Maxi Media Player
Maxi Media Player
Maxi Media Player for Home Assistant UI with a focus on managing multiple media players!
Features:
  • Group/Ungroup speakers
  • Control multiple speakers
  • Play favorites from list
  • Media browser button
  • Control individual volumes in a group
  • Artwork background
  • Possibility to override artwork
  • Shuffle and repeat mode
  • Theming
  • Configurable styling
  • Dynamic volume level slider
  • Track progress bar
and more!
Support the project
Do you like the Maxi Media Player? Support the project with a coffee :coffee:
BMC
Installation
With HACS (recommended)
Recommended way of installing this card is with HACS Home Assistant Community Store.
Without HACS
  1. Download this file: maxi-media-player.js
  2. Add this file into your /www folder
  3. On your dashboard click on the icon at the right top corner then on Edit dashboard
  4. Click again on that icon and then on Manage resources
  5. Click on Add resource
  6. Copy and paste this: /local/maxi-media-player.js?v=1
  7. Click on JavaScript Module then Create
  8. Go back and refresh your page
  9. You can now click on Add card in the bottom right corner and search for Maxi Media Player
  10. After any update of the file you will have to edit /local/maxi-media-player.js?v=1 and change the version to any higher number
Usage
Individual sections
By default, all sections of the card is available, and you can jump between them in the footer of the card.
However, you can also select individual sections to enable. Use this if you want to show the different sections next to
each other (by adding multiple instances of the card with different sections enabled).
By using the section configuration you can utilise the full power of Home Assistant’s layout capabilities and also drag in other cards in your Dashboard view.
Configuration
Use the Visual Editor in Home Assistant to configure the card. Most options are available there.
Configuration in YAML
type: custom:maxi-media-player
entities: # Required unless you specify entityPlatform
  - media_player.kitchen_player
  - media_player.hallway_player
  - media_player.bedroom_player
  - media_player.livingroom_player
excludeItemsInEntitiesList: true # Will invert the selection in the `entities` list, so that all players that are not in the list will be used.
entityPlatform: sonos # will select all entities for this platform. Will override the `entities` list if set.
All settings below are optional
# common for all sections
title: ''
sections: # see explanation further up
  - volumes
  - groups
  - grouping
  - media browser
  - player
widthPercentage: 75 # default is 100. Use this to change the width of the card.
heightPercentage: 75 # default is 100. Use this to change the height of the card. Set to 'auto' to make the card height adjust to the content.
footerHeight: 4 # default is 5. Unit is 'rem'. Use this to change the height of the footer.
entityId: media_player.bedroom # Forces this player to be the selected one on loading the card (overrides url param etc)
entityNameRegexToReplace: ' PLAYER' # Regex pattern to replace parts of the entity names
entityNameReplacement: ''
volumeStepSize: 1 # Use this to change the step size when using volume up/down. Default is to use the step size of Home Assistant's media player integration.
adjustVolumeRelativeToMainPlayer: true # default is false, which means all players will be set to the same volume as the main player. If set to true, volume will be adjusted relative to the main player in the group.
sectionButtonIcons: # customize icons for the section buttons
  player: mdi:ab-testing
  mediaBrowser: mdi:star-box-multiple
  groups: mdi:multicast
  grouping: mdi:group
  volumes: mdi:volume-high
mediaTitleRegexToReplace: '.wav?.*' # Regex pattern to replace parts of the media title
mediaTitleReplacement: ' radio' # Replacement for the media title regex pattern
# groups specific
groupsTitle: ''
hideGroupCurrentTrack: true # default is false, which means song/track info for groups will be shown
# grouping specific
groupingTitle: ''
predefinedGroups: # defaults to empty
  - name: Inside
    volume: 15 # If you want to set the volume of all speakers when grouping
    unmuteWhenGrouped: true # If you want to unmute all speakers when grouping
    entities:
      - media_player.hall
  - name: Kitchen&Hall
    media: Legendary # If you want to start playing a specific favorite when grouping
    entities: # Use below format if you want to set the volume of the speakers when grouping
      - player: media_player.kitchen
        volume: 10
      - player: media_player.hall
        volume: 5
  - name: All (except TV)
    excludeItemsInEntitiesList: true # Invert entities selection, so that all players will be grouped except those in the entities list
    entities:
      - media_player.tv
skipApplyButtonWhenGrouping: true # default is false. Will skip the apply button when grouping.
dontSwitchPlayerWhenGrouping: true # default is false. Will not switch to another player if main player is ungrouped.
groupingButtonIcons: # Use this to set custom icons for the grouping buttons.
  predefinedGroup: mdi:account-group # default is mdi:speaker-multiple
  joinAll: mdi:account-multiple # default is mdi:checkbox-multiple-marked-outline
  unJoinAll: mdi:account-remove # default is mdi:minus-box-multiple-outline
# player specific
hidePlayerControlNextTrackButton: true # default is false, hides player control next track button.
hidePlayerControlPrevTrackButton: true # default is false, hides player control previous track button.
hidePlayerControlRepeatButton: true # default is false, hides player control track repeat mode button.
hidePlayerControlShuffleButton: true # default is false, hides player control track shuffle mode button.
hidePlayerControlPowerButton: true # default is false, hides player control power button if media player TURN_ON feature is enabled.  This setting does nothing if media player TURN_ON feature is not supported.
showVolumeUpAndDownButtons: true # default is false, shows buttons for increasing and decreasing volume
showFastForwardAndRewindButtons: true # default is false, shows fast forward and rewind buttons
fastForwardAndRewindStepSizeSeconds: 60 # default is 15 seconds
labelWhenNoMediaIsSelected: 'No media selected'
labelForTheAllVolumesSlider: 'All volumes'
mediaArtworkOverrides: # Show your own selected artwork if certain rules match
  - mediaTitleEquals: TV
    imageUrl: https://cdn-icons-png.flaticon.com/512/716/716429.png
    sizePercentage: 40
  - mediaContentIdEquals: "x-htastream:RINCON_949F3EC2E15B01400:spdif"
    imageUrl: https://cdn-icons-png.flaticon.com/512/4108/4108783.png
  - mediaTitleEquals: p4malmo-aac-192
    imageUrl: >-
      https://mytuner.global.ssl.fastly.net/media/tvos_radios/2BDTPrpMbn_cTdteqo.jpg
  - mediaArtistEquals: Metallica
    imageUrl: >-
  - mediaAlbumNameEquals: "Master of Puppets"
    imageUrl: >-
  - mediaChannelEquals: "Sky Radio Smooth Hits"
    imageUrl: https://cdn-icons-png.flaticon.com/512/4108/4108794.png
  - ifMissing: true # ifMissing will only be used if none of the "Equals" overrides above resulted in a match
    imageUrl: https://cdn-icons-png.flaticon.com/512/651/651758.png
customFavorites: # Read more in 'Custom Favorites' section below
  media_player.tv: # set this to 'all' to show the custom favorite for all players
    - title: TV # Must match the name of the source (unless you specify media_content_id/type as shown below)
      thumbnail: https://cdn-icons-png.flaticon.com/512/716/716429.png
  all:
    - title: BBC
      media_content_id: media-source://radio_browser/98adecf7-2683-4408-9be7-02d3f9098eb8
      media_content_type: music
      thumbnail: http://cdn-profiles.tunein.com/s24948/images/logoq.jpg?t=1
dynamicVolumeSlider: true # default is false. See more in section further down.
dynamicVolumeSliderThreshold: 30 # default is 20. Use this to change the threshold for the dynamic volume slider.
dynamicVolumeSliderMax: 40 # default is 30. Use this to change the max value for the dynamic volume slider.
artworkHostname: http://192.168.0.59:8123 #default is ''. Usually not needed, but depending on your setup your device might not be able to access the artwork on the default host. One example where it could be needed is if you cast the dashboard with Google Cast.
showAudioInputFormat: true # default is false. Will show the audio input format (e.g. Dolby Digital) in the player section if available. By default, it will only show if the input format in the volumes section.
fallbackArtwork: https://cdn-icons-png.flaticon.com/512/651/651717.png # Override default fallback artwork image if artwork is missing for the currently selected media.
entitiesToIgnoreVolumeLevelFor: # default is empty. Use this if you want to ignore volume level for certain players in the player section. Useful if you have a main device with fixed volume.
  - media_player.my_sonos_port_device
artworkMinHeight: 10 # default is 5. Use this to change the minimum height of the artwork in the player section. Unit is in rem.
artworkAsBackground: true # default is false. Will show the artwork as background for the player section.
playerVolumeEntityId: media_player.bedroom # default is empty. Use this to control the volume of another player in the player section. Entity ID must the selected player or part of the selected player's group, otherwise it will not be controlled.
allowPlayerVolumeEntityOutsideOfGroup: true # default is false. Will allow the playerVolumeEntityId to be outside the group of the selected player.
showSourceInPlayer: true # default is false. Will show the source (if available) in the player section.
showBrowseMediaInPlayerSection: true # default is false. Will show the browse media button in the player section.
showChannelInPlayer: true # default is false. Will show the channel (if available) in the player section. This can for instance be the radio station name.
hidePlaylistInPlayer: true # default is false. Will hide the playlist name in the player section.
stopInsteadOfPause: true # default is false. Will show the stop button instead of the pause button when media is playing.
# media browser specific
favoritesItemsPerRow: 1 # default is 4. Use this to show items as list.
favoritesHideTitleForThumbnailIcons: true # default is false. Only makes a difference if favoritesItemsPerRow > 1. Will hide title for thumbnail artworks.
customFavoriteThumbnails:
  Voyage: https://i.scdn.co/image/ab67706f000000027b2e7ee752dc222ff2fd466f
customFavoriteThumbnailsIfMissing:
  Ed Sheeran Radio: https://i.scdn.co/image/ab6761610000e5eb4d2f80ceffc6c70a432ccd7c
  Legendary: https://i.scdn.co/image/ab67706f000000027b2e7ee752dc222ff2fd466f
  fallback: https://cdn-icons-png.flaticon.com/512/651/651717.png # will use this if thumbnail is missing and none of the above matches. Defaults to image of music notes.
favoritesToIgnore:
  - My Favorite Album
  - My Bad Playlist
topFavorites: # Show these favorites at the top of the list
  - Legendary
  - Country Rocks
  - Kacey Musgraves Radio
numberOfFavoritesToShow: 10 # Use this to limit the amount of favorites to show
hideBrowseMediaButton: true # default is false. Hides the button to open the media browser.
replaceHttpWithHttpsForThumbnails: true # default is false. Use this if you  want to replace http with https for thumbnails.
mediaBrowserTitle: My favorites # default is 'All favorites'. Use this to change the title for the media browser/favorites section.
# volumes specific
hideVolumeCogwheel: true # default is false. Will hide the cogwheel for the volumes section.
Using individual section cards
As mentioned earlier, use the individual sections for more layout flexibility.
Here is an example:
type: horizontal-stack
cards:
  - type: custom:maxi-media-player
    sections:
      - groups
      - volumes
    sections:
      - player
    sections:
      - grouping
      - media browser
Theme variables
The following variables are being used and can be set in your theme to change the appearance of the card:
--accent-color
--primary-color
--secondary-text-color
--secondary-background-color
--disabled-text-color
Read more about using theme variables here: Home Assistant frontend - Home Assistant
Custom Favorites
You can add your own buttons to the Favorites section. This can be useful if you want to quickly start a specific radio station or playlist.
To determine what to configure for a button do the following:
  1. Start playing the radio station or playlist you want to add. This can for instance be done in this card’s media browser or in the built-in Home Assistant Media page.
  2. Open the Developer Tools in Home Assistant.
  3. Go to the States tab.
  4. Find the media player entity that is playing the radio station or playlist.
  5. Look for the media_content_id and media_content_type attributes.
  6. For the thumbnail, you can inspect the HTML to see what image the media browser is using, or you can also use a local URL if you have the image stored locally.
  7. Use these values to configure the custom favorite.
Example:
customFavorites:
  all: # 'all' means it will show for all players, otherwise specify the entity_id of the player.
    - title: BBC
      media_content_id: x-rincon-mp3radio://http://stream.live.vc.bbcmedia.co.uk/bbc_world_service
The volume level slider is dynamically adjusting its scale. If volume is below 20% it will show a scale up to 30%. Above
20% it will show a scale up to 100%. The color will also change from green to red clearly indicating which scale is
being used.
Enable it in config with dynamicVolumeSlider: true
Linking to specific player
Append #media_player.my_sonos_player to page URL to have that player selected.
If entityId is configured for the card, the url param will be ignored. See more in the Usage section above.
Sort order of entities
If you want to have a custom sorting for your entities in the groups section you can use the entities configuration.
Default is otherwise to sort by entity name.
Example:
entities:
  - media_player.sonos_kitchen
  - media_player.sonos_hallway
  - media_player.sonos_bedroom
  - media_player.sonos_livingroom
CSS Styling
The recommend way to change look and feel is to use the built-in theming capabilities in Home Assistant. If that is not enough this card supports being styled with card_mod.
Example:
card_mod:
  style: |
    ha-card {
      color: white !important;
      background: gray;
      --accent-color: pink;
      --primary-color: white;
      --secondary-text-color: white;
      --secondary-background-color: pink;
The above YAML renders the following:
Very cool card, thanks for this. I’m using the linkplay platform for multiroom audio which has its own service for grouping speakers. Is it maybe possible to change which service is used for joining speakers?
If the Home Assistant integration for your speakers support grouping it should work. Otherwise I’m afraid not.
Good morning, please help to understand how to use this card with the yTube Music Player integration
thanks!!
This card only supports media_player entities.
Love this card! Thanks for sharing!
Looks like this doesn’t support homepod mini through Apple TV integration, despite it has media_player entity. Any idea how to get it to work?
I don’t have any homepods, so hard for me to test.
What does it look like when you try to add it?
Please share screenshots and errors from web console (if there are any).
Also how it looks here: http://homeassistant.local/developer-tools/state
Can you try this new release?
v1.2.0
:bug: Fixes
It already shows the homepod mini too. Thanks!
However, the grouping does not work with it. The device itself does not support this service. Now, I’m trying to integrate through Music Assistant add-on.
Yes, as expected. Only devices that actually support grouping will be groupable. I can think of a way to show it more clearly in the card though.
Nice card! Just installed it but wondering where the ‘Favorites’ coming from? Can one adjust them manually?
can this work with plexamp on my phone?
I’m also wondering the same, did you find the solution already?
@Robert_Shed
If it shows in the built in media player, it should work
Hi, it’s possible that the player switch to the currently playing media player automatically?. I mean, if I activate my home pod asking to Siri and starts playing is posible that the player show the HomePod media player without the need of interact with the player manually?
I tried with auto entities that works well with mini media player but I not able to make it work with maxi media player.
And a second question, it’s is possible to set the default image url with the content of a sensor? I have a sensor with the current playing Xbox game and I would like to show the actual cover of the game that I have stored in a sensor
Any help will be appreciated
fellow is trying to get this card into auto-entities, but were having a hard time populating the entities map
    - type: custom:auto-entities
      card:
      filter:
        include:
          - domain: media_player
      card_param: entities
would be the minimal config for that, but we still see:
please have a look what this error means, and if we should try something else to auto-populate?
given the card_param: entities is default for auto-entities (just like when populating a core entities card) I shouldn’t have entered it here, but it makes no diffrence taking it out, so I gather it is indeed default, but not working with this particular card
Ive been chatting with the auto-entities author and that card generates a list like
entities:
  - entity: media_player.x
  - entity: media_player.y
  - ...etc...
however, when we do
      entities:
        - entity: media_player.googlehome_library
        - entity: media_player.googlehome_hal
the maxi-media-player card shows the same error, of not finding entities.
hope this can be fixed, FR FR add option to list entity: media_player.abc · Issue #52 · punxaphil/maxi-media-player · GitHub
Hello, I’m using your code and it’s great. However there is a problem with my HOMEPOD, when it is paused there is no option to restart playback like on the original card. In my screenshot you can see the play function circled in red. How can I add it? THANKS
I’ll take a look
Hello, very nice media player card with lots of useful functions. Specially the grouping of multiroom snapcast speakers is great.
I ve a few small questions:
  • How would i Set the favorites? Its not necessary, to do this dynamically. For me its enough, when i can set favorites in Settings or yaml.
  • Is there a way, to play complete media folders instead of single files from local disk? In my case i use mopidy, if it is necessary.
  • Is there a way to filter the sources?
Thanks very much
Hey @PunxsutawneyPhil, I recently wanted to change all my sonos card to this new card as I have none sonos media player. That said I have come across and error that I hope you might be willing to take a look at for me. 1) favorites from non sonos devices do not show up in the favorites section I have the go looking for them in media browser for them . 2) if I have a sonos media player and a non sonos media player I am only able to see the items from sonos favorites and none from the other. Is there any way for the card to show favorites from both media players at the same time?
