Log changes to climate.temperature in the same way as input_boolean or other entities
Home Assistant doesn’t record changes to a climate entity’s setpoint temperature attribute. This makes is difficult to work out what or who has changed it. There is no obvious documentation to set up such recording.
See also
I would like to see climate setpoint logged in a similar way to how I observe changes to an input_boolean that shows which device, entity, automation or user made the change.
I would add as well current state. Like, Started Cooling, Stopped Cooling, etc
+1 I would also be interested in tracking who change the temp state, happened last night but have no idea what changed it or who.
Same, I’m using the Ecobee integration, it never logs set point changes. :frowning:
Yes this is really a bummer :expressionless:
It’s a major bummer that this is not a thing. Is it difficult to add? Or not enough people want this?
I have instances where multiple different users could change the set-point and not knowing who changed it is really frustrating.
I have the same problem. Twice this month, the heating turned up at random times during the night. I have no idea why this is happening. As a workaround, I made an automation that turns the heat down when it passes a threshold and checks every hour. Not ideal…
Massive oversight and obvious fatal flaw.
Would be good to see this ‘fixed’.
