0*0251##
2021-10-05 08:15:01 INFO (MainThread) [custom_components.myhome] Zone 3's main sensor is reporting a temperature of 25.1°C.
2021-10-05 08:15:02 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*0*0261##
2021-10-05 08:15:02 INFO (MainThread) [custom_components.myhome] Zone 4's main sensor is reporting a temperature of 26.1°C.
2021-10-05 08:15:02 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5*0*0208##
2021-10-05 08:15:02 INFO (MainThread) [custom_components.myhome] Zone 5's main sensor is reporting a temperature of 20.8°C.
2021-10-05 08:15:03 DEBUG (MainThread) [custom_components.myhome] Received: *#4*6*0*0272##
2021-10-05 08:15:03 INFO (MainThread) [custom_components.myhome] Zone 6's main sensor is reporting a temperature of 27.2°C.
2021-10-05 08:15:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:16:00 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:16:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Received SHA challenge: *98*2##
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Detected SHA-256 method.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Accepting challenge, initiating handshake.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Received Ra.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Generated Rb.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Received HMAC response.
2021-10-05 08:17:00 DEBUG (MainThread) [custom_components.myhome] Server identity confirmed.
2021-10-05 08:17:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##
Here is when the error appears:
 2021-10-05 08:42:04 ERROR (MainThread) [custom_components.myhome] Could not send message *#1*04##.
2021-10-05 08:42:57 DEBUG (MainThread) [custom_components.myhome] Received: *4*4002#5*0#1##
2021-10-05 08:42:57 DEBUG (MainThread) [custom_components.myhome] Received: *4*4002*5##
2021-10-05 08:42:59 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5#1*#20*5##
2021-10-05 08:42:59 INFO (MainThread) [custom_components.myhome] Unsupported message type: *#4*5#1*#20*5##
2021-10-05 08:42:59 DEBUG (MainThread) [custom_components.myhome] Received: *#4*5#1*20*5##
2021-10-05 08:42:59 INFO (MainThread) [custom_components.myhome] Zone 5's fan is off.
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-05 08:43:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
Hi @obelha
The F422 is a bridge between multiple buses, it can be used to extend the amount of addresses available on you standard automation bus; but also (and in your case I believe) to interconnect the alarm bus to the automation bus.
To be honnest, the simplest solution in your case is to buy an F454 (they’re still sold and are a lot cheaper that the MHS1) and drop it in your installation!
@tomfool1985, could you edit your post and put the logs in a “Preformatted text” block? Otherwise the website understands part of the logs/messages as instructions to put text in italics :confused:
Screenshot 2021-10-05 at 09.09.25
And the F454 would just replace the F422, ie, I just need to connect the wires that connect to both BUS ports in the F422 in the ports of F454?
Thanks for your help!
@obelha no, the F454 does not replace the F422. F422 is not a gateway, it is used to interconnect your alarm bus with the “main” bus.
@tomfool1985, unfortunately your logs don’t show much, there’s only two temperature related messages for zone 1, and both are 25.9°C; so your problem is not shown here
Maybe here:
2021-10-05 12:40:25 DEBUG (MainThread) [custom_components.myhome] Received: *4*0*1##
2021-10-05 12:40:25 INFO (MainThread) [custom_components.myhome] Zone 1's mode is set to 'cool'.
2021-10-05 12:40:25 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*12*0250*3##
2021-10-05 12:40:25 INFO (MainThread) [custom_components.myhome] Zone 1's local target temperature is set to 25.0°C.
2021-10-05 12:40:25 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*13*00##
2021-10-05 12:40:25 INFO (MainThread) [custom_components.myhome] Zone 1's local offset is set to 0°C.
2021-10-05 12:40:31 DEBUG (MainThread) [custom_components.myhome] Message *4*303*#4## was successfully queued.
2021-10-05 12:40:31 DEBUG (MainThread) [custom_components.myhome] Message *4*303*#4## was successfully unqueued by worker 0.
2021-10-05 12:40:31 INFO (MainThread) [custom_components.myhome] Message *4*303*#4## was successfully sent.
2021-10-05 12:40:32 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*4##
2021-10-05 12:40:32 INFO (MainThread) [custom_components.myhome] Zone 4's mode is set to 'off'.
2021-10-05 12:40:32 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*12*0250*3##
2021-10-05 12:40:32 INFO (MainThread) [custom_components.myhome] Zone 4's local target temperature is set to 25.0°C.
2021-10-05 12:40:32 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4*0*0263##
2021-10-05 12:40:32 INFO (MainThread) [custom_components.myhome] Zone 4's main sensor is reporting a temperature of 26.3°C.
2021-10-05 12:40:32 DEBUG (MainThread) [custom_components.myhome] Received: *4*203*#4##
2021-10-05 12:40:33 DEBUG (MainThread) [custom_components.myhome] Message *4*303*#1## was successfully queued.
2021-10-05 12:40:33 DEBUG (MainThread) [custom_components.myhome] Message *4*303*#1## was successfully unqueued by worker 0.
2021-10-05 12:40:33 INFO (MainThread) [custom_components.myhome] Message *4*303*#1## was successfully sent.
2021-10-05 12:40:33 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*1##
2021-10-05 12:40:33 INFO (MainThread) [custom_components.myhome] Zone 1's mode is set to 'off'.
2021-10-05 12:40:33 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*12*0250*3##
2021-10-05 12:40:33 INFO (MainThread) [custom_components.myhome] Zone 1's local target temperature is set to 25.0°C.
2021-10-05 12:40:33 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1*0*0262##
2021-10-05 12:40:33 INFO (MainThread) [custom_components.myhome] Zone 1's main sensor is reporting a temperature of 26.2°C.
2021-10-05 12:40:34 DEBUG (MainThread) [custom_components.myhome] Received: *4*203*#0##
2021-10-05 12:40:34 INFO (MainThread) [custom_components.myhome] Zone 0's mode is set to 'off'.
2021-10-05 12:40:34 DEBUG (MainThread) [custom_components.myhome] Received: *4*21*#0##
2021-10-05 12:40:34 DEBUG (MainThread) [custom_components.myhome] Received: *4*4002#4*0#1##
2021-10-05 12:40:34 DEBUG (MainThread) [custom_components.myhome] Received: *4*4002*4##
2021-10-05 12:40:34 DEBUG (MainThread) [custom_components.myhome] Received: *4*203*#1##
2021-10-05 12:40:34 INFO (MainThread) [custom_components.myhome] Zone 1's mode is set to 'off'.
2021-10-05 12:40:36 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4#1*#20*5##
2021-10-05 12:40:36 INFO (MainThread) [custom_components.myhome] Unsupported message type: *#4*4#1*#20*5##
2021-10-05 12:40:36 DEBUG (MainThread) [custom_components.myhome] Received: *#4*4#1*20*5##
2021-10-05 12:40:36 INFO (MainThread) [custom_components.myhome] Zone 4's fan is off.
2021-10-05 12:40:37 DEBUG (MainThread) [custom_components.myhome] Received: *4*4002#1*0#1##
2021-10-05 12:40:37 DEBUG (MainThread) [custom_components.myhome] Received: *#4*0#1*20*0##
2021-10-05 12:40:37 INFO (MainThread) [custom_components.myhome] Zone 1's actuator 1 is off.
2021-10-05 12:40:37 DEBUG (MainThread) [custom_components.myhome] Received: *4*4002*1##
2021-10-05 12:40:39 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1#1*#20*5##
2021-10-05 12:40:39 INFO (MainThread) [custom_components.myhome] Unsupported message type: *#4*1#1*#20*5##
2021-10-05 12:40:39 DEBUG (MainThread) [custom_components.myhome] Received: *#4*1#1*20*5##
2021-10-05 12:40:39 INFO (MainThread) [custom_components.myhome] Zone 1's fan is off.
2021-10-05 12:41:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#1*04##
2021-10-05 12:41:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#1*04##
2021-10-05 12:41:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-05 12:41:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully queued.
2021-10-05 12:41:00 DEBUG (MainThread) [custom_components.myhome] Message *#1*04## was successfully unqueued by worker 0.
Hi found a MH200N in second hand at a good price (100€). F454 price is around 500€.
Do you think MH200N will also do the work?
Thanks!
@obelha usually in France it’s very easy to find a brand new F454 under 200€, the website I usually order on lists it at 135€ (but they only ship in France).
But MH200N should work as well I suppose, I think there are users with this gateway successfully using this integration. You can search in this thread or ask around.
@tomfool1985, I’m having some doubts now, are we talking about the measured temperature or the set temperature? If my memory is correct the small number is the set temperature, right?
I don’t understand how it could be set to 0.6, because the system only allows increments of 0.5 anyway… I you find any logs that mentions this 0.6 degrees, whatever happens just before and after that is what I’m looking for!
Hi. It’s my log:
I’m really stumped, none of the logs provided by anybody show anything out of the ordinary :frowning:
Is everyone having problem ONLY with zone 1?
Can you all give me the part of the yaml config for the zone that is affected?
Mh200n and F454 are both official openwebnet Gateway.
F454 has more power (is the same hardware of myhomeserver1).
If you plan to use cen frames please use F454. Mh200n don’t publish cen frames.
Bye
Sandro
Yep, only 1’st zone :frowning: I have 20 zones and it is problem with only first zone :open_mouth:
Config:
climate:
  - platform: myhome
    devices:
      zone_1:
        zone: '1'
        heat: True
        cool: False
        standalone: True
        manufacturer: BTicino
        model: H4691
      zone_2:
        zone: '2'
        heat: True
        cool: False
        standalone: True
        model: H4691
Hi Julien,
these are the logs
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0#81## was successfully unqueued by worker 0.
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Received: *4*103*#0#81##
2021-10-06 00:14:14 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=#0
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Received: *4*21*#0#81##
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0#81## received response *4*103*#0#81##.
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Message *#4*82## was successfully unqueued by worker 0.
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Message *#4*82## was successfully sent.
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Message *#4*83## was successfully unqueued by worker 0.
2021-10-06 00:14:14 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*0*0244##
2021-10-06 00:14:14 INFO (MainThread) [custom_components.myhome] Zone 82's main sensor is reporting a temperature of 24.4°C.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#4*83## received response *#4*82*0*0244##.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*14*0130*3##
2021-10-06 00:14:15 INFO (MainThread) [custom_components.myhome] Zone 82's target temperature is set to 13.0°C.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#4*84## was successfully unqueued by worker 0.
2021-10-06 00:14:15 ERROR (MainThread) [homeassistant.components.google_assistant.http] No configuration for request_sync available
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully queued.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully queued.
2021-10-06 00:14:15 INFO (MainThread) [custom_components.myhome] Found gateway: 192.168.1.35
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*12*0120*3##
2021-10-06 00:14:15 INFO (MainThread) [custom_components.myhome] Zone 82's local target temperature is set to 12.0°C.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*82##
2021-10-06 00:14:15 INFO (MainThread) [custom_components.myhome] Zone 82's mode is set to 'off'.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#4*84## received response *#4*82*12*0120*3##.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## was successfully unqueued by worker 0.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## received response *#4*82*14*0130*3##.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*13*11##
2021-10-06 00:14:15 INFO (MainThread) [custom_components.myhome] Zone 82's local offset is set to -1°C.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully unqueued by worker 0.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully sent.
2021-10-06 00:14:15 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:14:16 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*0*0237##
2021-10-06 00:14:16 INFO (MainThread) [custom_components.myhome] Zone 83's main sensor is reporting a temperature of 23.7°C.
2021-10-06 00:14:16 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## received response *#4*83*0*0237##.
2021-10-06 00:14:16 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*14*0130*3##
2021-10-06 00:14:16 INFO (MainThread) [custom_components.myhome] Zone 83's target temperature is set to 13.0°C.
2021-10-06 00:14:16 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:14:16 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*12*0130*3##
2021-10-06 00:14:16 INFO (MainThread) [custom_components.myhome] Zone 83's local target temperature is set to 13.0°C.
2021-10-06 00:14:16 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*83##
2021-10-06 00:14:16 INFO (MainThread) [custom_components.myhome] Zone 83's mode is set to 'off'.
2021-10-06 00:14:16 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## received response *#4*83*12*0130*3##.
2021-10-06 00:14:17 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*14*0130*3##
2021-10-06 00:14:17 INFO (MainThread) [custom_components.myhome] Zone 83's target temperature is set to 13.0°C.
2021-10-06 00:14:17 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*13*01##
2021-10-06 00:14:17 INFO (MainThread) [custom_components.myhome] Zone 83's local offset is set to 1°C.
2021-10-06 00:14:17 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*0*0243##
2021-10-06 00:14:17 INFO (MainThread) [custom_components.myhome] Zone 84's main sensor is reporting a temperature of 24.3°C.
2021-10-06 00:14:17 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*14*0130*3##
2021-10-06 00:14:17 INFO (MainThread) [custom_components.myhome] Zone 84's target temperature is set to 13.0°C.
2021-10-06 00:14:18 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*12*0130*3##
2021-10-06 00:14:18 INFO (MainThread) [custom_components.myhome] Zone 84's local target temperature is set to 13.0°C.
2021-10-06 00:14:18 DEBUG (MainThread) [custom_components.myhome] Received: *4*303*84##
2021-10-06 00:14:18 INFO (MainThread) [custom_components.myhome] Zone 84's mode is set to 'off'.
2021-10-06 00:14:18 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*14*0130*3##
2021-10-06 00:14:18 INFO (MainThread) [custom_components.myhome] Zone 84's target temperature is set to 13.0°C.
2021-10-06 00:14:18 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*13*00##
2021-10-06 00:14:18 INFO (MainThread) [custom_components.myhome] Zone 84's local offset is set to 0°C.
2021-10-06 00:14:19 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*51*19545323##
2021-10-06 00:14:19 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting a total power consumption of 19545323 Wh.
2021-10-06 00:14:19 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*51*152904##
2021-10-06 00:14:19 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting a total power consumption of 152904 Wh.
2021-10-06 00:14:19 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*1200#1*125##
2021-10-06 00:14:19 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:14:19 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:14:19 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*1200#1*125##
2021-10-06 00:14:19 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*258##
2021-10-06 00:14:19 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 258 W.
2021-10-06 00:14:26 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:14:26 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:14:35 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*251##
2021-10-06 00:14:35 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 251 W.
2021-10-06 00:14:45 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0#81*#14*0120*3## was successfully queued.
2021-10-06 00:14:45 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0#81*#14*0120*3## was successfully unqueued by worker 0.
2021-10-06 00:14:45 DEBUG (MainThread) [custom_components.myhome] Message *#4*#0#81*#14*0120*3## received response *#4*83*14*0130*3##.
2021-10-06 00:14:45 DEBUG (MainThread) [custom_components.myhome] Received: *4*110#0120*#0#81##
2021-10-06 00:14:45 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=#0
2021-10-06 00:14:45 DEBUG (MainThread) [custom_components.myhome] Received: *4*21*#0#81##
2021-10-06 00:14:45 DEBUG (MainThread) [custom_components.myhome] Received: *4*22*#0#81##
2021-10-06 00:14:46 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81*13*00##
2021-10-06 00:14:46 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
2021-10-06 00:14:47 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81*0*0241##
2021-10-06 00:14:47 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
2021-10-06 00:14:48 DEBUG (MainThread) [custom_components.myhome] Received: *4*1*81##
2021-10-06 00:14:48 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
2021-10-06 00:14:48 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81*12*0120*3##
2021-10-06 00:14:49 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*0*0244##
2021-10-06 00:14:49 INFO (MainThread) [custom_components.myhome] Zone 82's main sensor is reporting a temperature of 24.4°C.
2021-10-06 00:14:49 DEBUG (MainThread) [custom_components.myhome] Received: *4*1*82##
2021-10-06 00:14:49 INFO (MainThread) [custom_components.myhome] Zone 82's mode is set to 'heat'.
2021-10-06 00:14:49 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*12*0110*3##
2021-10-06 00:14:49 INFO (MainThread) [custom_components.myhome] Zone 82's local target temperature is set to 11.0°C.
2021-10-06 00:14:49 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81*14*0120*3##
2021-10-06 00:14:49 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
2021-10-06 00:14:49 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*14*0120*3##
2021-10-06 00:14:49 INFO (MainThread) [custom_components.myhome] Zone 82's target temperature is set to 12.0°C.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*0*0237##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 83's main sensor is reporting a temperature of 23.7°C.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *4*1*83##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 83's mode is set to 'heat'.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*12*0130*3##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 83's local target temperature is set to 13.0°C.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*14*0120*3##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 83's target temperature is set to 12.0°C.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*0*0243##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 84's main sensor is reporting a temperature of 24.3°C.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *4*1*84##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 84's mode is set to 'heat'.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*12*0120*3##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 84's local target temperature is set to 12.0°C.
2021-10-06 00:14:50 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*14*0120*3##
2021-10-06 00:14:50 INFO (MainThread) [custom_components.myhome] Zone 84's target temperature is set to 12.0°C.
2021-10-06 00:14:55 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81#1*20*0##
2021-10-06 00:14:55 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
2021-10-06 00:14:56 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:14:56 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:14:57 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*256##
2021-10-06 00:14:57 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 256 W.
2021-10-06 00:14:58 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83#1*20*0##
2021-10-06 00:14:58 INFO (MainThread) [custom_components.myhome] Zone 83's actuator 1 is off.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully queued.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully queued.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:14:59 INFO (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully sent.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## received response *#4*84*0*0243##.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*1200#1*125##
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:14:59 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*1200#1*125##
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*258##
2021-10-06 00:14:59 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 258 W.
2021-10-06 00:14:59 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84#1*20*0##
2021-10-06 00:14:59 INFO (MainThread) [custom_components.myhome] Zone 84's actuator 1 is off.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully queued.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully queued.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## received response *#4*84*12*0130*3##.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## received response *#4*84*14*0130*3##.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*1200#1*125##
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:15:00 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*1200#1*125##
2021-10-06 00:15:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*256##
2021-10-06 00:15:00 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 256 W.
2021-10-06 00:15:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## was successfully queued.
2021-10-06 00:15:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully queued.
2021-10-06 00:15:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## was successfully unqueued by worker 0.
2021-10-06 00:15:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## was successfully sent.
2021-10-06 00:15:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully unqueued by worker 0.
2021-10-06 00:15:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## received response *#18*55*51*19545323##.
2021-10-06 00:15:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully sent.
2021-10-06 00:15:08 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*51*19545323##
2021-10-06 00:15:08 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting a total power consumption of 19545323 Wh.
2021-10-06 00:15:08 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*51*152904##
2021-10-06 00:15:08 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting a total power consumption of 152904 Wh.
2021-10-06 00:15:18 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*250##
2021-10-06 00:15:18 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 250 W.
2021-10-06 00:15:26 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:15:26 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:15:34 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*264##
2021-10-06 00:15:34 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 264 W.
2021-10-06 00:15:53 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*250##
2021-10-06 00:15:53 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 250 W.
2021-10-06 00:15:56 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:15:56 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:15:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully queued.
2021-10-06 00:15:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully queued.
2021-10-06 00:15:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:15:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## received response *#18*53*51*152904##.
2021-10-06 00:15:59 INFO (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully sent.
2021-10-06 00:15:59 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:15:59 INFO (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully sent.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] message to be sent: *#13**15##
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] OWN Message: *#13**15##
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] message valid
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#13**15## was successfully queued.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#13**15## was successfully unqueued by worker 0.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Command session connection reset, retrying...
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Opening command session.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully queued.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully queued.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Negotiating command session.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Reply: *#*1##
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Received nonce: *#044768194##
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Sending command session password.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Command session established.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Received: *#13**15*200##
2021-10-06 00:16:00 INFO (MainThread) [custom_components.myhome] Gateway device type is: F454.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#13**15## received response *#13**15*200##.
2021-10-06 00:16:00 INFO (MainThread) [custom_components.myhome] Message *#13**15## was successfully sent.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:16:00 INFO (MainThread) [custom_components.myhome] Message *#18*55*#1200#1*125## was successfully sent.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully unqueued by worker 0.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*1200#1*125##
2021-10-06 00:16:00 INFO (MainThread) [custom_components.myhome] Message *#18*53*#1200#1*125## was successfully sent.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*113*2##
2021-10-06 00:16:00 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting an active power draw of 2 W.
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*1200#1*125##
2021-10-06 00:16:00 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*255##
2021-10-06 00:16:00 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 255 W.
2021-10-06 00:16:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## was successfully queued.
2021-10-06 00:16:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully queued.
2021-10-06 00:16:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## was successfully unqueued by worker 0.
2021-10-06 00:16:07 DEBUG (MainThread) [custom_components.myhome] Received: *#18*55*51*19545323##
2021-10-06 00:16:07 INFO (MainThread) [custom_components.myhome] Sensor 5 is reporting a total power consumption of 19545323 Wh.
2021-10-06 00:16:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## received response *#18*55*51*19545323##.
2021-10-06 00:16:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*55*51## was successfully sent.
2021-10-06 00:16:07 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully unqueued by worker 0.
2021-10-06 00:16:08 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*51*152904##
2021-10-06 00:16:08 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting a total power consumption of 152904 Wh.
2021-10-06 00:16:08 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## received response *#18*53*51*152904##.
2021-10-06 00:16:08 DEBUG (MainThread) [custom_components.myhome] Message *#18*53*51## was successfully sent.
2021-10-06 00:16:11 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81*0*0241##
2021-10-06 00:16:11 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
2021-10-06 00:16:12 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*0*0244##
2021-10-06 00:16:12 INFO (MainThread) [custom_components.myhome] Zone 82's main sensor is reporting a temperature of 24.4°C.
2021-10-06 00:16:12 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81*14*0120*3##
2021-10-06 00:16:12 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
2021-10-06 00:16:12 DEBUG (MainThread) [custom_components.myhome] Received: *#4*82*14*0120*3##
2021-10-06 00:16:12 INFO (MainThread) [custom_components.myhome] Zone 82's target temperature is set to 12.0°C.
2021-10-06 00:16:13 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*0*0237##
2021-10-06 00:16:13 INFO (MainThread) [custom_components.myhome] Zone 83's main sensor is reporting a temperature of 23.7°C.
2021-10-06 00:16:13 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83*14*0120*3##
2021-10-06 00:16:13 INFO (MainThread) [custom_components.myhome] Zone 83's target temperature is set to 12.0°C.
2021-10-06 00:16:13 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*0*0243##
2021-10-06 00:16:13 INFO (MainThread) [custom_components.myhome] Zone 84's main sensor is reporting a temperature of 24.3°C.
2021-10-06 00:16:13 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84*14*0120*3##
2021-10-06 00:16:13 INFO (MainThread) [custom_components.myhome] Zone 84's target temperature is set to 12.0°C.
2021-10-06 00:16:14 DEBUG (MainThread) [custom_components.myhome] Received: *#18*53*113*263##
2021-10-06 00:16:14 INFO (MainThread) [custom_components.myhome] Sensor 3 is reporting an active power draw of 263 W.
2021-10-06 00:16:17 DEBUG (MainThread) [custom_components.myhome] Received: *#4*83#1*20*0##
2021-10-06 00:16:17 INFO (MainThread) [custom_components.myhome] Zone 83's actuator 1 is off.
2021-10-06 00:16:19 DEBUG (MainThread) [custom_components.myhome] Received: *#4*84#1*20*0##
2021-10-06 00:16:19 INFO (MainThread) [custom_components.myhome] Zone 84's actuator 1 is off.
2021-10-06 00:16:19 DEBUG (MainThread) [custom_components.myhome] Received: *#4*81#1*20*0##
2021-10-06 00:16:19 WARNING (MainThread) [custom_components.myhome] Unknown device: WHO=4 WHERE=81
This is the configuration of zone 1
climate:
  - platform: myhome
    devices:
      central_unit:
        zone: '81'
        name: termo soggiorno
        heat: True
        cool: False
        central: True
        standalone: False
        model: HC4695
@anotherjulien yes it the target one.
Another question, i have for each fancoil the F430/4 and the H4691, what do i have to put on the config?
Now i have f430/4 and this works excepet for zone 1 and it is not able to recognize if it is cooling.
climate:
  - platform: myhome
    devices:
      central_unit:
        zone: "#0"
        heat: True
        cool: True
        standalone: False
        model: 3550
      zone_1:
        zone: "1"
        heat: True
        cool: True
        standalone: False
        model: F430/4
I just notice that the value change to 0,somenthig when i change the temperature of other thermostat
Hi @anotherjulien ,
my system is up and running and i believe i will switch off the openHab server soon.
The idea to use the Mh202 + CEN+ + a script ( to trigger the CEN+ command) to overcome possible limitation, works perfectly in fact i use this way to open my gate and it’s also working with alexa.
Now here my question for you: in my system i also have the BT3486 alarm… are you interested to implement it? I can give you all openwebnet 5 codes and, of course, test it!
Let me know. Bye
Hi @Costa, no I’m not planning on adding the alarm system at the moment.
I see little value in doing so since it’s read only and even so does not provide much information.
@tomfool1985, @vix0971 or @XDUSS; could one of you provide me with the debug logs from Home Assistant core along with the integration debug logs during an occurence of the issue.
HA Core debug logs should clearly show the entity being updated, hopefully that would give more clues… :confused:
Hi @anotherjulien,
I agree with you that what is written from the openwebnet code 5 is just to collect the alarm status but i believe there is a trick to engage and disangage (also zone partialisation) the alarm from Home Asistant. I was waiting your answer to decide to make some test to make sure my idea works or leave it in case you was focusing on other implementation.
@anotherjulien If you explain to me how to take it i will.
Thanks any how for your collaboration.
