So that is through the more-info card I assume. It also looks like you have an “OFF” and “Heat” button on your card however I don’t see any buttons on mine. Unfortunately it looks like I won’t be able to use this card any more. I’ll keep my eye on it should anything change, I did like the simplicity of it but I do need those buttons to show for it to work for me. Thanks
That I understand.
Just screenshot of standard thermostat card. Also not having the non-standard buttons.
Can you post your config for the above?
For my TADO, it is nice to control at least the basics through HA, however, think you always need to use the original app to do advanced basic settings like schedules etc.
So HA (at least for me) is only the basic card for control and especially see the current status.
/Ralf
Hi @Ralf
My lovelace config is this:
entity: climate.eurotronic_eur_spiritz_wall_radiator_thermostat_heat_3
modes:
Full Power:
include: false
Heat Eco:
include: false
Manufacturer Specific:
include: false
'off':
include: true
sensors:
- entity: sensor.thermostat_bedroom_battery
step_size: 0.5
type: 'custom:simple-thermostat'
Those include: false
are no longer important. Before 0.96 I hide that way the buttons I do not want to show. Now they are gone themselves.
For advanced scheduling I am using this:
I just tried to mimic your setup in mine and it amazes me that I can’t at the very least get the ‘Off’ button to show. I wonder why it seems so different?? If I could get that at least to show I could continue using this card
I tried that, this is what it shows but still no luck. I tried both “modes” and I tried “hvac_modes” as it shows below. Neither approach shows the buttons.
This is what the card shows:
Reinstall the beta 0.26 , it should work. I am not sure why it did not work for me in the first install.
Same for me.
With the first installation no buttons, I’ve clicked on the reinstall button and now the buttons are there.
Thanks!
Oh my gosh, I reinstalled and the buttons appeared.
same for me
Also reinstalled and modes appeared again.
Strange, but solved.
Thanks for the help!
So I know I’ve brought this up before, but it’s still doing the issue of when I press up/down, the number reverts instantly. However, if I let it sit for about 10 seconds, it will change. It’s almost as if it’s waiting for the thermostat (Sensi in my case) to get the change for Wink/Sensi and then has to confirm with HA. Any idea if it would be possible to put some sort of visual delay where the temperature stays there for 10-15 seconds while it tries to make the change? The official thermostat card works fine this way.
I managed to get card-mod to work (the replacement for card-modder).
This is in a manual card.
entity: climate.thermostat
style: |
ha-card {
--st-font-size-xl: 20px;
--st-font-size-m: 12px;
--st-font-size-title: 14px;
--st-font-size-sensors: 14px;
--st-spacing: 2px;
header {
margin-bottom: 0px !important;
padding-bottom: 0px !important;
sensors:
- entity: sensor.thermostat_humidity
step_size: 1
I have the opposite problem of you all… I’m trying to turn the mode buttons off. Is there something wrong with what I’m doing below? Can the mode buttons actually be deactivated?
- type: custom:simple-thermostat
entity: climate.entrance
step_size: 0.5
hide:
state: true
modes:
'Off':
include: false
Heat:
include: false
Likely need to check your modes and confirm that they’re all in single quotes as well as capitalization matches.
Ah you nailed it. I thought it would be the same as the buttons, but when I looked for the actual names in the entities, they were lowercase and that did it. Kept the quotes the same.
I’m using a Honeywell Evohome system which has hvac_mode settings for just “heat” and “off”, but most of the useful mode selection is done in the preset_mode selection, which has similar modes to what you show for Tado for a scheduled or permanent or temporary manual mode… Can I ask you if you managed to get the buttons working for preset_mode, or were you lucky enough to have all that in the hvac_mode?
If you did it with just hvac_mode, does anyone out there know if it’s possible to have the buttons control preset_mode? See example entity below:
