sorry, yes, the topic is updData , that 5002xx is this MC6 mac address.
the data is encrypted with AES256, we will upload a new firmware which you can set the key or select none-encryption next week.
attached picture is the mqtt data list
Hi Paraviod
Yes, if first unit firmware is 3.xx are new touch hardware.
Domaray: Pleaseā¦ What is wrong in my HA?
Didnāt work Away and Off button.
Can you help me please?
Hi
when I connect the jfasher it gives me this error, what can it be?
I have rechecked the wiring several times and it is fine
Hello.
Are there any updates on this? Iām looking for old/new touch firmware.
Cheers,
Mateusz
Hi MateusZ
Please check this download link: https://we.tl/t-RBL1C3YUif
To modify the MQTT server please operate as below:
Regards
Yu
Hi MateusZ
This link is the MQTT firmware for common MC6, it connects to our MC6 cloud server , the data is encoded by AES128, user could use our App - Myhouse Pro to operate this mqtt MC6.
Regards
Yu
Regards
Yu
Hello Yu.
Thank You very much for your prompt replay. I do really appreciate it!
Thanks for the instructions as well.
Have a nice day!
Cheers,
Mateusz
Pleaseā¦ anybody know why my AWAY and ON/OFF button didnāt work?
Hi, sorry for the error in he blog. I have updated with the correct code. Here you are:
switch:
- platform: mqtt
state_topic: "home/termostato/status/state"
command_topic: "home/termostato/status/set"
value_template: "{{ value_json }}"
payload_on: "1"
payload_off: "0"
qos: 0
retain: true
icon: mdi:power
- platform: mqtt
state_topic: "home/termostato/away/state"
command_topic: "home/termostato/away/set"
payload_on: "1"
payload_off: "0"
qos: 0
retain: true
icon: mdi:login
Hope it works now
Domaray Thank you very much!!!
//History is same problem.
for history:
- platform: mqtt
state_topic: "home/termostato/mode/state"
Do you mean this?
- platform: mqtt
- platform: mqtt
state_topic: "home/termostato/away_temperature/state"
Domaray thankās. Now is fully work.
Is there any way I can add +/- buttons to change the temperature?
@Domaray thank you for your blog post about MC6 and HA!
I have a question, does anyone have issue with connectivity ? Or is there a way to debug what is going on if integration is not working as it should?
You can see history how it behaves, last data is from 4 hours ago, previously from 9 and 16 etc. but Iām trying to change the temperature, turn it on/off, set to away, basically everything that integration offers, without any change on the MC6 and without any change in history
How it looks like when I change temperature
https://gifyu.com/image/UAly
This is my card configuration (taken from blog)
cards:
- entity: climate.salon
type: thermostat
- cards:
- entity: switch.termostato_on_off
hold_action:
action: more-info
show_icon: true
show_name: true
show_state: true
tap_action:
action: toggle
type: button
- entity: switch.termostato_away
hold_action:
action: more-info
show_icon: true
show_name: true
show_state: true
tap_action:
action: toggle
type: button
type: horizontal-stack
- type: entities
entities:
- entity: input_number.away_temperature
icon: 'mdi:thermometer'
state_color: true
type: vertical-stack
Here are configuration and automation scripts
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
climate:
- platform: mqtt
modes:
- "off"
- "heat"
- "auto"
temperature_command_topic: "home/termostato/temperature_setpoint/set"
temperature_state_topic: "home/termostato/temperature_setpoint/state"
temperature_state_template: "{{ value_json|float / 10 }}"
current_temperature_topic: "home/termostato/current_temperature/state"
current_temperature_template: "{{ value_json|float / 10 }}"
mode_state_topic: "home/termostato/mode/state"
temperature_unit: c
max_temp: 30
min_temp: 15
temp_step: 0.5
retain: 1
switch:
- platform: mqtt
payload_on: "1"
payload_off: "0"
qos: 0
retain: true
icon: mdi:power
- platform: mqtt
payload_on: "1"
payload_off: "0"
qos: 0
retain: true
icon: mdi:login
- platform: mqtt
- platform: mqtt
- platform: history_stats
entity_id: sensor.termostato_mode
state: 'heat'
type: time
start: '{{ now().replace(hour=0, minute=0, second=0) }}'
end: '{{ now() }}'
state: 'heat'
type: time
end: '{{ now() }}'
duration:
hours: 24
state: 'heat'
type: time
start: '{{ as_timestamp( now().replace(hour=0, minute=0, second=0) ) - now().weekday() * 86400 }}'
end: '{{ now() }}'
state: 'heat'
type: time
start: '{{ 0 }}'
end: '{{ now() }}'
automation.yaml
- id: '1597530567890'
alias: Set Away Temperature
description: ''
- entity_id: input_number.away_temperature
platform: state
- data_template:
payload: '{{ [(states(''input_number.away_temperature'') | float)*10] }}'
retain: true
topic: home/termostato/away_temperature/set
service: mqtt.publish
mode: single
- id: '1602464759287'
alias: Get Away temperature
description: Set the slide to the away temperature read
- platform: mqtt
topic: home/termostato/away_temperature/state
condition: []
- service: input_number.set_value
value: "{{ (trigger.payload|float)/10 }}"
mode: single
And Node-RED
https://gifyu.com/image/UAnM
What Iām seeing in logs of MQTT broker is
1612389787: New client connected from 192.168.0.20 as mqtt_583dacd3.dd2be4 (p2, c1, k60, uāhamqttbrokerā).
1612390473: Saving in-memory database to /data/mosquitto.db.
1612391335: Socket error on client 5iVhdFcOpxLRMrwpqr2sfQ, disconnecting.
Try modifying the repeating period of the READ command on your Node-RED. Is set to repeat every 10 seconds, try with 15 or even 20.
Hello YuQiang Yu,
I like to try the local MQTT server firmware.
Do i understand it right that there is only one Topic updData/MacAddress ?
Or are there more topics like updData/MacAddress/temp, updData/MacAddress/settemp , ā¦
Best regards,
Frans
Hi Frans
Yes, the current released firmware only have one Topic updData/MacAddress , we can add a new screen to modify the topic(updData/) in next firmware, the last data of topic would be always macaddress of MC6.
Regards
Yu
Hi met98,
you can try the offline programer, please check this link,
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.6ab32e8dxpFjp9&id=565585985680&_u=6n0n2m0ff57
