Hi Again,
Iām sure itās been asked before and maybe already answered but I didnāt find any answer.
This is a bit frustrating. I had an SD-card failure and my last snapshot was over a year old so I lost my configs where I had the custom weather card working. Now when re-engineering the configs I donāt manage to get the custom card working. Get the famous āCustom element doesnāt exist: weather-card-chart.ā.
What is going on?
Note: I added the repo as a custom repo
in HACS and installed the weather card chart from there.
Any help is highly appreciated.
SOLVED: Found the answer, keep my post if someone else have the same issue even though itās been answered beforeā¦
The resources section has moved from the ui-lovelace.yaml to the configuration.yaml:-)
Strange that my old config worked before the SD-card breakdown though.
I also have the fix from the .27 version, cleared caches and did refresh from ā¦ menu, but still no graphs on .115.5ā¦ :-(. I went and manually verified that I had the same changes included in PR#43, and I doā¦ But no graphā¦
If youāre using nginx (or another proxy) see if you have caching content enabled there. I did on mine, and it took me a while to see that this was the reason it wasnt working even after the changes and cache clearing on my local browser.
You can also try accessing it via the local IP (and not the URL) since this should bypass the proxy server, and see if itās still broken.
No proxy, already accessing with local IPā¦ also tried via Nabu Casa. Itās not working on any of 5 devices running 3 OSes and combination of local and remote URL. I even tried it on a brand new computer with a browser that had never connected to my dashboard before.
Actually I just noticed that it does actually work for my daily card using open weather map, but not my hourly card using dark sky. Must be something either with the daily view or dark sky.
Iām running into the Custom element doesn't exist: weather-card-chart. error some other users have found. Iām probably overlooking something small but I just canāt figure out what it is. I have the js file from the repo in my config/www folder.
Hi all, has anyone gotten the rain bar chart to show on an hourly forecast using Dark Sky? Iām just not a good enough programmer to figure out why this isnāt working.
Yean but thatās the card for a whole week, mine is for a single day. Mine works for a whole week too, but not for just a day with the hourly forecast.
