Is there a way to make like some sort of dpad so the butoons touch and there is no gap in between them.
Check out stack-in-card (also by RomRider). It allows you to stack cards without any paddings, making them look like one entire card. These are button-cards an a different card entirely under those, all together inside a stack-in-card:
Keep in mind that stack-in-card doesnât support grid, only vertical and horizontal modes. So if you want to create a grid, you have to nest multiple stack-in-cards in horizontal and vertical mode.
Other way might be using card-mod with a margin variable, but Iâm not sure.
Using the name is not optimal (if you want to name the button).
It is better to use a variable
type: custom:button-card
variables:
back: |
if (entity.state == 'on') {history.back() ;}
show_icon: true
icon: mdi:arrow-left
styles:
img_cell:
- width: 24px
card:
- border-radius: 30px
- box-shadow: var(--box-shadow)
- height: 36px
- width: auto
- padding-left: 6px
- padding-right: 6px
grid:
- grid-template-areas: '"l"'
- grid-template-areas: '"i"'
label:
- justify-self: center
- padding: 0px 6px
- font-weight: bold
- font-size: 14px
tap_action:
action: toggle
entity: input_boolean.back
show_name: false
show_state: false
show_label: true
right, and for the fun of it I added the forward button too:
- type: custom:button-card
template: button_shortcut_menu
tooltip: Forward
icon: mdi:arrow-right
show_name: false
tap_action:
action: toggle
entity: input_boolean.forward_button
variables:
next: |
if (entity.state == 'on') {history.forward() ;}
as you can see in my card config, I use tooltip, to hove and display. Thats perfect for all other views, but for these back and forwards, I would love to see the view in the history. Cant find that in inspector, so not sure if at all possible. Would you know of some extra witchcraft??
Would you like to share your cat code?
Iâve actually changed my dashboard a lot since then and donât use any of that any more. As for Cat, itâs actually just the light in the Cat room (where my foster cats live).
My main dashboard looks like this now. Loads more quickly and I can see everything about my home at a glance.
Pity for me. But very nice! Is this tablet view or desktop view?
Is there any way to apply a gradient background-color to a notification field? When I apply the code below, it just goes transparent for the option that should turn gradient. I essentially want the notification field in the top right to be a gradient of green and blue if the result of my entity is âbothâ. All other solid colours work fine, just the gradient that doesnât.
notification:
- background-color: >
if (states['[[notification_entity]]'].state === 'on')
return "var(--green)";
if (states['[[notification_entity]]'].state === 'pool')
return "var(--blue)";
if (states['[[notification_entity]]'].state === 'vege')
if (states['[[notification_entity]]'].state === 'both')
return 'linear-gradient(90deg, #8AB8A2, #5391AE)';
Donât you need to define percentages so the gradient knows when one color stops and the next one starts? Try using this tool and copy/paste the code into your style: https://cssgradient.io/
Percentages are not required. You can even use simple
[[[ return 'linear-gradient(to right, blue, green)' ]]]
(resp. to left, to bottom, to top).
or - for a more scalable result -
[[[ return 'linear-gradient(to right, rgb(30, 144, 255), rgb(50, 205, 50))' ]]]
Just tried with the below, doesnât seem to work:
return "linear-gradient(135deg, rgba(138,184,162,1) 0%, rgba(83,145,174,1) 100%)";
Will try your solution, but I did try very similar to that and didnât work. Wondering if the background-color attribute just doesnât accept gradients?!!?
thanks for testing! Strange! Iâll change it to a solid colour to rule out one or the other and report back
What browser are you using out of interest? I am using IOS and Safari, think my issue might be I need -webkit- as well?!?! Will try again tomorrow anyway
Also i(Pad)OS and Safari. Did you try without conditions?
- background: 'linear-gradient(135deg, rgba(138,184,162,1) 0%, rgba(83,145,174,1) 100%)'
Where am I going wrong?
The icon is only this size, I wanted the icon to occupy the entire card as in the exampleâŠ
Could someone help me please?
example:
follow my code:
- type: horizontal-stack
cards:
- type: 'custom:button-card'
entity: switch.ty03584357f4cfa2340d6b
icon: 'hass:fridge-outline'
layout: vertical
show_icon: true
show_name: false
show_state: true
styles:
card:
- height: 172px
- width: 130px
icon:
- height: 104px
- width: 104px
custom_fields:
notification:
- position: absolute
- left: 48%
- top: 40%
- font-size: 18px
- font-weight: bold
- color: var(--primary-color)
name:
- font-size: 12px
state:
progress! Changed it from âbackground-colorâ to âbackgroundâ only worked for the condition less option Will now change based on conditions and see how I go. Thanks a bunch for your help!
Thanks again, all working now changing to âbackgroundâ. Cheers!
Hello guys, maybe some of you can help me.
Iâm trying to center the name and the label of a button card, but without success.
I did it with the img_cell without any problem, but the same method seems not working very well with the other two objects.
See the screenshot below:
As you can see, all the names and labels are shifted to the right side.
Here is the template iâm using:
climate:
show_icon: true
show_state: false
label: |
var mode = entity.state;
if (entity.state == 'cool'){
var mode = 'Freddo';
} else if(entity.state == 'dry'){
var mode = 'Deumidificatore';
} else if(entity.state == 'heat'){
var mode = 'Caldo';
} else if(entity.state == 'heat_cool'){
var mode = 'Auto';
} else if(entity.state == 'fan_only'){
var mode = 'Ventilatore';
} else if(entity.state == 'off'){
var mode = 'Spento';
return mode;
tap_action:
action: more-info
styles:
card:
- border-radius: 20px
- padding: 10px 0px 8px 0px
grid:
- grid-template-areas: '"i i i" "n n n" "l l l"'
name:
- margin-top: 10px
- place-self: center
- font-weight: bold
- font-size: 14px
label:
- align-self: start
- font-weight: bolder
- font-size: 12px
- filter: opacity(40%)
icon:
- width: 34px
img_cell:
- marging-top: 5px
- border-radius: 50%
- width: 42px
- height: 42px
Can someone help me?
Thanks!
