No matter how long I search or reading docs, I cannot find a place how to create a localized blueprint.
What I mean is, either translate an existing blueprint (additional language than English), or create a new with several languages.
Is this currently not possible or am I missing some … ?
Good point. I’m working a lot with this NSPanel blueprint and it is a pain to keep it translated with all the translations.
It would be nice to have some translation engine for blueprints or if one could get translations strings from Home Assistant via a template, but as far as I know, this is not available.
But why don’t you write this as a feature request?
Before I digg deeper into your code, how do you perfom this now (still a novice to HA, but I am learning … coming from a web developer world, and here are many things are handled in other ways …).
thx!
I’ve run into similar challenges while working on localization for some of my projects. From what I’ve found, creating a localized blueprint (or translating an existing one) might not be straightforward in some platforms, but there are workarounds! If you can’t find a direct option, sometimes setting up language-specific versions of your blueprint manually works, especially if you’re dealing with UI elements
