I just mean wait and see if it works before thanking me.
Installation with HACS works. No problem.
Card with the player, do not successfully create.
My intention is to use android tablet as the main display and control unit. Every member of the family will be able to control the heating. Weather forecast and other information available. I want to add an internet radio playerā¦ I donāt have alexa or anything like that.
Thatās probably my main problem.
If you do not have a media player integrated into home assistant then this card is useless to you.
In fact why you have asked numerous questions about a media player card when you donāt have a media player is very mysterious, but never mind.
You can view the buit-in media player integrations here https://www.home-assistant.io/integrations/#media-player
My very first post in reply to you pointed you to the install instructions that included how to install with hacs.
The reason I did not suggest hacs later was that you had already started the manual install and I did not want to confuse you further.
I thought the tablet was a multimedia player.
what is needed for this player is not written anywhere. Just one sentence in the guide to install. I could have saved a lot of words.
Iāll try to go
Yes it probably can play multimedia, most tablets can. However whether it can be integrated into HA is the question. I have referred you to the integrations page. Other than to do that, please open a new thread so that this one is not further polluted by your refusal to understand anything we say to you. Feel free to tag me in, I am happy to try and help you but this is not the place This thread is for a specific lovelace card for peope who already have a media_player
configured. You do not.
all dirt can be removed
Please
thank you
I have a multi-zone setup (casatunes) and the integration i use exposes each zone as itās own
media_player
and each source as a media_player
, but only the source- media_players have media info, so what happens is that when i add my media player for each room/zone, I donāt get any meta like track info and cover.
I know I can combine media players but I doesnāt look right to me and itās not minimal.
Iād really like to display media_* attributes in the zone media_player for selected source, is there an easy way to do this with mini media player? Or if not, maybe someone have a clever idea on how to do it?
Hello guys,
Is there a way to set an artwork when the media_player is off?
What I mean is: when the player is on, i have the Artwork of what itās currently playing.
Can I have the Artwork of the last played media when my Apple TV is off?
If I may piggy back off this: Iāve been wondering about this too. As an alternative, Iāve experimented with displaying a default image of sorts, but couldnāt find something that worked.
If I may double piggyback: Iām trying to set an artwork or background that shows when the media player has no artwork available (like Chromecast url streams and some other streams). I could not set this up, so I think this is not an option.
No, not the last artwork but you can set a background which will be displayed when thereās no artwork available. See the background
option in the documentation.
Might however be bugged in the latest release, will see if I can fix this weekend if so.
Hi, is it possible to show the background in a full-cover-fit style if thereās no artwork? So showing it like a square instead of a banner? I basically am trying to show all mini media player cards at the exact same size, with or without artwork
No, best bet would be card-mod.
Thatās too bad. Gonna see if I can get it to work with card mod then, thanks!
Hi @kalkih
I noticed you fixed the background disappearing issue with a PR over the weekend, thanks for the quick response. Is there a way to pull the dev build in HACS or are you going to do a release for this?
Thanks again.
Brad
Hi, I tried to create a custom card with this code:
type: custom:mini-media-player
entity: media_player.spotify_xxxxx
artwork: cover
hide:
artwork_border: true
icon_state: false
but it gives me this error:
Error: Custom element not found: mini-media-player
I have HACS installed on my Homeassistant on rasp, on my lovelace resource I have:
URL
/hacsfiles/mini-media-player/mini-media-player.js
Type
Javascript Module
can someone help me with this error? thanks!
refresh your browser. ctrl-f5
nopeā¦ same issue:
Custom element doesn't exist: mini-media-player.
type: 'custom:mini-media-player'
artwork: cover
hide:
icon_state: false
