ciotlosm
(Marius)
July 10, 2018, 9:06pm
1
BigNumber card
With various people requesting larger numbers for sensors we got to here. The card supports showing one big number but also severity colors with bar.
You can find the code here
Instructions
The instructions are also found on the above repo.
Download bignumber-card.js
Place the file in your config/www folder
Include the card code in your ui-lovelace.yaml
resources:
- url: /local/bignumber-card.js?v=1
type: js
Note: You can change v=1 to a higher number whenever updating code to avoid having to clear cache in all browsers
Write configuration for the card in your ui-lovelace.yaml
- type: custom:bignumber-card
title: Humidity
entity: sensor.outside_humidity
scale: 30px
min: 0
max: 100
severity:
- value: 70
style: 'var(--label-badge-green)'
- value: 90
style: 'var(--label-badge-yellow)'
- value: 100
style: 'var(--label-badge-red)'
Reload your Lovelace tab (no need to restart Home Assistant or other things) and you should see the card.
FAQ: GitHub - ciotlosm/lovelace-thermostat-dark-card: 🌡 Thermostat card with a round and black feel to it · GitHub
Options
Name
Type
Default
Description
type
string
Required
title
string
optional
Name to display on card
scale
string
50px
Base scale for card: '50px'
entity
string
Required
sensor.my_temperature
min
number
optional
Minimum value. If specified you get bar display
max
number
optional
Maximum value. Must be specified if you added min
from
string
left
Direction from where the bar will start filling (must have min/max specified)
severity
list
optional
A list of severity objects. Items in list must be ascending based on 'value'
Severity object
Name
Type
Default
Description
value
number
Required
Value until which to use this severity
style
number
Required
Color of severity. Can be either hex or HA variable. Example: 'var(--label-badge-green)'
WARNINGS
Make sure you use ascending object values to have consistent behaviour
Values are the upper limit until which that severity is applied
NigelL
(Nigel)
July 10, 2018, 11:32pm
2
Looks good! I have to say I’m impressed with the rate of progress you guys are making!
This is awesome. With the power of Lovelace, I’m worried the community will make awesome cards like this and they’ll get lost in the shuffle. There should be a Lovelace card App Store or even a forum topic here to help organize where users can find custom (non-official) cards.
This also makes me want custom-tiles-ui ported to a Lovelace card.
Klagio
(Klagio)
August 30, 2018, 7:18am
7
ciotlosm:
value: 70 style: ‘var(–label-badge-green)’ - value: 90 style: ‘var(–label-badge-yellow)’ - value: 100 style: ‘var(–label-badge-red)’
this is not working anymore?
title: Outside temp.
entity: sensor.yr_temperature
scale: 35px
severity:
red: 28
green: 0
amber: 24
Klagio
(Klagio)
August 30, 2018, 7:21am
8
I changed from this
scale: 35px
severity:
red: 28
green: 0
amber: 24
to this
scale: 35px
severity:
- value: 0
- value: 24
- value: 28
now it shows back the cards, but not the colours (its white background )
ciotlosm
(Marius)
August 31, 2018, 7:37am
9
You need to add min/max otherwise it won’t show.
Klagio
(Klagio)
August 31, 2018, 7:42am
10
I see. In my case I would rather have the FULL badge coloured (in temperature if below 20 green, between 20 and 26 yellow and red above 26), and not a bar. Like it was before
Is ithis possible?
ciotlosm
(Marius)
September 1, 2018, 2:31am
11
I can add that as enhancement
Klagio
(Klagio)
September 1, 2018, 5:11am
12
Thanks a lot.
In previous version was working
Klagio
(Klagio)
November 3, 2018, 1:29pm
13
Receiveing this error now on 0.81.4
http://192.168.1.10:8123/local/bignumber-card.js?v=0.0.1:86:52 Uncaught TypeError: Cannot read property ‘state’ of undefined
14:25 components/system_log/init .py (ERROR
AndreaF
(Andrea)
November 6, 2018, 8:20pm
14
This is the card I was looking for!! Though I use only the “big number” part… thank you very much ciotlosm
ohadbenita
(Ohad Benita)
November 10, 2018, 9:38am
15
Thanks a lot, been using it widely in my setup @ciotlosm
I do have a suggestion to make - can we have it so it will open a URL or make another action on-click ?
deviant
(deviant)
November 11, 2018, 4:41pm
16
In some reason severity doesn’t work for me.
entity: sensor.living_room_humidity
title: Living Room
scale: 20px
min: 0
max: 100
severity:
- value: 0
style: '#ff0000'
- value: 30
- value: 50
style: #FF0000
- value: 70
style: 'var(--label-badge-blue)'
All my cards are default blue
rawash
November 28, 2018, 9:42am
17
I am trying to use this card to display the current Electricity price and highlight if the current price is within 20% of the min predicted price for the day. My Electricity provider publishes the min and max price for the day via a sensor parameter.
The problem is, if I mention the sensor name against entity I don’t have the option to calculate the relative value of the sensor against the min and max.
Can someone suggest a way to use a calculated value instead of the default entity value ?
@ciotlosm ,
Thanks for this. This is exactly what I am looking for to display time on my panel.
However, I wish I can put my date sensor entity in the title: variable so that the date will appear below the time like this…
moon
(Maciej Moon Maciejowski)
December 11, 2018, 7:48am
19
You need proper indent after severity (put 2 spaces before - value)
severity:
- value: 0
style: '#ff0000'
- value: 30
- value: 50
style: #FF0000
- value: 70
deviant
(deviant)
December 11, 2018, 8:22am
20
thanks for the reply!
yes, i aware of indentation. the problem was in values order i guess. i treated 30 as 30 and above and should treat as 30 and below. silly mistake.
