Seems that you have not defined the entity.
I also think so, just I do not know what I’m supposed to do, you can give an example.
thanks
How did you define your custom:button-card? Could you please post its code?
I see that the temperatures are there, so it’s a problem with the icon templates. Both normal and collapse cards work in my home assistant, so I can’t understand why this happens in your configuration
I tried two codes:
a:
- type: custom:button-card
template: vacuum
variables:
entity: vacuum.vacuum
b:
- type: custom:stack-in-card
mode: vertical
style: |
ha-card{
border-radius: 21px;
cards:
template: vacuum
variables:
template: card_1_line_4_actions_select_vacuum_fan_speed
triggers_update:
- sensor.aspiro_fan
variables:
item1_background_entity: sensor.aspiro_fan
item1_background_state: GENTLE
item1_icon: mdi:water
item2_background_entity: sensor.aspiro_fan
item2_background_state: SILENT
item2_icon: mdi:fan
item2_icon_scale: 0.75
item3_background_entity: sensor.aspiro_fan
item3_background_state: STANDARD
item3_icon: mdi:fan
item3_icon_scale: 1.3
item4_background_entity: sensor.aspiro_fan
item4_background_state: TURBO
item4_icon: mdi:fan
item4_icon_scale: 2
Your entity vacuum.vacuum
has no states in capital letters. Try it with
label: |-
if (entity.state == 'docked' && entity.attributes.battery_level == '100'){
return 'On its base';
- Is
vacuum_info:
correctly indented?
wow, thats awesome. Will have a detailled look at it! Thank you very much for all your configs!
Thanks for the help,
I changed according to what you said - and unfortunately I still get an error.
code:
vacuum_info:
tap_action:
action: none
icon: mdi:robot-vacuum
label: |-
if (entity.state.toUpperCase() == 'docked' && entity.attributes.battery_level == '100'){
else if (entity.attributes.status.toUpperCase() == 'charging'){
return 'In charge';
else if (entity.state.toUpperCase() == 'cleaning'){
return 'Cleaning in progress';
else if (entity.attributes.status.toUpperCase() == 'retuning home'){
return 'Back to its base';
else if (entity.attributes.status.toUpperCase() == 'pause'){
return 'On break';
else{
return '❓ Unknown ❓' ;
styles:
icon:
- color: |-
return 'rgba(var(--couleur-gris),1)';
return 'rgba(var(--couleur-vert),1)';
return 'rgba(var(--couleur-jaune),1)';
return 'rgba(var(--couleur-violet),1)';
return 'rgba(var(--couleur-bleu),1)';
else{
img_cell:
- background-color: |-
return 'rgba(var(--couleur-gris),0.2)';
return 'rgba(var(--couleur-vert),0.2)';
return 'rgba(var(--couleur-jaune),0.2)';
return 'rgba(var(--couleur-violet),0.2)';
return 'rgba(var(--couleur-bleu),0.2)';
else{
in the file button_card_templates.yaml
Look for:
### VERTICAL BUTTONS (fka SCENES) ###
Sorry, I did not see this part. I’m just working on it now and updates
nice !
the theme seems be to very popular. All custom card should be post on github in order to have an “database”
I tried like this:
vacuum_info:
tap_action:
action: none
label: |-
return 'on its base';
else if (entity.state == 'charging'){
return 'in charge';
else if (entity.state == 'cleaning'){
return 'cleaning in progress';
else if (entity.state == 'docked' && 'retuning home'){
return 'back to its base';
else if (entity.state == 'pause'){
return 'on break';
else{
return '❓ unknown ❓' ;
styles:
icon:
- color: |-
else if (entity.state == 'retuning home'){
else{
img_cell:
else{
And so: Unfortunately it does not work.
vacuum_info:
tap_action:
action: none
label: |-
return 'in charge';
return 'on break';
else{
styles:
icon:
- color: |-
else{
img_cell:
else{
You are using a template called „vacuum“ in your button-card. But in your template I can see „vacuum_info“ (which is not indented properly I think).
v1.0.0-beta.11
Hi guys, we hope all of you have had a good start to the new year.
Over the holidays it was also a bit quieter for us, which is why we have a pre-release with bug fixes and new translations for you at the beginning of the year.
But also a few new cards from @mp-se have made it into this release. Try them out: New custom cards and update of existing ones by mp-se · Pull Request #154 · UI-Lovelace-Minimalist/UI · GitHub
As you may have noticed, @Paddy0174 has also reported back in the discussion area of the repo: Relocation of the repo · Discussion #158 · UI-Lovelace-Minimalist/UI · GitHub
This makes us very happy and means that the repo can stay where it is. Paddy still needs a little time to recover and get up to speed, and then hopefully he’ll be back in full swing.
@stokkie90 has also been busy in the meantime and has continued to work on the HACS support for the Minimalist UI. You can follow the current state of work here WIP: Hacs Support by stokkie90 · Pull Request #168 · UI-Lovelace-Minimalist/UI · GitHub
If you like, you can also help us to find a new logo for the HACS release. Of course we are also grateful for further feedback. Just have a look at the discussions on the Github repo or our Discord server.
see you soon
Features
- #154 New custom cards and update of existing ones @mp-se
Code enhancements
- #149 Update button_card_templates.yaml 13robin37
- #170 armed_away state for alarm chip @denes44
Bug Fixes
- #155 Update card_light_icon_info.yaml basbruss
- #156 Fix custom_card_saxel blue style card @saxel
- #153 Fix battery_card icon color when state is unavailable @saxel
- #146 fix Card “card_media_player_with_controls” (missing variable “ulm_card_media_player_with_controls_entity”) vncnt-dev
- #183 Light Slider unavailable color @schumijo
- #182 Update chips_icon_label to use base chips template @schumijo
Translations
- #163 Add Polish translations for cards desty2k
- #176 Portuguese Translation kaphwor
- #181 Missing variables in new language files @denes44
- #184 Update ES.yaml revin34
Documentation
- #169 Update README_popups.md @KaherdinTristan
- #173 Update README_popups.md @schumijo
Thank you so much for helping out to keep this UI awesome
Thank you very much. You should take the wiki with a grain of salt though. During @paddy0174 's absence it is practically not updated and therefore currently quite outdated. We still have some catching up to do here
Tell us where we can help
