(York_Yu_Chan)
You will find a link at the top of this series of postings I.E. post number one.
It will take you to the GitHub page.
Also
https://github.com/Yevgenium/lovelace-weather-card-chart
(York_Yu_Chan)
Also
All seems to be working well but am having an issue with the bar chart. I assume this shows rain in inches and not snowā¦ But even if snow here in +New England we are not getting 21 inches. I have not seen any way to influence this reading.
Update: Checked Open Weather States and see they are reporting 21 for Tuesday. Assume this is not inches but mm. Wonder how to have it graph in inches.
Iām still having trouble, How did you fix the card config?
If I remember correctly just by removing the ā-ā at the beginning.
Thanks, got it to work following the instructions, but make sure you have OpenWeatherMap integration installed. I didnāt so I had to change āweather.openweathermapā to āweather: weather.homeā because I have Meteorologisk institutt integration installed instead.
easier to do that is to use styles, though the page still has to load the info, and the hide it. It would be nice that your code gets added in the main version of the plug-in as an option, maybe post it in GitHub!
If anyone else wants the code:
type: 'custom:weather-card-chart'
weather: weather.xxxxxxxxx
mode: daily
style: |
.main {
display: none !important;
.attributes {
Hi all, in case anyone is interested, I created a fork of the card with the below fixes/changes. It may not work well for everyone, especially people using openweathermap as that was the service that the card was designed for (it seems).
My card works well with smartweather weather stations, though, and might be better for anyone who has an hourly weather source but wants a 24 hour graph (current card draws 9 hours). Here is the list of my changes:
I certainly wonāt promise you the code is good as I have little real world programming experience and really only practiced programming in school 30 years ago, but it works well for me. I might make it a little better if someone had interest in it (but no promises).
Anyhow, you can find it here
Also, Iād be curious to know if there are any other well maintained forks out there. There are an awful lot of PRās open against this one which implement fairly needed features, I would be happy if I could start following someone who was more actively maintaining the card.
Hi all, is it possible to replace weather icons with those of the standard [colored] HA weather card? (I canāt figure it out how to refer them properly from the script.)
I think you could replace roundNumber(weatherObj.attributes.pressure) with a call of smth like this:
computePressure(hpa) {
var calcMmhg = Math.round(hpa / 1.333);
return calcMmhg;
cool, will have a look.
you missed one Pr though https://github.com/Yevgenium/lovelace-weather-card-chart/pull/44
moving from km/h to m/s is āagainstā HA defaults though, youāre sure you want to do so?
that is for the integration itself of course, not necessarily for a frontend cardā¦
My goal is definitely not to integrate all the open PRāsā¦ But there are more Iām considering to look atā¦ I think to make my version useful to everyone, I will first have to make some of my changes optional, so maybe that should be a higher priority.
As for the wind speed, it seemed that no matter what I did, my weather component was reporting m/s which the card was then attempting to convert and making wrong, so just commenting out the conversion was the easiest fix for me.
Maybe I should tell the maintainer of the smartweather component that it should be doing conversion to km/h by default. I have had to notify him of other things such as using ānullā instead of zero for rain amounts.
cool, looking forward to a new and better card. the Pr is only minor, but is a certain improvement, check the position of the top icons, which are now aligned correctly:
You are right, that was bugging me too. Added it. Looks like you have a nice version as well. I will see if I can get mine to a state thatās a bit more fit for general use, but you might consider doing your own fork?
I feel so stupid, canāt get this goingā¦
Error message:
Component error: resources - Integration āresourcesā not found.
Input in configuration.yaml:
resources:
-type: module
url: /local/weather-card-chart.js
What am I missing?
Nope, It doesnāt work, I tried with:
Lovelaceās resource:
Manual Card Config:
Also, can I add my own sensor for humidity and pressure? I have my own weather station.
OK, fixed it. When adding a resource to Lovelace all you need to do is make sure it doesnāt contain:
āresources: - type: module url:ā but just the link to the card.
The question still stands, can I replace weather humidity and pressure with my own sensor data?
If the card uses the weather entity no. There are custom cards you can use that will let you though.
beta 2021.6 throws a warning on. raised an issue in the repo
bar chart: "scales.[x/y]Axes.maxBarThickness" is deprecated. Please use "dataset.maxBarThickness" instead
I dont know yet how to replace that in the resource, so Ive commented the line completely, and seeing no difference
however, it might be nice to know how to correct the code, so if anyone would be able to help out here?
thanks!
Update
I did add this in the datasets list:
maxBarThickness: 15,
and see no errors. However, I dont see anything changed either, so not sure this does anything at allā¦
it is loaded correctly alright:
just as a FYI: this card is broken as of 2021.7, because of changed core charts.
Dont have details yet, but running the beta now, and it is chartless
and 2 fixes are live!:
PR by @koying Bump to ChartJs3 (mandatory for 2021.7). Fixes #59 by koying Ā· Pull Request #60 Ā· Yevgenium/lovelace-weather-card-chart Ā· GitHub
and a fork by @fancygaphtrn GitHub - fancygaphtrn/lovelace-weather-card-chart: Custom weather card with charts
now that this is fixed, I notice my ll(str)
doesnt work, and it always shows the locale.enā¦ guess because my HA instance uses the English language I never noticed, but I do in fact have a weather-card-chart config using:
type: custom:weather-card-chart
title: Woensdrecht
weather: weather.buienradar
temp: sensor.buienradar_feel_temperature
locale: nl
so I want it to display the nl strings. Anyone else notice this?
should this line:
this.lang = this._hass.selectedLanguage || this._hass.language;
be changed to use the this.config.locale
edit, yes, it should:
this.lang = this.config.locale || this._hass.language;
does the trickā¦ cant believe we never stumbled over this before?
hereās my adaptation with animated icons:
