hi Guys, Is there a way to hide the tapbar when scrolling and can you customize the tapbar as you wish? regards
Glad it worked!
As for the picture, I assume you are referring to the button icon.
If so, you can enable the icon for it.
As for the state, itās a bit tricky to explain given that I donāt know your current set-up.
This heater that you are controlling via Google Assistant SDK, is it in any way accessible in Home Assistant? If itās a state only entity and canāt control it just add it to this button so you can see its state:
type: button
icon: "mdi:heat-wave" #or whatever icon you like
entity: switch.your_heater_entity #entity of the device you'd like to know the state
show_state: true
tap_action:
action: call-service
service: google_assistant_sdk.send_text_command
command: "turn on bedroom heater"
New to the UI Minimalist project but already loving it!
I am wondering if I can change the decimal point into a comma for all the cards. I think some cards did display it like that but every card that uses a temperature (room card, graph card etc) use a point.
I have my profile settings set accordingly
My ānormalā Lovelace dashboard displays all the values as shown.
I assume I can edit the Template Code of the cards to replace the decimal point but I am just wondering if there is a central place I can change this.
Thanks for any help!
Iām trying to call a script from the script card but canāt seem to pass a variable:
- type: 'custom:button-card'
template: card_script
variables:
ulm_card_script_title: 'VRT Nieuws'
ulm_card_script_icon: 'mdi:radio'
tap_action:
service: script.turn_on
service_data:
entity_id: script.play_news_on_speaker
radio_speaker: ārobbyā
Specifically the radio_speaker variable. I get the following error:
Failed to call service script/turn_on. extra keys not allowed @ data['radiospeaker']
What is the correct way to pass an extra variable with this card?
Have you tried this instead?
tap_action:
Example: Iāve got a main script, that I use - and use the data to specify the variables
speech_engine_female:
sequence:
- condition: state
entity_id: group.family
state: home
- service: tts.cloud_say
data_template:
entity_id: "{{ who }}"
message: "{{ message }}"
cache: true
language: nb-NO
options:
gender: female
husk_ta_ut_av_vaskemaskin_tts:
sequence:
- condition: state
state: home
- service: script.speech_engine_female
who: media_player.kjokken
message: !include include/tts/husk_ta_ut_av_vaskemaskin_tts.yaml
how can you change the images on the scene card in such a way that a full screen is taken over from the scenes?
I
would like to control hue scenes there and take over the images of the scenes. these should then be displayed there as a full circle.
Hi all,
I am using room card but cannot activate icons for cover (opened /closed)
where did I wrong?
- type: "horizontal-stack"
cards:
template:
- card_room
- red_no_state
entity: climate.termostato_bagno_piccolo_p1
icon: mdi:shower-head
tap_action:
action: navigate
navigation_path: '/ui-lovelace-minimalist/BagnoPiccolo'
variables:
label_use_temperature: true
label_use_brightness: true
entity_1:
icon: mdi:lightbulb
entity_id: switch.luci_bagno_piccolo
templates:
- yellow_on
tap_action:
action: toggle
entity_2:
entity_id: cover.tapparelle_bagno_piccolo
templates:
- blue_on
tap_action:
action: toggle
thanks
Hey all,
I have followed up step by step the tuto to install and create the first buttons etc and it works nicely on my laptop. However when I visualize the outcome on my mobile (android) all icons are black⦠what am I missing ?
Merci !
Make sure you are using the correct theme on your device under your settings
Argh!!! Newbee in action!!! Merci this solved it.
Iām trying to make some cards of my own but it is frustratingly bad explained, or i just cant find it⦠Anyone wanna help??
how can i use the card_room with popup_thermostat?
First try:
- type: horizontal-stack
cards:
template:
- ulm_translation_engine
- card_room
- grey_no_state
- grey_on
- grey_off
entity: climate.schlafzimmer_dect301_1
icon: mdi:bed-king
hold_action:
action: none
tap_action:
action: "fire-dom-event"
browser_mod:
service: "browser_mod.popup"
large: true
hide_header: true
content:
type: "custom:button-card"
template: "popup_thermostat_temperature"
entity: "[[[ return entity.entity_id ]]]"
This card is empty, how can i give him the right āentity: climate.schlafzimmer_dect301_1ā ?
what you need?
I want to make a card with a time bar that count down, that i also can toggle an entity with⦠Iāve managed to piece a little bit together by the cards there alreadyā¦
custom_card_eric_countdown2:
template:
- "ulm_actions_card_overlay"
variables:
ulm_card_weather_backdrop: false
ulm_card_weather_primary_info: "extrema"
ulm_card_weather_secondary_info: "precipitation"
show_icon: false
show_name: false
show_label: false
styles:
grid:
- grid-template-areas: "'item1'"
- grid-template-columns: "1fr"
- grid-template-rows: "min-content"
- row-gap: "12px"
card:
- border-radius: "var(--border-radius)"
- box-shadow: "var(--box-shadow)"
- padding: "0px"
custom_fields:
item1:
card:
type: "custom:timer-bar-card"
entity: "timer.kaffebryggaren_timer"
name: Kaffebryggaren stƤngs av om
invert: true
bar_width: calc(70% - 7em)
bar_height: 60px
bar_radius: 20px
layout: full_row
bar_foreground: '#89b3d7'
bar_background: '#3c4b64'
unit: minutes
tap_action:
service: switch.toggle
service_data:
entity_id: switch.kaffebryggaren
style: |
ha-card {
border-radius: 14px;
box-shadow: none;
Red is what Iāve used but it take up unnecessary space. Green is what the card looks like now (code above).
Bottom is what i want it to look like (excuse my amazing paint skills
)ā¦
So, for example, how do I learn how layouts work? Where do all the template for different things come from? Actions?
These thing, how should i know?
styles:
card:
check this:
This code is for custom:button-card. It allows to manage css styles for elements inside the card.
Styling may be done by using card-mod too (see a link in the post above). Card-mod is a plug-in which allows access to css styles of a card.
Custom button-card in general does not need using card-mod - it has its own functionality (see a code you posted).
What are css styles in general - google about it, search for ācss tutorialā etc.
Hey, I have updated to the latest version of the room-card, before that I had colors on the icons depending on the state of the entity.
After updating I canāt see those colors anymore.
Raw Configuration:
http://pastie.org/p/4V0r1KQr15lPoTzwl9BEvA
Card:
Any idea how can I fix that?
Thanks!
Can you be more specific on what update you have installed? The cardās latest update is from at least 3 months ago. It seems like you are using an unsupported installation method based on the raw-configuration.
I donāt have anything in mind that I changed something on the Raw Configruation.
but when I run Watchman report I get those two errors that might be related to my issue:
number.match | missing | custom_components/ui_lovelace_minimalist/lovelace/translatio |
| | | ns/default.yaml:18,28 |
| climate.hvac | missing | custom_components/ui_lovelace_minimalist/lovelace/ulm_templa |
| | | tes/popup_templates/popup_buttons/popup_button_airconditionn |
| | | er.yaml:22
How can I fix this?
Thanks!
