Lovelace: Banner card
If anyone is interested, I managed to embed a simple-thermostat air conditioner card and a multiple-entity-row card into the banner-card card. The picture shows an example display.
I would be grateful if someone shares their experience of displaying TV. In my example, from is not displayed conveniently.
Hi all!
First of all : I love this card :slight_smile:
But i need to change the size of the icons…
How do i do this?
Hi all,
I am using this card but for some reason it isn’t displaying the toggles for lights… I already restarted the instance.
Am I missing something?
use this in your theme, or in card-mod
–mdc-icon-size: 0px;
How do I get this theme/layout? Can you share the code? I love the translucent look with the shadowing
Did you find a solution for this? Am currently experiencing the same issue
Edit: using this repository as a custom HACS addition fixed it (GitHub - crempp/banner-card at 0.13.3)
No, unfortunately I still have the same issue. I think I already have this installed:
Hello, for some reason my light button is not showing in the screen. Any suggestions what’s is happening ? Same happens with other entities: lights, switches. The entities came integrated from Smart Life integration. Here is the code:
type: custom:banner-card
style: |
  ha-card .heading {
    color: white;
    font-size: 32px;
    margin-top: 30px;
    margin-bottom: 30px;
background: '#EDE7B0'
heading: 🛋 Living room
link: /lovelace/living_room
entities:
  - entity: sensor.sensor_temperatura_superior_temperature
  - entity: light.swt_cozinha_lavanderia_switch_1
  - entity: light.fibaro_system_fgd212_dimmer_2_level_11
  - entity: sensor.air_temp
  - entity: sensor.sensor_temperatura_superior_humidity
Screenshot 2023-05-10 172005
UPDATE: FIXED BY changing the repo to manual one. Link: https://community.home-assistant.io/t/lovelace-banner-card/117293/306
Yes. it id fix the problem. Just added the custom repo, reinstall and update screen. THX
Hi there, I have just created a banner card without much configuration. However, the alignment of the cover controls (Curtain Roller) appears to be leaning towards the bottom. Am I missing something? Thanks in advance!
heading:
  - 🛏️ Master Bedroom
entities:
  - entity: switch.10009457dc_3
      service: script.toggle_ewelink
    map_state:
      'on':
        color: yellow
        value: mdi:track-light
      'off':
        color: black
        value: mdi:track-light-off
  - entity: cover.0x54ef44100032a5d9
  - entity: sensor.0x54ef44100032a5d9_device_temperature
Tried to single out the control in a separate card and the results is the same.
(As I am a new user, I cannot embed another image).
Hello , I want on off button but not show , please help me what is missing
only name show ( Lights )
also i have same problem , u have got solution?
I hope you know the different between a “button” and an “icon” as i referred to, in the “old” commend
http://homeassistant.local:8123/hacs/repository/186765704
( The Manual )
PS: And do also notice that this card seems “abandoned” !, latest fix was more than a year ago, and since then also PR are not “handled”, and simple questions not answered
Try use this Fork instead
Screenshot of my cards:
Love your cards!
How did you manage to get backgrounds working for some reason I am unable to get mine to work. I have code as follows but they just stay blank…
background: url:("local/test2.jpg")
heading:
  - mdi:bed-empty
  - Test Room
entities:
  - entity: light.flower_lamp
      service: light.toggle
    map_state:
      'on':
        color: deeppink
        value: mdi:flower-outline
      'off':
        color: teal
I’m sorry to say that I cannot help you. I rebuilt my whole home assistant when I moved a few weeks ago and did not go with banner cards this time. :frowning: And, I don’t remember how I did it when it set it up a couple of years ago.
Hi, have the same question and didn’t found anything helpful. Have you found a solution for your problem?
The syntax on your url method call is wrong - you need to remove the colon.
Try background: url("local/test2.jpg").
I’m not sure if you can reference local media like that, as I’ve always hosted externally, but it might help.
for me its working with : background: url(/local/flur.jpg) … loose the double quote also make sure you have your picture in ./config/www on the host
Really like this banner-card, one question though.
I have a sensor/entity and it displays to up to 7 decimals. When I click on it > cog wheel > precision, I can change it to 2 decimals, but it doesn’t change in the graph itself. When I use another card (mini-card graph, for example) I do get the right figure (2 decimals).
Anyone got a solution?
