@Ildar_Gabdullin , if you want to set a specific option that’s the way you do it. But my question is about how to set the select value using the dropdown directly read from the select options! There should be a way to do it, right?
I can use the entities card, but it uses too much space and it has too many gadgets (icon, text, underline, etc) and uses too much space, see the image below. And the other problem is that the dropdown list gets cut in the upper part, so you don’t see the upper values and cannot reach them ???, as shown below…
@Ildar_Gabdullin “overflow: visible” doesn’t fix the problem, unfortunately. I think it seems to be related to the fact that the card is at the bottom of the view and it is small, so the dropbox needs to open up instead of down and gets cut by the upper view…, it’s very bad.
The following image shows the problem with the views next to it:
I don’t know whether the stack-in-card will help? I haven’t use it yet. It seems to be a card for many items?
For the 2nd question, the dropdown needs to show the selected item and if the user changes the item, the select entity needs to be updated with that item. So in my case, the user needs to change the time using the dropbox…
Since you have not posted a code - people have to guess here. But - please - do not post the whole code, post only a minimal snippet where you are facing a problem with overflowing (which cannot be fixed with my “overflow: visible” code).
Hard to believe - but this is exactly the way how every “input_select” works).
User selects a value → the state of the “input_select” is updated to the selected value.
I saw only that code you posted - and this is not a code of the whole card, just a code for “tap_action”.
As well as this new code - this is a part related to a “srtrelatslct” custom field inside some unknown button-card.
And this part contains the misplaced “styles” part from my example.
And since this part is misplaced - you are getting a wrong result.
I would suggest to test with simple cards and proceed with complex cases step by step.
You’re right, the code was misplaced, thanks for the tip!
Now I managed to hide some items, but I would like to reduce the space between the options. What is the property I need to change?
OK. For the 2nd question, what I mean is whether there is a card that does exactly what the standard dropdown does, but with easier to configure styles?
